Question about Dishwashers
Top row of dishes are not getting clean.
Ever since we first installed this dishwasher 3 years ago, it has never cleaned very well, but the top row of dishes in particular just doesn't get clean.  Unless we pre-clean everything in the top row, chunks of food will remain on the dishes and bowls up there. This happens even if bowls are facing directly down.
    Problem Solver:
  • 17 Answers
It sounds as if there is no water pressure to the upper arm. You may want to try putting something over one of the holes to see if it is disturbed during th wash cycle. There should be enough pressure there to blow off a piece of masking tape if it is not attached too securely. Do some experimenting to see if you have presure there. There could be a problem with the tube that feeds to the water to the upper arm.
Posted on May 18, 2009
I have same problem but no water comes out of top spray arm. I took hose off at pump to see if it was plugged but everything is clear. Anyone think pump is toast?
Posted on Jun 20, 2009
The top shelf of dishes in my CDA dishwasher isn't coming out clean any more
Look at you manual. How to remove the top spryer to clean it, re-install and presto. (I hope)
Jan 13, 2013 | Dishwashers
My KitchenAid dishwasher is not getting my dishes clean.
Sounds as though the heating/drying element or the controller has gone kaput... You will probably need it serviced.
Jan 31, 2010 | Dishwashers
My GE Eterna Series 3 Quiet power is not cleaning our dishes. Mostly the dishes on the top row has lots of stuff found in the glasses and mugs. YUCK!! I ran it for a minute and there is just water in...
I just took mine apart (bottom turntable, screen, etc.) and I was disgusted by the grime and gum that was clogging everything. I think it was keeping all the water a gritty white, which constantly left residue. I am currently running a load... hope that the "clean" dishwasher actually washes my dishes now!
Nov 18, 2009 | Maytag Dishwasher
GE PDW9700 - The dishes do not get cleaned
Same as above problem: I have had this dishwasher for less than 4 years and the dishes as of about 2 years ago stopped getting cleaned. I use the recommended dish liquid and rinse and lightly clean the dishes before I put them in.
What a piece of junk!! gs
Feb 26, 2009 | GE Profile PDW8400J Built-in Dishwasher
Dishes on top rack don't get clean
The following suggestions will greatly enhance the ability of your dishwasher to clean all of the dishes thoroughly:
1. Rinse all of the food off of the dishes before you put them in the dishwasher.
2. Run the hot water into the sink until it is as hot as it gets before you start the dishwasher.
3. Do not pack the dishes into the dishwasher, just put in a reasonable number without crowding or stacking them on either shelf.
4. Pull the top shelf all the way out to be sure that the water connection at the rear of the top shelf is connected. Sometimes, this connector comes disconnected preventing the water from entering the top spray assembly.
THese things should make a huge difference.
Good luck with this and please rate my answer. Thanks. Joe
Feb 03, 2009 | Kenmore 24 in. 15079 Built-in Dishwasher
Kitchen aid dishwasher doesn't clean dishes in the top rack
Sounds like you have 1 of 2 problems. Either your pump is clogged or you need a bigger drain loop.
Nov 25, 2008 | Dishwashers
DISHWASHER NOT CLEANING TOP RACK DISHES
I had the same problem (no water being delivered to the top rack) and found that the chopper assembly was completely blocked. I removed it, washed it, put the whole thing back together. It works like new now.
Note that it is not easy to get to the chopper assembly. I used the "pump and motor parts" diagram on http://shared.whirlpoolcorp.com/assets/pdfs/literature/Repair%20Part%20List%20-%208193720.pdf. The inlet protector was especially difficult to get off, but I was able to pry it off to expose and remove the chopper assembly. I cleaned all the parts I removed really well before re-installing.
Jun 16, 2008 | KitchenAid 24 in. KUDI01TJ - Multiple...
Dishes not cleaning particularly on top rack
A guess: the solenoid that directs the water from the pump is not opening fully. Clean it. It is a little nasty to get to but will likely cure the problem.
Jun 13, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
Dishwashers Logo
170 people viewed this question
Top Dishwashers Experts
