Question about Acer Aspire 5610 Notebook
When I am on the web, for instance on-line classes, and different gaming sites my notebook's fan runs high and then the notebook clicks off. HELP I am often right in the mist of something and it shuts off without warning accept for the fan blowing hard.
  • 489 Answers
You have problem with cooling. coling system need to be cleaned.  in the service or do it yourself.
Posted on May 27, 2009
What is difference between a class and an object with respect to Java?
This kind of question is a test of your knowledge of the terminology associated with object oriented programming. You should note that this question could just as well be asked in the context of a C++ programmer interview, or any programming position that requires object oriented programming for that matter.
The terms 'class' and 'object' are definitely related to one another, but each term holds its own distinct meaning. Let's start out by explaining what the term "class" means in the context of OOP. The term 'class' refers to the actual written piece of code which is used to define the behavior of any given class. So, a class is a static piece of code that consists of attributes which don't change during the execution of a program - like the method definitions within a class.
An object is an instance of a class The term 'object', however, refers to an actual instance of a class. Every object must belong to a class. Objects are created and eventually destroyed - so they only live in the program for a limited time. While objects are 'living' their properties may also be changed signficantly.
An example will help clarify what we've said. Suppose we have a class called 'Animal'. All Animals have bodies and brains - and these could be the attributes of our fictional Animal class. We can also add some methods that would be common to all Animals - like "movement", because all animals can move (maybe you can think of a better example for methods, but hopefully you get the point). So, the idea you really want to enforce in your own mind is that this very general 'template' of an Animal does not change - it's simply just some lines of code that define the Animal class.
An instance of the Animal class would be a specific animal - like a lion, a cat, or a zebra. These instances of the Animal class would be called objects. Whereas the Animal class is a general concept, the instances of that class - the lions, cats, etc - take that general concept and create a real instance of it. That is why programmers define constructors for their classes - so that when someone wants to create an object of the class, he/she can just pass in the actual properties that he/she wants the object to have - like what kind of animal it is, the name, the weight, etc. So, you can think of a constructor as something that brings the class to life - which is why it is called a constructor, because it constructs a specific instance of a class.
Objects have a lifespan but classes do not And, as our Animal example clearly shows, every object has a lifespan associated with it - a cat or zebra can not live forever. And, the properties of those objects can change as well while they 'live'; if we have a 'size' variable defined in the class that would of course change as the cat object grows bigger.
Object versus class summary So, we can say that whereas a class is a general concept (like an Animal), an object is a very specific embodiment of that class, with a limited lifespan (like a lion, cat, or a zebra). Another way of thinking about the difference between a class and an object is that a class provides a template for something more specific that the programmer has to define, which he/she will do when creating an object of that class.
Jul 16, 2014 | Computers & Internet
I have successfully installed prince of persia warrior within on my computer.it is 64-bit win-7. but the programme doesn't run. i also change compability mode to win XP,but it also doesn't run.it...
Play online and Windows version will be handled by the web site. It does not matter which windows version you are using. The game runs by the engine on the web site.
The same game on steam game site:
http://store.steampowered.com/agecheck/app/13500/
Apr 03, 2012 | Microsoft Computers & Internet
I have an acer aspire 5534 notebook and I lost my Cd rom drive... It is showing code 39 My driver is corrupt or missing. I have uninstalled it and re-installed it, same message...I have tryed going on line...
Windows XP
  1. Click Start, and then click Run.
  2. In the Open box, type regedit, and then click OK.
  3. In the navigation pane, locate and then click the following registry subkey:HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11CE-BFC1-08002BE10318}
  4. In the right pane, click UpperFilters.
    Note You may also see an UpperFilters.bak registry entry. You do not have to remove that entry. Click UpperFilters only. If you do not see the UpperFilters registry entry, you still might have to remove the LowerFilters registry entry. To do this, go to step 7.
