Question about GE (PSS26MSRSS) Side by Side Refrigerator
Model number GD5SHGXKQ01
Water dispenser on the door leaks at a rapid rate
  • 473 Answers
Chances are the water valve on the fridge is hanging open and letting water thru so the valve would need to be replaced (part # 2205762).  Also, if there is a reverse osmosis system on hooked up to the fridge, this can a dispenser to leak due to low water pressure which will let the valve hang open.  If you have an r.o. remove it first and hook up to regular house pressure and see if that takes care of it.  If no r.o. then replace the valve.  You can get the part at  Type in that part # and select parts from the drop down box and hit go.  Sells for $58.09.
Posted on Oct 17, 2007
When I run the water dispenser there is a water leak on the floor.
What happens to be the model number?
26173865-qoiw5swae02ur1lnfj3irvmf-5-0.jpg You very likely have a leak in the water line coupling at the bottom or top of the dispenser door where it goes through the hinge
Apr 24, 2016 | Refrigerators
I have a westinghouse side by side frig about 10 years old. Model number RS695V Serial number 34700050.The problem is water is leaking out of bottom of freezer door. I believe it is caused by a clogged...
The hose that goes to the water dispenser most likely has a crack in it somewhere inside the door. Usually the heat from the light in the door deteroriates the hose and lets water leak inside the door every time the dispenser is used.
Feb 19, 2015 | Westinghouse Refrigerators
How to fix water leak on GE Profile Refrigerator
I would look at the dispenser door for the ice (ice chute) I have seen this door not completely close and cause leaking the you are describing. This door is has a black seal, use a flashlight, from the inside of the freezer door, look for light on the outside of the door. I think you leak is there and replace the solenoid for the door to fix this issue. Good Luck, if you want more help please input a model number. Thanks
Aug 17, 2014 | Refrigerators
Water leaking from the dispenser down the face of unit. when the door is closed the water continually runs.i shut the water supply off to find the problem but i cant figure out how to remove the dispenser...
What is the make and model number of your unit? Without haveing the model number I would be pretty much guessing at what the issue could be there are alot of differences in many different kinds of refrigerators. Thanks I await your reply
p.s if you have a water dispenser on the door if you remove the front panel you will see a small switch that is most likely stuck or broken but would need the make and model number to confirm your exact unit Also with the model number I can try to find your schematic of the unit showing how the front face comes off some are screwed in an others you would use a small flat head screwdriver and pry outwards (gently)
Aug 05, 2011 | Refrigerators
Water dispenser leaks on model number KSRS25FGSS13. I HAVE FLUSH THE AIR OUT AND IT STILL HAS A VERY SMALL DRIP
Probably replace the water inlet valve on the back where the water supply comes in. Disconnect the water line to the dispenser there and see if it keeps dripping when you try the dispenser.
May 10, 2010 | KitchenAid Architect 25.3 Cu. Ft....
Water is trickling down through where the ice dispenser depressor sticks out of the freezer door. The ice is getting soft. Water is trickling down under the framing for the ice /water dispenser on the...
By not being there seeing the amount or flow rate i'm not sure but from where your saying it's coming out, It sounds like this is either condensation from behind the framing or the flap that closes when your not getting ice is not closing. This could be a broken spring but if the flap is closing. There is a heater blanket behind the framing that heats and dries the condensation out. If it goes out, water will leak out from where your describing. Try going to and enter your model number. This should bring up diagrams of your unit. See if there is a heater that goes in your model. if there is, I'm pretty sure it will be bad and need replacing.
Dec 21, 2009 | Frigidaire Refrigerators
Whirlpool side by side with ice and water in door. Water leaks from dispenser. I guess that there is a valve that is leaking but I do not know how to get to it. Help. Thanks
Do you have an in-line filter? There can be many reasons for no water supply. Line feeding the refrigerator is clogged or blocked. The water control valve that turns water to ice maker and dispenser is defective or the water filter located inside your refrigerator is in need of change. I will be here to help you go through the steps. Let me know when you are ready, Thanks, Sea Breeze
Model number 596.76592600 ? I Need this number, very important.
If I have been helpful in any way please rate me. Thank You, Sea Breeze
May 02, 2009 | Refrigerators
Whirlpool refrigerator water dispenser not working
hve u tried to clean any blockages in the unit.let me know wat other problem u face
Oct 23, 2008 | Whirlpool GS6NBEXR Side by Side...
I think I would think about getting a new one. It would cost more to fix it and then you may not get it back together so it wouldn't leak.
Dec 21, 2007 | Refrigerators
Something leaking from dispenser frame
You can remove the frame around the dispenser by pulling it gently and then you access to the screws that hold the dispenser in place. Could be a spillage behind the frame. Good Luck.
Nov 01, 2007 | GE (PSS26MSRSS) Side by Side Refrigerator
GE (PSS26MSRSS) Side by Side Refrigerator Logo
168 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
