My kenmore washer will not adjate.
I have looked and the belts are fine. The washer will adjate A little but not enough to wash the cloths. Help two small kids at home and A lot of dirty cloths. Thank you Julie
  • Washing Mach... Master
  • 8,220 Answers
You probably have a broken drive coupling. The part is cheap enough. here is a pdf:
http://appliancejunk.com/motorcoupler.pdf
Here is one from Jimbo:
http://repair2000.com/coupling.html
Here is one I made:
Direct drive coupling replacement by
TheMobilian
Posted on May 16, 2009
My kenmore portable washer fill up with water but wont keed adjating
no agitation? check the door switch, the motor coupler, the clutch and the belt if applicable and may even want to check the cam dogs in agitator
Feb 07, 2015 | Kenmore Washing Machines
Washing Machine Won't Spin Dry Clothes
You may be overloading the machine. Just because you got them all in there and wet, doesn't mean there was enough room for them to get a good washing. Cut back on size of the load (make sure you have large load selected) and see if that doesn't help you.
Jan 22, 2014 | Kenmore 44932 Front Load Washer
Hi, I have a Kenmore 110.26832692, lately it's been making a loud grinding/thumping noise when agitating. The clothes end up wrapped around the agitator, sometimes even stuck underneath it. The basket...
Sounds like maybe the changing of the dogs might be the problem./The top section of your adjatator sould move freely one direction turn it the other way bottom section should move with it. If it does not do that then your dog install got messed up also you should not barely get fingers under botton section of adjatator/ Note the basket is not supposed to move when washing on this unit . see if unit is doing any of those things get back to us...Good luck
Feb 09, 2011 | Kenmore Washing Machines
Washer fails to remove water from clothes after rinse and spin cycles are completed. M/N 110.26732500
'f its a top load put something down in lid switch hole.....Start wash cycle let unit go through cycle by itself Don;t touch timer unit should fill then adjatate then drain then you will here a clunk and unit will spin thats the wash////then unit will fill then adjatate then unit will drain(this is the inportant part ) unit should drain completely before it spins if it is spinning with the water in it your gearcase is getting bad//This condition also put stress on the clutch//if unit is not draining and spinning at the same time but just spinning slowly then you will need a clutch.....Hope this helps if i did help you please vote need more help please ask..........
Feb 03, 2011 | Kenmore Washing Machines
Washer not spinning enough to ring out cloths
if a direct drive whirlpool, its the clutch, easy replacement, if you have the cabinet off already, remove the agitator, then pump, motor, drop tranny and replace clutch
Jan 22, 2009 | Kenmore 22422 Top Load Washer
Kenmore 80 washing machine won't spin
No belts on that washer. You need a new clutch, the clutch cant grab the basket drive tight enough to spin. I will try to add a tutorial on it tomorrow. Look here for tutorial. www.shop.washermd.com Dave
Jan 05, 2009 | Kenmore 24902 Top Load Washer
Whirlpool Thin Twin Washer
Sounds like the transmission is gone the thing you call the spinning mechanism is call the adjatator it should move left to right I can tell you right now to replace the dog ears if it is a kenmore washer they go bad all the time they cost about 5 dollars they are under the cap on top of the adjatator you will need to pull it off to do the job good luck Ron
Jun 10, 2008 | Whirlpool LTE6234D Top Load Stacked...
Kenmore washing machine
the belt is slipping if this model still has belts.
lean/tilt it back and look under for belts.
its the belt in the center
Feb 29, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore washer model series 23711 pn 10182371800
nurse annie give me your model number and approx age .and will be happy to advise mike give me the age of your washer as you might not have the same problem
Jan 14, 2008 | Washing Machines
Washing Machines Logo
76 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
