Question about Craftsman 25cc Gas Line Trimmer
Problem is that I do not know where the fuel lines are conected
But my problem is that I do not know where each hose is attach to fuel filter & how the hoses to the bulb is connected. Wher can I get a diagram to show me where the fuel line are all connected properly or can someone tell where all fuel lines are connect from the fuel tank to the bulb and carburator. tahnk you
  • Miguel Guerra May 19, 2009
    I do not understand half of the solution. wich fuel hose goes to the bulb and wich one goes to the filter their is a thin hose and a tick hose Thank you
  • flb0267 May 23, 2009
    my fuel lines have dry rotted and i do not know where they go. is there a drawing for the installation?
  • 12 Answers
Your carb has two hose connections, one is the inlet and the other is the return. The inlet (suction side) won't have any barbs on it (smooth brass pipe). The return side will have barbs to keep the hose from popping off if the line is plugged and is probably plastic. The inlet side should connect to the fuel filter that will be dangling from the hose inside the tank. Make sure the filter is free to move around the inside bottom of the tank
Posted on May 18, 2009
  • Kal Schofner May 20, 2009
    You can determine which hose goes where by purchasing short lengths 18" of each tube size.
    1. Attach the tubes to the carb connections.
    2. Place a small quantity of clean gasoline into a clean empty water bottle and place one of the hose ends into the fuel.
    3. In a second empty cup place the other hose end.
    4. Squeeze the primer bulb. If gas flows from the full bottle to the empty one then you have found the inlet or filter side (it's in the gas)
    5. If it blows bubbles, switch the tubes and try again.
    6. If gas doesn't flow you have a problem with the primer and/or carb.
    Please don't flag my response as inappropriate as that indicates that I cursed you out or was rude to you in some way.
  • Kal Schofner May 21, 2009
    I can provide better information if you can provide the weedwacker part number.
    Kal
Fuel line problem at fuel filter conector, 1994 Buick Century
I know the feeling well when this happens. I to did the same as you and also did the clamp, but found the best way was to yous a crimp tool for fuel lines and its not come off since its like the tool to put brake lines on to the calipers and then you put the rubber hose onto it and using a fuel line clip to hold the rubber in place. has lasted the last 5 years now with no problems.
Jan 14, 2014 | Buick Century Cars & Trucks
1950 poulan
Open fuel tank, pour out fuel on clean flat area (away from any flames or spark sources) then check the 2 plastic hoses inside. One should have a fuel filter on it's end. The plastic these lines are made seams to disintegrate so, filter may not be attached and lines may be broken off. Replace them.
Mar 05, 2013 | Poulan 14" Chainsaw
I had to replace the fuel lines on my Craftsman model 358798940 leaf blower and i'm not sure how they hook up on the carburetor, 1 line runs from the fuel tank fliter to the carburetor and the other...
The fuel hose from the tank with the filter on the end goes to the main fuel inlet on the carb, this is the conection closest to the alloy pump cover held with a single screw, the other conection on the carb has a hose to the short conection on the back of the primer ( the suction side ) the longer conection on the primer ( pressure side ) has a hose back to the tank, this pipe just pushes into the top of the tank, just remember the primer pulls fuel from the carb, into the bulb, and back to the tank, not the other way round.
May 31, 2011 | Garden
PowerMac by McCulloch PM425AV-18 38cc. I have replaced the line from the fuel mixture tank to the primer bulb & replaced the primer bulb. Now the chainsaw won't keep or looses the prime. Now...
Are you sure you have conected the pipes the correct way round, the fuel hose from the tank with the filter on the end goes to the main fuel inlet on the carb, nearest to the alloy pump cover, the other conection off the carb goes to the shorter conection on the back of the primer, the longer pipe on the primer goes back to the tank, just remember the primer pulls fuel from the carb, into the bulb, and back to the tank.
