Question about Mtd Garden
Does Bolen's weed wacker BL100 17" cut 31 cc require a mix of gas and oil. Thank you
Does Bolens BL100 17"cut 31cc weed wacker require a mix of gas and oil.
  • Anonymous Mar 22, 2014
    Oil gas ratio boulen
  • Anonymous Mar 26, 2014
    recoil pulley fails to engage flywheel
I was able to get information from someone's manual. I can't find mine. Would like a manual.
Posted on May 18, 2009
    New Friend:
Have a bolens bl100 17'' cut 31cc weedwacker it chokes out when i give it full gassometime even cuts out have to start it again
Posted on Apr 05, 2011
SOURCE:
Does Homelite Gas weed wacker require gas mix
Lookup for your specific model - but most of these require a 50:1 gas/oil mix.
Aug 15, 2014 | Garden
Found a Bolens BL100 weed trimmer with some gas in it , got it started but was wondering exactly the gas/oil ratio mixture
40:1
40 parts gasoline to 1 part 2 cycle mix.
In USA that is 3.2 ounces of oil per gallon of gas.
Sep 13, 2010 | Garden
Oil gas mix
50:1 50 parts petrol to 1 part oil
Jul 24, 2010 | Craftsman 25cc Gas Line Trimmer
Have a Ryobi weed wacker 725r 31cc click link Trimmer Plus. No more line-can't figure out how to remove bottom to replace the line or what kind of line to replace with. Deceased husband lost directions...
i also have a ryobi weed wacker. if it is the same. you don"t have to remove the button. line up the 2 arrows one on wheel with bumpy edges and one by the button. you should see 2 holes feed a 2-3 foot piece of line into the hole the line comes out of for cutting and it should come out of a curved holw on the bottom by the button .tuck the end into a small round hole . pull line tight (tug on the section that you cut with). wind the string by turn the ring around the button. til desired length. if this doesn't work. google you model # and look for a manual (manual for ryobi weed wacker model # ------------.)
Jun 09, 2010 | Garden
Just want the gas oil mix for a 25cc weed wacker
if using sthil oil the mix is 50:1 if not then its either 32:1 or 40:1 not to much dif
Jun 08, 2010 | Homelite Mighty Lite Lawn Trimmer
How do you get the spool off of a gas (31cc) ryobi weed wacker? The string is stuck up in the spool and I can't get it out.
The knob on the bottom unscrews, and the spool comes apart once you get that off.
Mar 27, 2010 | Garden
Weed wacker stall out
#1 fresh fuel mix #2 screen inside carb.
Aug 04, 2009 | Garden
Garden Logo
2,280 people viewed this question
Top Mtd Garden Experts
lnbn1975
Morne Olivier
dannydoesita
Are you a Mtd Garden Expert? Answer questions, earn points and help others
