Question about Compaq Presario R3000 Notebook
I have a 4 year old compaq presario r3000 with xp home edition installed, now the problen is it won't boot because the hal.dll is corrupted or missing, I have been wanting to install Windows Vista Home Premium is that possible and would that solve my problem?
  • 585 Answers
I'm not sure what the other response said, but I would discourage the Vists installation. It's likely that neither the hardware nor the software will support each other. If you can get the current system to boot into safe mode (F-8 key at boot) you can likely repair the current system. If windows won't boot into safe mode, try the Compaq utilities accessed using F-10 at boot.
Hope you're successful.
Posted on May 16, 2009
  • 115 Answers
I wud say that plz dnt install windows vista coz tat wud eat up lot of computer's memory and ur computer wnt be running ,,it wud b walking,,and u wud get irritated,,moreover u wud face problems with the 3rd party softwares tat u wud try to installl,,resulting in more problems,,my advice,,go with xp,,easy convenient to use
best of luck,,giv a good rating use,,keep me posted
Unable bootup & error prompt that HAL.dll file missing or corrupt
CauseCauses of the "missing or corrupt hal.dll" error include, naturally, a damaged hal.dll DLL file or a hal.dll file that has been deleted or moved from its intended location. Additional causes may include a damaged or missing boot.ini file or possibly a physically damaged hard drive.
Resolution
  1. Restart the PC. The hal.dll error could be a fluke.
  2. Check for proper boot order in BIOS. You might see the hal.dll error if the boot order in BIOS is first looking at a hard drive other than your main hard drive.
    Note: If you've recently changed your boot order or recently flashed your BIOS, this may be what's causing your problem.
  3. Run Windows XP System Restore from a command prompt. If this doesn't work or you're receiving the hal.dll error message before you're able to complete this process, move on to the next step.
  4. Repair or replace the boot.ini file. This will work if the cause of the problem is actually Windows XP's boot.ini file and not the hal.dll file, which is often times the case.
    Note: If repairing the boot.ini does correct the hal.dll issue but the problem reappears after a reboot and you've recently installed Internet Explorer 8 in Windows XP, uninstall IE8. In this specific situation, IE8 could be the root cause of your hal.dll problem.
Nov 09, 2010 | Acer Aspire 4720 Notebook
Keep getting this message <window
  • "Windows could not start because the following file is missing or corrupt:
    <Windows root>\system32\hal.dll.
    Please re-install a copy of the above file."
  • "<Winnt_root>\System32\Hal.dll missing or corrupt:
  • "Cannot find \Windows\System32\hal.dll"
  • "Cannot find hal.dll"
The "missing or corrupt hal.dll" error displays shortly after the computer is first started. Windows XP has not yet fully loaded when this error message appears. CauseCauses of the "missing or corrupt hal.dll" error include, naturally, a damaged hal.dll DLL file or a hal.dll file that has been deleted or moved from its intended location.Additional causes may include a damaged or missing boot.ini file or possibly a physically damaged hard drive.
    Please let me know you have any further questions or concerns.
Thanks.
May 08, 2010 | HP Compaq 6720s Notebook
The file <windows root>\system32\hal.dll.
Write a new partition boot sector to the Windows XP system partition. If the partition boot sector has become corrupt or isn't properly configured, you may receive the hal.dll error.
Recover data from any bad sectors on your hard drive. If the physical part of your hard drive that stores any part of the hal.dll file has been damaged, you're likely to see errors like this.
Restore the hal.dll file from the Windows XP CD. If the hal.dll file is truly the cause of the problem, restoring it from the original Windows XP CD may do the trick.
Perform a repair installation of Windows XP. This type of installation should replace any missing or corrupt files. Continue troubleshooting if this does not resolve the issue.
Perform a clean installation of Windows XP. This type of installation will completely remove Windows XP from your PC and install it again from scratch.
Note: While this will almost certainly resolve any hal.dll errors, it is a time consuming process due to the fact that all of your data must be backed up and then later restored.
Feb 15, 2010 | Dell Latitude E5500 Laptop
Hal.dll file missing or corrupted
Follow the steps given in the link below to troubleshoot the hal.dll missing issue:
http://support.microsoft.com/kb/945380
Aug 26, 2009 | Microsoft Windows XP Home Edition with...
I have a compaq presario r3000 running xp home. When I boot, it never finishes booting. It gets stuck in boot mode and just stays that way.
hi
some of your OS files got corrupted or deleted.
you just have to repair the OS using bootable CD.
be carefull while selecting the options dont select the FORMAT option just select the repair option..this will do.
if you find the solution useful plz rate me carefully
Jun 30, 2009 | Compaq Presario R3000 Notebook
  1. Verify the boot.ini file is found on the computer by using a boot diskette or use your Windows CD to get to the MS-DOS "C:\>" prompt.
  2. From this prompt edit the boot.ini, verify that it is pointing to the correct operating system, and that no anomalies are found within the file. Below is a listing of what to verify
  • If only one operating system is on the computer verify that the boot.ini only has one operating system listed. In some situations an alternate configuration line may be added for the same operating system, leaving the improper line.
  • Verify that the "default=" line as well as the operating system line are the same and that they are pointing to the correct operating system.
Verify that the computer has the hal.dll file
From the MS-DOS "C:\>" prompt quickly determine if your computer has the "hal.dll" file by typing "dir hal.dll /s" at the prompt. If the computer returns a "File not found" message, the hal.dll has been deleted.
