Question about Dometic RM2652 Refrigerator
Is there a 12volt coil in a Dometic rm52 refrigator
I would like to know if the model dometic rm2652 it only a two way model ( Gas,110 elect
  • Dometic Master
  • 8,220 Answers
What you would need to do is get an inverter to power the icebox. Turn the 12 volts into 110 to power up the compressor. THE INVERTER STORE has aone for $199
Posted on May 16, 2009
Dometic RM2652 check light
possible bad 12 volt heater element
Apr 11, 2018 | Dometic Heating & Cooling
My camper has a dometic RM2652 refrig. the electric works, but it won't transfer to butane
Most dometic refrigerator have a button you need to push when you shift the mode switch to gas. This button holds the gas valve open until the thermopile generates enough power to hold the valve open. So on most shift the mode switch to gas, hold the button until the flashing light goes out. The flashing light indicates the gas valve is energized and the unit has shifted to gas mode. Depending on when the unit was last used it may take up to 5 minutes for the gas supply to purge the gas lines to the refrigerator. So be patient.
Hope this helps.
Oct 15, 2014 | Dometic RM2652 Refrigerator
Dometic service manual
Check the fuses in the main board on rear of fridge.
Jul 26, 2014 | Dometic RM2652 Refrigerator
Dometic refrig not cooling but found yellow oil at service panel
if you find an oily substance its most likely freon. this looks pretty new so i would say you have a bad soldered joint on a copper to steel line. theses usually ar fot the high side. where the condensor coil or loop runs either to underref or up in the ref walls
Aug 01, 2010 | Dometic RM2652 Refrigerator
Hi,have a dometic rvfridge ,gas and e,ec,was
I would recomend that you downlaod the diagnostic sevice manual, and test a few things yourself.
Roy
Jul 29, 2010 | Dometic RM2652 Refrigerator
98 trailer with a Dometic RM2652 will not ignite on propane
Dometic DM 2652 just installed in travel trailer. Went to plug in and turn on later and discovered no lights or power? what do I start checking?
Apr 19, 2010 | Dometic RM2652 Refrigerator
Have dometic fridge in rv.......new in 2007 all
Check your 12 volt ground
Check the fuses in the back under the cover
Other than that sound to be a bad control board
Oct 23, 2009 | Dometic RM2652 Refrigerator
Refrig does not work on elec
there is a small fuse on some models and check you heater for a short
Jun 02, 2009 | Dometic RM2652 Refrigerator
RM2652 WORKS ON GAS NOT ON AC ALL FUSES OK POWER
www;
Unplug the fridge. Remove the cover from the circuit board, unplug the 2 wires going to the heat element and do an Ohms reading should be 35-45 Ohms. If the Ohms is good then you need a circuit board as long as you have checked the 110 volt fuse on the circuit board.
Thanks for using Fixya
Jerry
Mar 30, 2009 | Dometic RM2652 Refrigerator
Dimetic RM2652 refrgerator problem
Check the coils to the left of the burn chamber they should be hot not as hot as the burn chamber but hot to the touch. If not you could have blockage in the coils not allowing the fluids to flow. Also check that the flu area is clear no nest of any sort wasp or birds.
Sep 02, 2008 | Dometic RM2652 Refrigerator
Dometic RM2652 Refrigerator Logo
158 people viewed this question
Top Dometic Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Dometic Refrigerator Expert? Answer questions, earn points and help others
