Question about Stanley F33PT Paper Tape Framing Nail
Bostich nailer N79WWblows continous air
The trigger does not engage and it will no longer shoot nails . Could it be the trigger valve or more? Thanks
  • 154 Answers
If the nailer is passing air from directly out of the trigger valve, it must be replaced (P/N-TVA11). If it is passing air from anywhere else, (eg back cap or front ) it needs an O-ring kit (P/N- ORK11)
Posted on May 28, 2009
Nailer is shooting air out of trigger, is not releasing brad
Sounds like the head valve. Remove the head cap take out the head valve, clean, re-fit and give it a few drops of air line oil. Then give it a try. Good luck.
Oct 19, 2014 | Stanley Bostitch 18 Gauge Brad Nailer 1 -...
Nbosb bostich nail gun air is leaking out trigger how to fix?
I am not familiar with that model number, however if your nailer has a round plastic trigger valve, it should be easy to replace. Most bostitch nailers use a TVA6 valve that sells for about $20.00. Better to replace the valve because, if plastic, the firing pin in the valve becomes very worn/loose over time and orings will not work. Easy to check. Remove the trigger and try moving the firing pin from side to side. If it moves, replace the valve. If your gun has a metal threaded-in valve, remove the valve and replace the orings with generic. Usually 2mm on the pin and 5mm on the inner spool. Local bearing company can measure them for you. Good luck.
Aug 09, 2014 | Air Tools & Compressors
Internal air leak won't pressure up
Sounds like the trigger valve is bad. If the air is leaking out of the trigger you can buy a kit and replace it. Try eReplacementParts com or your local Bostitch service store. It's really simple to change, check out this site for step by step, How To Replace The Trigger Valve On Bostich Nail Gun How To Guides DIY... OEM Replacement Parts DIY Repair
Mar 17, 2014 | Stanley Bostitch SB1850BN 18Gauge Brad...
Nail gun will not shoot a nail
Check the safety trip make sure it is pushing back far enough. If it doesn't then it won't do anything. When it was fine just moments earlier.
Feb 05, 2013 | Dewalt D51822 Clipped Head 2Inch to...
My paslode air framing nailer model 5350-90s is loosing air out of the trigger valve when I press on the trigger and the nail does not fire. What is the problem ?
Sounds like a bad O ring. There are rebuild kits you can get with a new set of O rings. Or you can have it done for about $30-50.
Jun 09, 2011 | Heavy Duty Stanley Bostich Heavy-duty...
Air leaks around green cylinder at trigger area and nail plunger will not retract. this is a stanley bostich rn45b nailer
Your nailer uses a trigger valve (part # tva6 cost about $20) and is sold at www.bostitch.com or generic valves sold on ebay . If you have a source for orings, you could try to repair the valve. Remove the roll pin that holds the trigger to expose the tva6 valve. There are roll pin/pins that hold the valve in just above the valve in the body. Remove these pins and apply air pressure to gun to pop-out the valve. Use caution when you do this. Remove nails, lower pressure to gun and use glove or rag to catch valve because it could come out with force. With tva6 valve in hand remove two pins that hold valve together and remove inner plunger. The middle oring on plunger is cause of leak. Try using an oring about same size as the broken seat. It must fit pretty tight to work. If you had a small leak it could be that the firing pin orings fit too loose or just too worn. Use silicone lube or oring lube on the orings and the valve port. Good holidays.
Dec 02, 2010 | Stanley Bostitch Rn45b1 Industrial Coil...
Must pull the trigger every time to shoot a nail, should be able to hold trigger and tap where i want the nail.
On some models the contact fire is not available. There is a flap that is under the actual trigger. When you press the safety in, it engages this little flap which allows the trigger to be engaged. As soon as the safety comes up this little flap falls back down disengaging the trigger.
There is an optional trigger assembly that you can put on this nailer. You need parts 174299 and 174300 to make this gun a contact nailer.
Sep 10, 2009 | Stanley Bostitch HP118K 23 Gauge Headless...
Air leaks arond trigger when depressed, but no nail fires.
Where does the air leak out from? If it leaks from the trigger DeWalt makes a trigger valve assembly part # 641006-00 list 8.89 BUT if it leaks from other areas we have to look into it deeper. If it is just the trigger valve let me know and I will give you instructions how to remove and install the new one.
Feb 05, 2009 | Dewalt Round Head Framing Nailer D51845
I have a bostich framing nail gun and as soon as i hook my air hose up to it the air comes directly out through where the driver is, dont even have to pull trigger, can u help, need gun operating to make...
The o-rings need to be replaced and/or the trigger assembly is defective. Look around at local lumber yards for a "Bostich days" promotion. Often with the purchase of a box of nails, the Bostich rep will "service" up to 2 guns for free. If this is not an option for you because of time, you can purchase the o-ring kit and replace the rings yourself. This is not a difficult repair. Also, be sure to lubricate the guns with pneumatic oil frequently as this will keep the rings lubtricated and prevent them from drying out and leaking.
Hope this helps,
Dan
Nov 30, 2008 | Stanley Bostitch F21PL Nailer
Stanley F33PT Paper Tape Framing Nail Logo
227 people viewed this question
Top Stanley Air Tools & Compressors Experts
John Trevino
yoopertech
Joe Garcia
Joe Garcia
Are you a Stanley Air Tool and Compressor Expert? Answer questions, earn points and help others
