My 2002 chevy Silverado interior lights work intermitantly but wont stay on. What do I need to do to solve this problem?
SOURCE: Motor starts but dies as soon as it goes to the run position.
you burned out body control module. will need replacement
SOURCE: 2002 2500 Silverado tailgate handle will not release catches
You will need to remove the trim piece the is under the release handle. Be carefull those things tend to break the little tabs that hold them on. Anyway pop (pry) it off with a screwdriver. Once it is off you can see that the little clips that hold the rods to the handle assy are broke. These clips are color coded. Most likely yellow or green. You might be able to get them at say Pep Boys or some place like that but they might make you buy an assortment package , then you get clips you will never use. Good luck, hope this is helpfull.
SOURCE: 2003 Chevy Silverado Interior rear veiw mirror compass and temp
sounds like a fuse blew if both went out check fuses first
SOURCE: 1999 Chev Silverado Door Light Switch
the actuator for the dome light is actually located inside the lock mechanism. Have you checked to make sure the dome light override button is in the out position?
SOURCE: How do I remove the
REMOVE PANEL SCREWS, PANEL GOES UP! NOT OUT, IT WILL BREAK IF YOU PULL STRAIGHT OUT!!
