Question about Toshiba TLP 261 Multimedia Projector
Toshiba TLP-S30 When I push the button the power does not come on. I tried using another cord but the same problem exists. Is there a place I can send this to have it fixed. There are less than 50 hours on the unit over a couple year period. Brian
  • Fujii Mar 27, 2008
    I try to power on the projector and it come to works only for few our and after tnhat no more results when you try again
The output of my projector has become a greenish tint. This happened all at once. I have not found the cause. Does anyone know what to do to correct problem?
Posted on Oct 07, 2008
My TLP-S30 won't power on as well... Didn't touch or move it for week and thought it was batteries in the remote at first but NO :(
Posted on May 20, 2008
Make sure the lamp cover is in place as it has a plunger on it which closes a switch . If the switch is open you will never power on. With the cover remover you can manually actuate the switch too and it will power up.
Posted on Oct 30, 2007
What bulb is needed to replace in the projector?
three green lights come on then the standby light goes red and remains on when the projector is plugged in. The lamp and fan do not come on when the power button is pressed instead the lamp light comes on red.
Jul 13, 2010 | Toshiba TLP S30 Multimedia Projector
Toshiba TLP s30 projector identification part
http://www.nextag.com/toshiba-tlp-s30/search-html
Mar 28, 2008 | Toshiba TLP S30 Multimedia Projector
Toshiba TLP projector identifiation part
You need to check lamp again, it may be not well mounted.
Toshiba TLP-S30 loses calibration/alignment with whiteboard.
there are phisical adjustments for the projector itself. is it on a smartboard? hold down the 2 buttons on the pen tray until the 9 point callibration screen appears. the points react to stylus release, so put the stylus near the point and "draw" a line to the center of the point then release. do the same for the other 8. that should do it.
Dec 11, 2009 | Toshiba TLP S30 Multimedia Projector
I have a Toshiba TLP-S30 and lately the color balance of the projected image is way off. I've tried adjusting the color balance via the menu, but no improvement. Could this problem be fixed with a new...
reset the settings to factory default. sometimes the lamp will burn at a lower temp at the end of it's life and emits a different color. might be the lamp or the ballast. if all else fails, replace the main board.
Oct 18, 2009 | Toshiba TLP S30 Multimedia Projector
Internal fan location in TLP S30, I get an error message about internal fan problem
one of the fans arent working. there should be at least 3- one for the lamp, one for the power supply, and at least one for the lcd panels. you should be able to see the one for the lamp and power supply from the outside. if both are spinning, it's the other one, which you might be able to see from the bottom.
Sep 22, 2009 | Toshiba TLP S30 Multimedia Projector
Toshiba TLP XD-2000
There are two things it could be...
First, how far are you trying to run the cable for? When you run longer distance a humbucker might be needed. Or it means that the internal distribution output has bad vertical and horizontal connections.
Jul 21, 2009 | Toshiba TLP S30 Multimedia Projector
My TLP-S10 can't operate more than 20 second. it automaticaly turn off and its repeatedly. what is the solution..??
the power supply is bad and needs replacing. the capacitors dry out after a while on toshibas.
Jul 09, 2009 | Toshiba TLP S30 Multimedia Projector
White areas in the image are yellow and the black are blue-green
you have a few issues. first is the yellow in white. the light filter on the blue lcd panel is fried due to excessive dust and heat. unfortunately, you may have to replace the whole optical engine. as for the flashing horizontal lines, the power supply isn't cooling down and the caps are drying out, causing fluctuations in voltage. so, replace the power supply.
Jul 04, 2009 | Toshiba TLP S30 Multimedia Projector
HOW TO RESET LAMP HOURS
Do this
Unplug the AC cord
Press Input, VOL - /Standby/Menu at the same time.
Plug the AC cord and wait until the Power light is amber. release the Vol/Standby/Menu bottoms. I hope will work for you.
Jul 12, 2008 | Toshiba TLP S30 Multimedia Projector
Toshiba TLP 261 Multimedia Projector Logo
193 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
