Question about Logitech UE Boom blue
Connects sometimes My UE Boom paired with my macbook pro out of the box and worked great. Unfortunately it has not connected consistently since. One day it will two days it won't, etc. It pairs right away to my iPhone and works great but just not the macbook pro. I reset the mac, forgot the device and repaired but all to no avail- help!
SOURCE: Logitech Play Link
everything i've read says that the pairs that come together are matched at the factory so that you can use multiple pairs in the same house without them interfering...
Posted on Jul 09, 2008
SOURCE: how to take apart
I figured out how to remove the headphone clip without causing cosmetic damage to the headphone casing. Unfortunately for me, this was after I had scratched up the casing already. Anyway, to avoid the cosmetic damage, use some kind of plastic tool, like a plastic spoon. After pulling off the headphone cushion, you will see the aforementioned 4 slots. Carefully slip the handle end of the spoon underneath one of the slots(not through them), and apply gentle pressure toward the center of the speaker. Do this for each of the 4 slots, and the tabs should easily come loose. Hope that helps.As for figuring out how to get the headphone to work, I'm waiting for that solution myself. The right headphone is out, but the left one works, none of the wires are loose, so the damage must be from my nephew being careless with the headset cable, and probably tugging on it once too often. Don't let your 15 year olds use your headsets, if they tend to be clumsy :)
Posted on Jan 11, 2009
gdlkn84as528
  • 89 Answers
SOURCE: Harmony 890 Pro will not pair with Xbox360
The RF signal is on the XBOX is used for the controllers only.
When using the Harmony 890 with a 360, you will have to use it as an IR (infrared) device. That is the only way to use a remote with the 360. If you have an extra port on your RF extender, you can place the end on the remote senor on the 360 (located under the eject button).
I set these remotes up weekly, it is a product I recommend to people all the time!
But again, the only way to setup a remote with the 360, is to use the IR port as a standard IR remote. Since the controllers run off RF, the learn function will not work, unless you already have 360 remote control to use to do the learn function.
Hope that offers some insight. This information can also be verifies at Microsoft XBOX 360's FAQ page.
Posted on Oct 21, 2009
Testimonial: "Yes! This was VERY helpful as I did not know the Xbox360 accepted IR commands. However, after configuring my remote, I'm still unable to pair. ideas?"
  • 48 Answers
SOURCE: i am trying to put my logitech cordless media
You didn't say what OS you're using, but on Windows 7 I just had to use the Add a Device option, then hit the reset button on the bottom of the keyboard and then enter the code that Windows provided.
Posted on Mar 28, 2010
Ue boom connected to pc but is not playing music... if i get lucky i get muffled sounds play back, how do i fix this
Q: What should I do if the audio is distorted or drops out on my UE BOOM?
A: Audio distorted or dropping out when streaming to UE BOOM
If you're having trouble with audio distortion or drop-outs on your UE BOOM, try these suggestions:
  • Move the audio source closer - it might be out of the range of your speaker.
  • Move away from other sources of wireless signal - you could be experiencing interference.
  • Make sure your speaker has enough battery power (connect it to a power source with the supplied adapter).
  • Adjust the volume on both the audio source and your speaker.
  • Restart both your speaker and the audio source.
  • Re-pair your device with your speaker (see, "How do I pair additional Bluetooth® devices with my speaker?").
  • If you're using two UE BOOM speakers (for Double Up), try disconnecting and streaming to one speaker only.
NOTE: If you're streaming audio content from the internet, the issue could be with the internet connection and not your speaker.
Dec 26, 2014 | Microsoft Computers & Internet
My iPhone don't work with my Bluetooth speaker system
Paired is not connected. Connecting is the next step after pairing. Then make sure that the ilive speaker is set as the dudio output device.
Dec 22, 2013 | iLive Bluetooth Speaker System
Cant connect Macbook to Bose Soundlink Wireless Music System
What I did to connect to BOSE wireless speaker to my MacBook air was go in advance settings and uncheck all three options there and then press the wireless button until it beeped--> then I was able to pair it to my laptop. Success!
Jan 02, 2012 | Bose SoundLink Wireless Music System...
Slow internet connection between Gateway Router WGR 200 and MacBook Pro running Leopard
This is related to the firmware of the router, so what you need to do here is to update the firmware of the router and that should fix the problem....
Sep 25, 2008 | Gateway Wireless-G WGR-200 Router...
Using Wing for internet through macbook pro?
You can connect and synchronize your device with the pc using bluetooth. ON your device tap
1)Start-Program-Active Sync
2) Make sure that Bluetooth on both your device & the computer are turned on and set to visible mode.
3)Tap MENU-CONNECT VIA BLUETOOTH.
goodluck
Jul 25, 2007 | T-Mobile Wingâ„¢ Smartphone
Problem with Blackberry Pearl 8100
Place the unit headset back in pairing mode by holding the call button for 1 to 5 seconds until the light turns purple. Then open the boom. Then try to reconnect .
Apr 19, 2007 | Motorola Mobility H700 Wireless Headset
Trying to pair Motorola HS850 to cell but I hold down button and light comes on but won't stay on
you hold the button with the boom closed and as soon as the light stops blinking you realease the button and open the boom, the light should remain on and steady. promt your cell phone to find it and the code is 0000
Mar 25, 2007 | Motorola Mobility HS850 Consumer Headset
Logitech UE Boom blue Logo
51 people viewed this question
Top Logitech Audio Players & Recorders Experts
Michial Gueffroy
William Covington
Level 1 Expert
Are you a Logitech Audio Player and Recorder Expert? Answer questions, earn points and help others
