Question about GE Quiet-Aire Ductless Heat Pump Split System AS1RD09AA0/AS0RD09AA0
A/c with heat pump. only runs by-pass mode no cool
Ductless, 24,000 btu. static charge ok, only operates in by pass mode. solenoid very hot. after loosen screw n slide to side it still remains in by pass. temporarily open two leads from wall to compressor operate no change power down reposition solenoid and make connection with signal wire and restart same problem. Suggestions?
    Guru:
  • 462 Answers
If you remove the coil from the rev valve it will burn out the coil. So do not do this. Now if the charge is low (static charge to me means at rest or at start up with no load) the rev valve cannot reverse its self. It has to have enough refrigerant to make the reversing valve switch possession
By by pass mode do you mean in the heating mode?.
If this has helped you any please rate me as high as you can if you need more information please post and I'll try answer more, but give me as much information as you can. type of refrigerant, both fans operational, clean filters, all ducts open, what kind of heating electric or gas, your locality : coastal, inland, humidity....
Posted on May 16, 2009
  • Farley Redfield
    Farley Redfield May 16, 2009
    Oh yes the compressor and other motors have to be running before it will reverse also. I didn't know if you knew this or not. Just sitting the only thing that will happen ( assuming it is working properly) is the coil on the rev valve will energize and that's it. At least on all the standard made heat pumps that are modern. In older models the reversing valve operated in the heating mode on some manufactured. I believe all now operate in the cooling mode.
My gree mini split 2400 heat pump air conditioner does not turn off at the set temperture when cooling
I am not sure about your specific model. However most A/C units I have worked with have a fan switch. The switch allows you to choose to have the fan on all the time or only when the unit is cooling. Some of these switches are behind the front panel, behind the panel or out in the open it should be close to the other controls. Hope this was helpful.
May 24, 2014 | Gree 24,000 BTU 18 Seer Ductless Mini...
Senville mini split displays a "defrost" symbol????
It's a heat pump and that is how they work. But it shouldn't be cycling so much unless you live in Minnesota? The colder it is outside the more chance that the outside coil will freeze so it will go into defrost. It may be low on charge or have leak as well. Call a tech to verify.
Apr 13, 2014 | Senville 18000 BTU Ductless Air...
I have a LG minisplit (indoor unit LSN122HE /outdoor unit is LSU122HE) it cools great dehumidifies also and has for 3 months of summer. However its cold now and it will not heat. It runs for a min out
That's an inverter series motors... the outdoor fan motor is on an ambient controller to maintain pressures when cold outside in air conditioning mode, but not in heat...only defrost when needed. Check the settings on the outdoor board for defrost timing
Dec 02, 2013 | LG LSN122HE / LSU122HE - 11,500 BTU 13...
Wont work when on heat
check to be certain the reversing valve solenoid is wired properly and working
Nov 17, 2013 | Commercial-Cool 24,000 BTU s AC Heat/Cool...
Lg lsu186he unit runs for a while then go's into defrost
normally this happen because the UNIT is to BIG for cooling your ROOM or House .In other words the BTU is OVER calculated.
You must get support from the supplier manufacturer.
God bless you
Oct 08, 2012 | LG LSU186HE 17,800 BTU Ductless SingZone...
GE Quiet-Aire Ductless Heat Pump Split System AS1RD09AA0/AS0RD09AA0 Logo
82 people viewed this question
Top GE Heating & Cooling Experts
ray gallant
Jay Plesset
Are you a GE Heating and Cooling Expert? Answer questions, earn points and help others