To recover this file boot the Windows operating system CD and choose the option to "Restore", "Repair", or "Recover." This option will prompt you for the Windows installation to use, the administrators password and will allow you to restore the proper file. At the MS-DOS prompt type the below command.
expand C:\i386\hal.dl_ D:\windows\system32\
In the above example "D" would be the letter of your CD-ROM drive and "C" the letter of the drive your operating system is installed on. For example, your disc drive may be D: and your hard drive is likely C:.
Jun 04, 2009 | Compaq Presario 5000 PC Desktop
Windows system 32 hal.dll error after restoring e-machine
There's actually a number of reasons why these annoying little DLL errors happen, but the most common, is caused when new programs are installed over all old ones and the old ones are not completely uninstalled 100%, causing registry pile ups and of course, getting a .DLL error messages.
Another reason, is damage that's been done by malware/spyware/adware programs, attaching themselves to your PC and wrecking havoc, deleting crucial DLL files from your PC.
The hal.dll file is created during install from 5 other dlls. HAL is the Hardware Abstraction Layer and it's the interface between the system drivers and the actual hardware.
Copying hal.dll will not resolve the problem.
A lot of times the file will be reported missing due to corruption of the boot sector or of the file system
Causes of the "missing or corrupt hal.dll" error include, naturally, a damaged hal.dll file or a hal.dll file that has been deleted or moved from its intended location.
Additional causes may include a damaged or missing boot.ini file or possibly a physically damaged HDD.
Suggested remodies-
5. Write a new partition boot sector to the Windows XP system partition. If the partition boot sector has become corrupt or isn't properly configured, you may receive the hal.dll error.
6. Restore the hal.dll file from the Windows XP CD. If the hal.dll file is truly the cause of the problem, restoring it from the original Windows XP CD may do the trick.
7. Perform a repair installation of Windows XP. This type of installation should replace any missing or corrupt files. Continue troubleshooting if this does not resolve the issue.
8. Perform a clean installation of Windows XP. This type of installation will completely remove Windows XP from your PC and install it again from scratch.
Important: If you can't gain access to your files to back them up, understand that you will lose them all if you continue with a clean installation of Windows XP.
9. Replace the hard drive. Finally, if all else has failed, including the clean installation from the last step, you're most likely facing a hardware issue with your hard drive.
10. Perform a new installation of Windows XP after installing the new hard drive.
I have not tried it - but HERE is a free program purporting to fix the error.
Thanks for using FixYa - a FixYa rating is appreciated for taking the time to answer your FREE question.
Apr 10, 2009 | E-Machines eMachines Desktop PC
Been having this problem for 2 months.. computer is turned off... have been rebooting from CD in drive for 1 year... harddrive tired and cannot boot up by itself... lately cannot get to any Recovery mode,...
If you have a Windows XP CD, follow these steps.
1. Boot from the CD and start the installer
2. Choose to install onto the already formatted partition with the unbootable Windows, but opt to leave the existing filesystem and any other OSes alone. Choosing this will require you to create another folder for Windows to avoid writing over the existing installation. I usually call the new folder "WINXP."
3. Install Windows as you would normally, you'll need a Product Key but you can actually use your personal key on someone else's computer with no danger to you losing it or being accused of piracy, I'll explain this later.
4. Boot the NEW Windows XP install. Do not "Activate" or "register," you're going to be deleting this copy of Windows from the machine if all goes well.
5. Edit the BOOT.INI on the hard drive from the original installation of Windows with the corrupted HAL. This file should be in C:\ (may be hidden)
Sample BOOT.INI for XP Pro
Microsoft wrote:[boot loader]
timeout=10
default=multi(0)disk(0)rdisk(0)partition(1)\WINDOWS
[operating systems]
multi(0)disk(0)rdisk(0)partition(1)\WINDOWS="Microsoft Windows XP Professional" /NOEXECUTE=OPTIN /FASTDETECT
6. Go to C:\WINXP\system32\hal.dll (where "WINXP" is the folder you installed the second copy of Windows XP) and copy it from the new Windows to C:\WINDOWS\system32\hal.dll (or wherever you installed Windows XP originally, I use "WINDOWS" but some people use strange folder names for their XP) and overwrite any file there. The new hal.dll is uncorrupt and newly regenerated. The file is specific to each machine's hardware configuration and we needed to rebuild it. The installer did that for us with the new installation.
7. Try rebooting your computer to see if you can get into your OLD Windows installation. If you can, congratulations!
8. DELETE the "WINXP" folder (or wherever you put your new Windows install).
PS: Please rate this solution
Mar 11, 2009 | Computers & Internet
Hal.dll file missing, can't boot from xp disc as error states hard drive cannot be detected
Issue : Blue screen - Missing HAL.DLL error message
Solution :
1) Insert your windows XP CD into your CD/DVD drive.
2) Restart your computer.
3) Press the F12 key to access the one time boot menu.
4) Select Onboard or USB CD-ROM Drive.
Press any key when prompted.
5) The Windows XP Setup will launch.
6) Press R to choose the Repair option and enter recovery console on the Welcome to Setup Page.
7) bootcfg /rebuild
8) Enter Y and press enter
9) Type Microsoft Windows XP Home Edition or Microsoft Windows XP Professional Edition.
10) Type /fastdetect
11) Type Exit
Nov 15, 2008 | Computers & Internet
Compaq Presario P8656U
ya u can do a formatt or repair im open for direct chat
Jan 21, 2008 | Compaq Presario 5000 PC Desktop
Compaq Presario R3000 Notebook Logo
158 people viewed this question
Top Compaq Computers & Internet Experts
Abhinandan  Patil
Abhinandan Patil
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
