Question about GE D52GW12 52" Rear Projection HDTV-Ready Television
GE 52 " rearprojection flat screen picture bowing 3d effect
I have had this tv for a few years and just up untill a few weeks ago was working fine.Then about 2 or 3 weeks ago it started to everyonce and a while bow in from the top and bottom .It has no pattern seems to work fine for a while then today it bowed while i was watching tv shut off then when it turned back on it had that 3-D effect with the top and bottom of the screen bowed in .Please help me I am pretty handy when it comes to this stuff unless its complicated can this be a home repair or should a pro do it?
  • henson_892 May 17, 2009
    it was just fine when i went down stairs and now it is an on and off type thing it runs good then it bowes you turn it off for a few and tunr it back on some times it stays like that and some times it comes back is this still the same problem that can be fixed with these parts and thanks for getting back to me so fast
  • GE Master
  • 8,617 Answers
Thats usually a very easy repair by replacing FL231, DL231 and CL230 total parts are about 11.00 at the following link and they provide free instructions. The components are all listed under RCA parts category.
http://servicemanuals.vstore.ca/
Posted on May 16, 2009
  • Sonny Berry
    Sonny Berry May 17, 2009
    yes the components listed should repair your symptoms as long as your model is the D52GW12
Re: Toshiba 65 in Cinema Series - 12 years old. Color Separation. Green bow at top center of screen, red and blue double images tilting upwards toward sides. Sometimes clears unassisted after set has...
projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Here are more details and solutions for both.
Common Problem #1) Convergence has gone out
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some pics of convergence problems.
Common Problem #2) CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
69189a5.pngSOLUTION
You can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jan 20, 2011 | Toshiba 65H82 65" Rear Projection...
Tip
Tv picture has a bow in it and letters are doubled my 52" rca just started the...
I ALSO HAVE A 52 INCH RCA (2 YEARS OLD) I HAVE TRIED ALL OF THE TIPS THAT HAVE BEEN DISCUSSED. LUCKILY I PURCHASED THE EXTENDED WARRANTY ON THIS UNIT.. AFTER A MONTH OF OVER THE PHONE TROUBLE SHOOTING FROM WARRANTY REPAIR CENTER THIS INCLUDED REMOVING THE BATTERIES IN CASE THE REMOTE WAS BAD. THEY FINALLY CAME AFTER IT YESTERDAY. THE PICKUP BOYS SAID THAT THEY ARE HAVING A LOT OF TROUBLE WITH THESE UNITS DOING THIS SAME THING. THEY ALSO SAID THAT SOME WERE BEING REPLACED WITH NEW ONES. NOT SURE IF RCA OR WARRANTY IS REPLACING (MINE WAS PURCHASED FROM BESTBUY WITH BEST BUY WARRANTY). IF ANYONE HAS SPOKEN TO ANYONE ABOUT A REPLACEMENT PLEASE RESPOND. I THINK IF THERE ARE SOME UNITS BEING REPLACED WITH NEW ONES WE ARE MORE THAN LIKELY GETTING THE SAME DEFECTIVE UNITS (WHICH WILL MORE THAN LIKELY WORK UNTIL OUT OF WARRANTY). I WISH THEY WOULD JUST GIVE REFUNDS OR CERTIFICATES TOWARDS NEW DIFFERENT UNITS MAYBE IF THERE WERE ENOUGH COMPLAINTS THIS MIGHT BE CONSIDERED.
on Jun 22, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
We have a RCA D52W23 rear projection TV. Now the color looks like it is in 3D. A friend has the same problem a few years ago and bought a part on line and fixed it themselves. What is the part and where...
  • Screen looks 3D
69189a5.pngSOLUTION
Jan 19, 2011 | RCA D52W19 52" Rear Projection Television
I left my 60 inch rear projection mitsubishi HD 1080 on overnight as I fell asleep in front of it for about 5 hours (11pm - 4am). This morning when I turned it on the picture is doing a fisheye effect on...
It sounds your Mitsubishi rear projection tv got problem with convergence output chips failure, I'm not aware about model number of this tv so unable to provide you specific info however, it is hardware failure and few parts need to be replaced by tv repairman.
Convergence output chips make align picture on front screen and if they stop working, you will see 3D look or bowed picture with different colors.
Contact local tv repair shop to fix this issue in tv.
Thanks.
Nov 17, 2010 | Televison & Video
LG Projection Screen No Picture
Hello, if the model number is correct it's not a projection tv, but an LCD tv. If that's correct, it sounds like a bad main board issue part # is AGF31218501...thanks
Apr 25, 2017 | LG 42LC2D 42 in. LCD HDTV
I have a GE 52 " rearprojection flat screen picture TV 4 years old. The color conveyance is off and it will not realign using the remote. Help!!
If the convergence option is still visible under the picture settings in the menu. Then the problem will usually be related to the convergence power supply board, which is the board on the far left which is suspended over the main chassis. You can get the convergence power supply board, or have yours repaired at www.tvrepairworld.com
Nov 29, 2009 | GE D52GW12 52" Rear Projection HDTV-Ready...
Could use some help with a "bowed" picture on my RCA P52960
Is the convcergence ( Alignment) also off which gives the TV a 3D look around items on the screen? If so replace the STK730-130 on the convergence power supply
Jun 23, 2009 | RCA P52960 52" Rear Projection Television
Screen projector un aligned
Projection TV sets are known to have two common problems. The first problem that is common to these sets is convergence failure. When this happens the TV will usually look 3D, Wavy/Distorted, etc. It may also shutdown and blink an error code.
The second common problem with Projection TV sets is dull video, halos around objects, white looking video, or red overpowers the screen. This is commonly caused by the fluid in the lens being clouded overs.
You can find more details and solutions here on Fixya at the following link below. Or click HERE
3d884ac.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Mar 27, 2009 | GE D52GW12 52" Rear Projection HDTV-Ready...
Crazy menu, comes on periodically without using remote
believe it or noT: try replacing all of the switches on the control panel (((power button switch,menu button switch, etc...)))
Oct 27, 2006 | RCA HD52W56 52" Rear Projection HDTV
GE D52GW12 52" Rear Projection HDTV-Ready Television Logo
307 people viewed this question
Top GE Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a GE Televison and Video Expert? Answer questions, earn points and help others
