Question about Kirby G4 Bagged Upright Vacuum
How do I replace the belt on my Kirby sweeper---a G4? Thanks!
I have the correct size belt --thought I knew how to do it--wrong! I appreciate your assistance.
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 112 Answers
1)First, you turn the square belt lifter on the front of the power nozzle until the red arrows line up (belt off of the Kirby's driveshaft but on the "hook" inside the power nozzle) 2)Remove the power head from the front of the machine. Now that it is off the Kirby, you can turn the square belt lifter until the green arrows line up. (Belt on, which means on the driveshaft on the front of the Kirby when the power nozzle is on the Kirby which makes the brushes spin. Now that the power nozzle is off of the Kirby, the belt isn't actually resting on anything but the green arrows will still point to belt ON ) This removes the belt from the "hook" so that it can be slipped off the brush roll. 3)Turn the power nozzle upside down and release the two clips that hold the metal baseplate on and remove the baseplate. 4)Grab the brushroll and pull it out of the power head. Slide the new belt onto the center of the brushroll. It will hang loose...it doesn't have to stretch around anything yet. MAKE SURE THAT THE BRUSHROLL SPINS FREELY!! If it doesn't, you'll burn all new belts quickly due to the added strain on the belt. 5)Look at the ends of the brushroll. The brushroll has three height settings..you should see notches AND NUMBERS on the sides of the brushroll's end caps. ONE notch (also #1) FACE UP on BOTH sides is the first setting and should be used when the roller is new. Three notches is the last setting used before a new roller is needed and should be used if the brushes are short and worn. Put the brushroll back in, making ABSOLUTELY SURE sure that the SAME NUMBER of notches and the same raised number on the edge are FACE UP on BOTH sides. This is important, as the brushroller will be unbalanced if inserted wrong. Also, one end cap of the brushroll is larger than the other and will only fit onto the larger notch in the power nozzle. 6)Replace the baseplate by fitting the front clips into place and then push it down in back and secure it with the two rear swivel clips. Make sure it fits securely down over the bumper on all sides with no suction leakage. 7)Turn the belt lifter to where the RED arrows line up, making sure that the inner "hook" grabs the belt and stretches it up while you are turning it. Once you have the belt stretched up, put the power nozzle back onto the Kirby and lock it in place. 8)NOW...turn the belt lifter back to GREEN. If the little green light on the power nozzle lights up when you turn it on, CONGRATULATIONS!!! The brushroll is spinning!!
Hope this was helpful :) and thank you for using Fixya!!!
Posted on May 23, 2009
Green light no on
HI There,
When the green lights do not come on when vacuuming with a Kirby, this indicates that your belt2_bing.gif has either broken or fallen off. There is a magnet on the beater bar that activates the LED green light when it's spinning.
Here's a helpful video tutorial2_bing.gif that we recorded, that will show you how to replace the belt, as well as perform basic maintenance on your roller brush to prolong the life of your belt as long as possible.
Video Repair on How To Check The Belt on a Kirby Generation G4:
I hope this was helpful! If you have any follow up questions, please feel free to use the comment field here on Fixya.
If you need to purchase a new roller brush, or belt for your Kirby G4, here are direct links to those parts on our website:
Kirby G4 Roller Brush Assembly:
http://www.govacuum.com/kir108.html
Kirby G4 Agitator Belt:
http://www.govacuum.com/kir143.html
If this repair was helpful to you, please be so kind and rate my repair helpful, or leave feedback for me. This is really appreciated by the Fixya community when someone answers your questions.
Thanks again,
Chris Jones
GoVacuum.com
May 21, 2010 | Kirby Ultimate G Bagged Upright Vacuum
The green light is not coming on and kirby is not sucking
HI There,
When the green lights do not come on when vacuuming with a Kirby, this indicates that your belt has either broken or fallen off. There is a magnet on the beater bar that activates the LED green light when it's spinning.
Here's a helpful video tutorial that we recorded, that will show you how to replace the belt, as well as perform basic maintenance on your roller brush to prolong the life of your belt as long as possible.
Thanks again,
Chris Jones
GoVacuum.com
May 14, 2010 | Kirby G4 Bagged Upright Vacuum
Information on how to replace belt on kirby g4 . I am turning the belt square, but cant get belt to attach.
body { background: #FFFFFF; margin: 0px; padding: 4px; font-family: arial, verdana, sans-serif; font-size: 10pt; } p { margin:0px; padding:0px; } .spwrap { background: transparent url(/wysiwyg_rte/misspell.gif) repeat-x scroll center bottom; } Hello,
We recently recorded a very helpful video that will walk you step by step through changing the belt on your Kirby G4. Also the video will show you how you can do routine maintenance on your roller brush that will extend the life of your belt dramatically.
If you haven't already purchased the belt for your Kirby, here's a direct link to the belt that your Kirby G4 uses on our website,
http://www.govacuum.com/kir184.html
Here's the video,
I really hope that the video was helpful. Please feel free to use the Clarification Request here on Fixya if you have any questions about how to change the belt. I am always more then happy to help you further diagnose your machine if my suggestion didn't work. If it did, and you found it helpful, please kindly rate the review as helpful by clicking on the thumbs up icons. Thank you very much.
Chris J.
GoVacuum
Mar 26, 2010 | Kirby G4 Bagged Upright Vacuum
How do you change the belt on a kirby g4 vacum
Greetings,
I have shot an excellent video repair on how to replace the belt on Kirby Generation Vacuum Cleaners, including your Generation 4, G4. The video is below in an easy to follow, and understand video. Feel free to use the pause controls to pause the movie as you're fixing the belt on your Kirby.
I hope this video was able to teach you the exact process of how the Kirby belt has to be installed in order for it to work properly. Please, if you have any questions just request a clarification of the repair and I'll be more then happy to help you further, I'm always happy to answer any questions. If you found this video helpful, please kindly rate this repair solution as helpful also. I really do appreciate it, thank you.
Thanks for watching!
Chris J.
Feb 20, 2010 | Kirby G4 Bagged Upright Vacuum
Kirby G4 causes black streaking when shampooing carpet
Replace the belt it is probably worn. You can get a replacement here:
Kirby G4 Belt
Dec 06, 2009 | Kirby G4 Bagged Upright Vacuum
Kirby heritage II
As long as it is Kirby belt - you should be fine. Make sure that the shaft is clean and that you do not vacuum something greasy or wet (grease or oil will lubricate the belt and shaft will loose the grip -heat up and burn). Make sure that brush roll spins freely.
I am assuming you know how to put the nozzle on properly (if you not sure - go here)
Good Luck
Rocky
Aug 22, 2008 | Kirby Heritage II Vacuum
Kirby heritage 2 sweeper
http://reviews.ebay.com/CHANGING-THE-BELT-ON-A-KIRBY-G3-G4-G5-GSIX-ULTIMATE-G_W0QQugidZ10000000003720039
the above link shows you how to change the belt on the g-series kirbys but it will apply to the heritage edition as well...the only difference is the color...some of the arrows may be missing on the front belt lifter knob...but they are little differences...
hope this helps!!!
Feb 06, 2008 | Kirby Heritage II Vacuum
Kirby G4 Bagged Upright Vacuum Logo
323 people viewed this question
Top Kirby Vacuums Experts
JoeVacs
Gerry Harvey
Gerry Harvey
Are you a Kirby Vacuum Expert? Answer questions, earn points and help others
