I need to find the sky remote code for my lg tv. model: LH 3000.
Just got an LG 42LH2000 and code 0206 works
Try these
0206 1206 1293 0851 0857 1665 1174 1176 1219
1280
0065 0244 0405 0318 0037 0398 0191 0459 0245
0584 0137 0634
You will probably need a REV 8 remote control. If you have a old Sky+
box it may only be REV 6.
To program the remote control unit using a 3 digit code:
1 Turn your TV on.
2 Press TV on your Sky remote control handset.
3 Hold down SELECT and the RED button together for about 2 seconds,
until the red light on the Sky remote control flashes twice.
4 Key in your 3 digit code selected for your make of TV from the table
below. The light on the Sky remote control should flash twice. If the
light flashes only once, recheck the code for your make of TV and start
again at Step 1.
5 Press the STANDBY button on your Sky remote control. If your TV
switches off, press SELECT. The light on the Sky remote control flashes
twice. Now try the other functions.
6 Repeat if necessary using another code.
To program the remote control unit using a 4 digit code:
1 Turn your TV on.
4 Press TV on the remote again.
5 Type in the 4 digit code for your TV. The LED on the remote should
flash twice. If the LED only flashes once, recheck the code for your
brand of TV and start again at Step 1.
6 Press STANDBY, and your TV should turn off. If it doesn't, switch off,
press TV, then press the STANDBY button. Repeat this (press TV, then
STANDBY) until your TV turns off, then press SELECT.
NOTE: If the LED on the Sky remote control flashes 3 times then all
internal codes for that make of receiver have been checked. Repeat from
step 1, ensuring that you enter the correct manufacturer code.
7 You should see the TV Guide screen. When you do, the remote control
set-up process is complete. If you do not see the TV Guide screen, you
must now complete the following steps.
8 Press TV on the remote control.
9 Hold down SELECT and the GREEN button together for about two seconds,
10 Key in the number of the channel on your TV that you use for watching
satellite TV.
11 Press SELECT on your remote control. The red light flashes twice. The
remote control setup process is complete.
