Question about HP Pavilion dv2810US Notebook
I want to fix the error that keeps popping up before it gets worse.
When I turen on my PC an error message states, "This application has failed to start because MagCore.dll was not found."
Hardware Monitor Found a error
Since it doesn't tell you much, the first question is: does the system then work? If so, I'd ignore it until it fails.....or take it in and have a tech fix it. The problem with the first solution...ignore it....is that ignoring it s0ometomes makes it worse. The problem with the second is that, until it fails completely (i.e. gets worse) it may be difficult to track down from where it's coming.
On the other hand, if it doesn't work and stops at the error mentioned, then take it to a tech.
Jul 10, 2014 | Sony VAIO Computers & Internet
I keep getting this error: Intel® Express Installer < The application failed to initialize successfully-(E0441203). Actually when installing the mother board drivers, there has been a power cut...
The failed install has messed Windows itself its integrated installer has been corrupted.
The easiest way to fix that is to reinstall, otherwise you will gonna have to manually delete all partially installed drivers, clean the registry and perform a Repair install.
Sep 24, 2010 | Intel Computers & Internet
Wf2k.exe - unable to locate component
Download tis file from google.com then paste in C://windows/system32 then try.
Dec 03, 2009 | Computers & Internet
I can't get into my folders, applications, etc.
The error message you are getting is a result of a trojan virus that embedds itself in WININET.DLL.
Two simplest solutions:
1. If there is nothing important on the laptop that isn't already backed up, use your Dell install disks to re-install the computer.
2. If you have important files on the drive which are NOT backed up. Take it to a pro, or buy a 2.5" Hard drive enclosure, put your drive in the caddy and connect it to another computer that has an up to date virus scanner. Scan the drive for viruses and allow the virus scanner to clean all virus' it finds.
When that's done copy the files you need to the other computer and then Restore the laptop as per step 1. When it's up and running again, install a good virus scanner, then copy the files back to it from the other PC.
Hope this helps,
Chris
May 14, 2009 | Dell Latitude D600 Notebook
I have a dell latitude es400 and it keeps giving me a error messages like drwtsn32.exe-application error. The message in the box shows "the application failed to initialize properly (Oxc0000142). Click on...
You can reinstall the entire operative system with the CD that comes with your laptop, or with the restoration partition. See user's manual. This is the best way to fix error in a PC. Before restore the OS, backup your personal data.
May 14, 2009 | Computers & Internet
ERROR Window: Fail to read from dependant file.
If you are getting "Failed to read from dependent file" during installation, this is because Registry Booster is already running in the background.
If this is the case, then you should be able to see an icon in the
system tray next to the system clock. Double clicking on this icon should
restore the program window.
If you do not find it here, please right click on the taskbar and choose task
manager. In the processes tab you should find a registrybooster.exe entry. Select
it and click End Process.
Sep 19, 2008 | Computers & Internet
Counterstrike problem
not sure, sounds like you need to re-register your account on the game servers to me. look on the counterstrike forums for a solution or try to contact their tec support for a resolution.
Oct 07, 2007 | Acer Ferrari 3200 Notebook
HP Pavilion dv2810US Notebook Logo
143 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
