Question about Proscan PS38000 TV
I have NO sound!
I have a ProScan PS38000 and There is no Sound coming out of my Speakers, when the TV is on and the picture is very Clear i've tried everything. What should i do?
  • Anonymous Feb 13, 2008
    I had a power bump and now no sound is comming out, but picture is good. Afraid that something got fried inside, but this thing is just too big to take to the shop. CC people are useless.
Check for two locations - on the back of the set itself, lower right hand side. A switch for the speakers (EXT -up-, INT -down-) should be in the down INT position for the TV's internal speakers. Also on the TV screen go to MENU> AUDIO> SPEAKERS> press enter to check the ON button. Of course the other option is a separate amp (using the rear Audio Output RCA jacks), or below that the LEFT/RIGHT external speaker connectors.
Posted on Jun 09, 2008
I have a proscan model # 32LB30QD it was manufactured in 2008-10-11. I can watch picture just fine but audio only comes out trough the yellow red white chords. not directly from the tv itself. Sad that i...
Without getting too technical, it sounds like you may have an internal connection issue. Have you tried using external speakers with it? That might be ab easy fix.
Nov 28, 2013 | Proscan 32LB30QD 32 in. LCD TV
My 42" Proscan TV is
Try another set to see if does the same - if so, then it is your box. If not it is the tv. If still under warranty have it fixed before the no sound becomes permanent.
Sep 16, 2017 | Proscan 42LA45H 42 in. LCD TV
No Sound on ProScan 50" Rear Projection
Check that sound is not "Muted";
Check that speakers are not turned off;
If using a S-VHS component, remember to connect the components L & R AUDIO OUT jacks to the TV's L & R INPUT jacks.
Jun 03, 2009 | Proscan PS50700 50" Rear Projection...
Go to there website to download the pdf version of the manual.
If that does not help look on the back and you should see optical out, audio out type connectors.
Most effective way would be to buy a surround sound amp and connect it via an optical out to the surround sound amp and the surround sound amp will have the connectors for the surround sound speakers.
May 18, 2009 | Proscan 42LA45H 42 in. LCD TV
Proscan tv surround sound hook up
This depends on whether you have digital cable box or not. If you have a Digi Cable Box look for the red/white RCA output and connect this via RCA cable to the Red/White Audio input on your surround.
If just Basic Cable look for a red/white audio output on the back of your televison. connect this to the Red/white in on your surround. Could be called tv in or auxillary.
Jan 28, 2009 | Proscan 26LB30QD 26 in. LCD HDTV
the ticking sound is coming out from the flyback that is high voltages!!! if you on the unit is there a picture coming out? or sounds coming out from speaker?
Jul 02, 2008 | Televison & Video
No Audio, picture fine
this is a very common problem just unplug tv for 5 minutes it
should fix it . simple fix most of the time with rca and proscan.
If that does not do it go into menu scroll down to audio and then press on .
thanks doctor video leading edge electronics
Apr 28, 2008 | Proscan PS36800HR 36" TV
The video works perfectly but there is no audio
The best part is that you like the picture and that makes it worth repairing,before you call for an estimate tap on the side of the set and/or the jack panel to see if the sound comes back if it does react you are looking for a loose conection and the repair should not be expensive but if it does not react you might be looking at the stereo amp board and that can be expensive depending in your location,If you are familiar with tv service you can go as far as removing the back cover and taping on the chassis or in the area were the internal speaker wires conect to the chassis or the amp board but if you are not too familiar be safe and call for assistance from a servicer.
Oct 04, 2006 | Proscan PS50700 50" Rear Projection...
Proscan to Bang and Olauffson sound system
FDirstly, you should not connect your TV to a Sound System. If you desire to listen to your Broadcast TV , and enhance the listening experience,I suggest you use the Audio L & R outputs of your Cable Box to your Sound System AUX IN , and Video Out to the TV's Video IN socket. Then you will recieve a better picture and a enhanced sound quality. But just directly connecting the TV's Audio Out to the Sound System will make scarcely any difference.
Aug 20, 2006 | Proscan PS36600 36" TV
Proscan PS38000 TV Logo
233 people viewed this question
Top Proscan Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you a Proscan Televison and Video Expert? Answer questions, earn points and help others