  5. On the Edit menu, click Delete.
  6. When you are prompted to confirm the deletion, click Yes.
  7. In the right pane, click LowerFilters.
    Note If you do not see the LowerFilters registry entry, unfortunately this content cannot help you any further. Go to the "Next Steps" section for information about how you can find more solutions or more help on the Microsoft Web site.
  8. On the Edit menu, click Delete.
  9. When you are prompted to confirm the deletion, click Yes.
  10. Exit Registry Editor.
  11. Restart the computer.
Jan 25, 2010 | Acer Aspire 5500 5570-2609 Laptop
Help
HP makes 118(!) different computers in the 'G60' line. From their web-site:
http://h10025.www1.hp.com/ewfrf/wc/pfinder?tool=&query=g60
choose your model, and click to download manuals & more.
Jan 07, 2010 | HP G60 Notebook
Pc game says ''game has experienced a problem and needs to close'', and won't start running? This has happened to two games I have downloaded from the game disc but not from a third game. I don't know what...
check the video settings to see if you have the game reolution set to high..if you go to the settings page and set the game reolution to the bottom settings and play the game and nothing happens up the resolution again to a hiogher setting and run again usually different games run at different resolutions and depending on your computer configuration or graphics card this can cause crashes..you may have to download the lates patch for the game from the web site for you game. Good Luck A
Nov 23, 2009 | Video Game Consoles & Games
Lenovo cannot detect DVD ROM, Error code 19 reported. Related to drvier. Tried to update driver but found out driver that is already installed is the latest. Did not find any driver in Lenovo's web....
Microsoft Windows Vista loadTOCNode(2, 'resolution');
  1. Click Start Collapse this imageExpand this imagevistastartbutton.jpg, and then click All Programs.
  2. Click Accessories, and then click Run.
  3. Type regedit, and then click OK. Collapse this imageExpand this imagesecurityshield.jpgIf you are prompted for an administrator password or for a confirmation, type the password, or click Allow.
  4. In the navigation pane, locate and then click the following registry subkey:HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11CE-BFC1-08002BE10318}
  5. In the right pane, click UpperFilters.
    Note You may also see an UpperFilters.bak registry entry. You do not have to remove that entry. Click UpperFilters only. If you do not see the UpperFilters registry entry, you still might have to remove the LowerFilters registry entry. To do this, go to step 8.
  6. On the Edit menu, click Delete.
  7. When you are prompted to confirm the deletion, click Yes.
  8. In the right pane, click LowerFilters.
  9. On the Edit menu, click Delete.
  10. When you are prompted to confirm the deletion, click Yes.
  11. Exit Registry Editor.
  12. Restart the computer.
Now go to the "Did this fix the problem?" section. uparrow.gifBack to the top Microsoft Windows XP loadTOCNode(2, 'resolution');
Nov 06, 2009 | Lenovo ThinkPad SL400 Notebook
What do the different fan speeds indicate
The different fan speeds are different airflows across the coil and blows out into the room..
For instance speed
#1 is usually high speed
#2 is medium high
#3 medium low and
#4 low speed
Aug 17, 2009 | Heating & Cooling
Does not recognize anything in DVD drive. Game or CD, nothing. No error messages. Fan is not running.
hi well first of all most xbox 360 come wid an extended waranty mine had 6 years due to the dreaded 3 red lights of death bst option is go to xb0x web site follow the instructions to register you console then phone the help line theyll arange to pick up the console an repair it to me sound like the mother boards nt wrking certain components ie fan rom drive hope this helps...
May 21, 2009 | Microsoft Xbox 360 Console
Need aurio and modem driver
You can go to the Compaq/HP WEB site to download the latest drivers for your model laptop that suit your particular Windows operating system.
Go to www.compaq.com
Nov 24, 2008 | Compaq Presario Notebook
Fan noise problem
remove the cpu fan clean the dust, then install it again, also put BIOS on default setting, then check
Nov 06, 2008 | HP Compaq nc8000 Notebook
Acer Aspire 5610 Notebook Logo
32 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
