Question about Kenmore 10502
Water filter needs to be replaced
How do I find out what the part number is for the water filter without disturbing the current filter?
  • 47 Answers
THERE SHOULD BE A MODEL NUMBER ON YOUR WASHER. TRY THAT,
RODNEY
Posted on May 16, 2009
What type/model/ brand of water filter do I need for the Whirlpool Roper side-by-side refrigerator with the model number: RS25AGXNQ00
There is a generic type of water filter that fits all Whirlpool and KitchenAid refrigerators with a water filter located in the base grill below the door.
it looks a bit like this: http://www.partselect.ca/11722132-2-M-Whirlpool-EDR5RXD1-Water-Filter.jpg
Here is one on amazon: Amazon com Replacement Roper RS25AGXNQ00 Refrigerator Water Filter...
Sep 05, 2016 | Whirlpool Refrigerators
I need a filter bypass cap for model RF323TEDBSR
That model does not take a bypass plug if you don't have water coming. Thru the filter housing is bad part number (da97_08006g) and needs to be replaced but you could take it apart you could coupler the water lines and bypass the filter housing also called filter case
Mar 24, 2016 | Samsung Refrigerators
Ge smartwater plus
The problem would not be from your water filter. The water is controlled by the dual water valve inteh back of the fridge. The water valve will most likely need to be replaced. It's possible that a small piece of debris found it's way to the ice maker water valve after disturbing the filter. It's also possible that the ice maker is at fault too, causing the valve to stay energized too long. Although if the valve stays energized too long it will eventually burn out. You can try unplugging the 2 wire plug to the ice maker valve to see if the problem stops first, if not than you will need to replace the water valve unit. Pleazer Appliance...
Sep 02, 2014 | GE Profile PSW26P Stainless Steel Side by...
Amana model# SZD23VE refrigerator were is the water filter? or does it even have a water filter?
Yes it has a water filter option. The water filter housing is in the refrigerator near the top of the unit. You need to twist the old filter itself to the left to remove. (You will be removing a cover that you need to take off the old filter and put on the new filter. This cover can also be replaced without a filter to bypass the filter. The part number for the filter is AP4310541, http://www.appliancepartspros.com/part_details.aspx?part_id=4310541 .
I hope this helps.
Apr 09, 2011 | Amana Refrigerators
I've got a side by side Whirlpool refridgerator. The Water Filter status light is not indicating. What could be the problem and solution?
There are several pages that explain dispenser programming. This is on page 10 of the owners manual.
Water Filter Status Light (on some models)
The water filter status light will help you know when to change
your water filter. When the water filter status display changes from
"GOOD" to "ORDER," this tells you that it is almost time to
change the water filter cartridge. Replace the water filter cartridge
when the water filter status display changes to "REPLACE." If
water flow to your water dispenser or ice maker decreases
noticeably, change the filter sooner. The filter should be replaced
at least every 6 months depending on your water quality and
usage.
After changing the water filter, reset the status light by pressing
and holding the FILTER button for 3 seconds. The status light will
change from "REPLACE" to "GOOD" when the system is reset.
Changing the Water Filter
1. Press the eject button to release the filter from the base grille.
2. Pull the filter straight out.
3. Turn the cap counterclockwise to remove it from the filter.
IMPORTANT: Do not discard the cap. It is part of your
refrigerator. Keep the cap to use with the replacement filter.
4. Align the ridge on the cap with the arrow on the new filter and
turn the cap until it snaps into place.
NOTE: You can run the dispenser without a filter. Your water
will not be filtered. Simply insert the cap all of the way into the
base grille and rotate the cap until it is firmly in place.
5. Remove the covers from the O-rings. Be sure the O-rings are
still in place after the covers are removed.
6. Push the filter into the base grille. The eject button will pop
back out when the filter is fully engaged.
7. Flush the water system. See "Water and Ice Dispensers."
Water Filter Status Light:
The water filter status light will help you know when to change your water filter.