May 15, 2011 | McCulloch 16 Inch Gas Chain Saw MCC1635AK
How to conect fuel lines to poulan chain saw 2375 Le
The hose coming from the fuel tank with the filter on the end goes to the fuel inlet on the carb, this is the conection closest to the alloy pump cover held with a single screw, now take a hose from the other conection on the carb to the shorter ( suction side ) conection on the back of the primer, take a hose from the longer conection ( pressure side ) on the primer back to tank, this just pushes into the tank, just remember that the primer pulls fuel from the carb and dumps it back to tank.
Apr 14, 2011 | Poulan Wild Thing 2375 18" Gas Chain Saw...
My Homelite backpack leaf blower runs until tank is 1/2 full
thats what it is try opening the gas lid look inside to see where the fuel line lies if its up high them try pushing it down to the bottom
Nov 13, 2009 | Homelite Consumer Products Backpack...
I need info on a Poulan Pro 445 fuel line routing
I'm so confused. This is reported as a Poulan and McCulloch pole saw, which one? Is it a pole saw? That is the only 445 Poulan I can find. It is reported as an electric but has a fuel routing problem.
If it is a Poulan Pro gas pole saw it is here: PP445 Gas Pole Pruner
The fuel system routing is terrible, but it is all there is.
Fuel Routing follows:
Tank to carburetor (hose in tank with filter on free end)
Carburetor to primer (primer draws fuel from the tank through the carb)
Primer to fuel tank (returns any excess fuel to tank when pushed) HTH
Lou
Oct 11, 2009 | McCulloch 10" Electric Pole / Chain Saw
Fuel filter at foer escape 2001 4w chenging
start the engine  open the hood and remove the system fuse
the engine will stall, the pressure is now relieved
the fuel filter is in front of the fuel tank, driver side
wear gloves/saftey glasses and have a fire extinguisher available (who knows!) the filter will have 2 hoses attached at either end. white/yellowish clips attach these hoses. feel for the top of the clip and push the 2 ends in and down. you may have to use a screw driver to pry the bottom of the clip as well. pull the bottom of the clip down, it will not come out of the coupling completely. repeat for both lines, pull lines firmly off of filter. unscrew filter from hose clamp. approx 6-10 oz of fuel will spill from lines and filter. you should use a pan. install new filter, in same direction as last. insert new clips into coupling, discard old. clip on "out" side may be reused if an R clip. tighten clamp on filter, attach hoses. push in clips to lock. inspect for leaks, wipe entire area clean of fuel. insert fuse and attempt to start. Cycle the ignition to run and off three times before starting to pressurize the fuel line. Good luck and hope this helps.
Jun 22, 2009 | 2001 Ford Escape
Fuel filter in gas tank is attach to hose and connect to ?
The longest, and sometimes smaller in diameter of the two fuel lines, goes from the carburetor to the bottom of the tank. Leave enough slack in this line so that the filter that attaches to the end will rest comfortably at the bottom of the tank.
The other fuel line goes from the primer bulb to just inside the tank, (about an inch). make sure that you get the right size fuel lines. The plastic coupling goes on the end of this line, inside the tank. This keeps the line from pulling out of the tank.
(HINT): When feeding the lines through the tank holes, cut the lines at an angle. They will feed much easier into the holes. You can than cut them off square, once you know that you have enough to work with.
If you need further assistance, just let me know.
Jim
Jun 16, 2009 | McCulloch Garden
Poulan 2150 w/ walbro wt324 carb fuel line reassembly
the fule line that comes from the filter/ pick up will go straight to the nipple usualy the one closest to the middle of the carby.
the other hose comes from the carby to the in or **** side( punp it you can feel it)of the primer and then goes to the tank that is the return/ prime, nothing is conected to it in the tank. if you have the carby one the wrong way around it will not prime. just swap them over..
Nov 24, 2008 | Garden
Craftsman 25cc Gas Line Trimmer Logo
575 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