When the dispenser control panel's water filter status display changes to "ORDER," this tells
you that it is almost time to change the water filter cartridge.
Replace the water filter cartridge when the water filter status display changes to "REPLACE."
The filter should be replaced at least every 6 months depending on your water quality and usage.
NOTE: If water flow to your water dispenser or ice maker decreases noticeably, change the
filter sooner. After changing the water filter, reset the status light.
Details:
Pressing and holding RESET FILTER starts the 3 seconds countdown. Using the dispenser
cancels the countdown AND no dispensing is permitted. The number '3' blinks 3 times and the
'invalid' tone sounds 3 times and user has to release both the pad and the button and press
the button again to start it over
After 3 seconds, the BLUE WATER BARS in the Icon flash and an audible tone sounds 3
times. When the system is reset, the "ORDER" and "REPLACE" icons will disappear from the
display screen. See figure 16.
Note: Users can reset the filter status at any stage.
If you should need the complete and exact model number and manual with parts manual you will need to enter the Model Number here=> sea_breeze_132.jpg Manuals, Guides and Instructions Please rate this solution, Thanks, Sea Breeze
User manual click HERE
Apr 02, 2011 | Whirlpool 25.6 cu. ft. Side-by-Side...
Where is the water filter located and how do i replace it.
The water filter is located in the fresh food or fridge side of the appliance, at the rear - in the upper right hand corner.
To change the filter, open the fridge door, clear the top shelf and grasp the filter. All that is needed is to turn the filter to the left about a 1/4 turn for it to drop down. A few drops of water may spill onto the shelf. To install a replacement, remove the protective cover (shown as a red cap above), and position under opening for filter. Gently push upward while turning the filter to the right. The filter will pop in, and as you turn about 1/4 of the way around, it will be drawn up a small amount until seated. At this point it will no longer turn any further.
More info about the filter is below (taken from the manual).
Please rate this reply - thanks!
The water "Filter Indicator" light
• "Filter Indicator" light lets you know when it is time to change your water filter cartridge. The light
will change from green to orange. This tells you that it is almost time to change the current cartridge.
It is recommended that you replace the cartridge when the light changes to red. (see "Install the water filter" section for more information)
• If you install water filter, throw away the first six glassfulls of water filter, or until water flows clearly to flush impurities in the water supply system.
Using the dispenser without the water filter
• You can not use the water and ice dispenser without a water filter cartridge because the water line
blocks at water supply.
Ordering replacement filters
• To order more water filter cartridges, call 1-800-SAMSUNG and ask for accessory Part # DA29-
00003A or contact your authorized Samsung dealer.
Jan 04, 2011 | Samsung RS265LABP Side by Side...
How do you get the water filter out of refrigerator so you can replace it
Without knowing your particular model number, I checked and most 25 cu.ft. side by sides have the water filter in the grille. You just push a release button and it pops out. There is a cap on the filter, do not through it away as you will need it on a new filter. Also ensure the O-ring protective covers are removed on the new filter prior to installing. You can run the water dispenser without a filter as well. Here is a link to the PDF for one type of 25 cu. ft. Whirlpool side by side.
http://www.whirlpool.com/assets/pdfs/product/ZUSECARE/GS5VHAXWA_Use%20and%20Care_EN.pdf
Jul 17, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Oil leaking around filter housing on my 2002 530i
if oil filter was replaced and now leaks need to get new one and make sure you put a little oil on your finger and rub it on the rubber gasket on new filter and only tighten hand tight.
Jun 23, 2010 | 2002 BMW 5 Series
Using without water filter
The effort it would take to eliminate filter would be too much. Just leave filter in place. If new house filter is working right you should never have to replace fridge filter and your water will be double-filtered :)
Jul 02, 2008 | LG LSC26905TT Side by Side Refrigerator
Washing Machines Logo
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
