Question about NEC VT470 Multimedia Projector
Lamp not working
I read the solution posted on 8/30/07, but my remote does not have a help button.  It's only unique buttons are "Source", "Pic-Mute", and "Aspect."  Will one of those work?  Also when should I press and hold the button? While the green light is lit? After the red lights start flashing? While the unit is off?
I had the same questions and decided to push power on and hold the help button as soon as soon as the power light came on. 10 secs later and the light was working again! Try grabbing a different NEC projector's remote, maybe it will have a help button.
Posted on Mar 20, 2008
Soo I accidentally pressed the USB button on the element controller and I have no idea how to take it off again sooo...
The USB button is a dedicated shortcut key to select the USB source. To change to another input, press the Source button repeatedly until you have the desired source selected and then press OK. (On the Element ELEFW3916 TV, it's the lower side of the button above the power button on the side. On the remote, the source button is between the volume - and channel down buttons. That puts it below the mute.)
I hope this helps. Please post a comment with the model of your Element TV, if you don't see an Input or Source button on the TV or remote.
Jul 17, 2017 | Element Televison & Video
Lamp reset LG RD-JT40
Try to do this, press the ENTER button on the TV and the MUTE button on the remote at the same time. After 5 seconds the screen should come up and it will read "Lamp use time...Total lamp use time ....lamp reset" Press the center button on your remote (the circle button right in the middle of the four directional buttons) and you will be reset to -0- again. Your orange light should now be off.
Good Luck.
Jan 26, 2008 | LG RD-JT40 Multimedia Projector
Reset lamp timer lg projector model BX-401C
Try this, it works on older LG TV models:
Put the projector on. While holding down the Menu key on the projector, press and hold down the Menu button on the remote. Keep both buttons pressed for a count of at least 5 seconds.
When the Service Menu pops up, release the Menu button on the remote control first and then the one on the projector after.
Now you're in to the service menu, you need to find out which button on the remote brings up the Lamp Timer Reset function. This is where you're going to have to do a bit of trial and error. With the TVs, the remote button was the Mute key. There isn't a Mute key on the projector remote, so try the Lamp key first. If that doesn't work then try some other buttons. Here's the method.
While holding down the Enter/OK on the projector, press and hold the Lamp key for five second. If this works then the lamp timer reset box should appear. Release the remote button first, followed by the unit button.
Press Enter/OK on the remote to reset the lamp timer. If there's an On Screen Prompt to confirm, press Enter again.
Press Exit on the remote to come out of the menus.
Warning: Don't reset or change any other functions. The service menu isn't the place to be tinkering around with stuff you don't understand.
Aug 31, 2014 | Office Equipment & Supplies
Can the service menu for the LG 52sz8d dlp tv be accessed from the orig remote not the service remote just installed new lamp and tv was working fine for 1 week now the lamp indicator light comes on and...
One possible solution to access the service menu on LG tv's is as follows with steps 1 - 4:
1. With the TV on, press and hold the MENU button on the TV front panel.
2. While holding that button, press and hold the MENU button on your remote.
3. Hold both buttons for ~5 seconds until the service menu comes up on the TV.
4. Release the remote MENU button first, then the TV MENU button.
If you are looking to reset the lamp indicator then continue with the following steps 5 - 11:
5. Press and hold the ENTER (or OK) button on the TV front panel.
6. While holding that button, press and hold the MUTE button on the remote.
7. Hold both buttons until the Lamp Life Hours show up on your TV screen.
8. Release the MUTE button first, then the ENTER button on the TV front panel.
9. Make a note of the lamp hours if you want.
10. To reset the lamp hours, press the SELECT button (the one between the four arrow keys with two concentric circles on it) on your remote.
11. It will ask you to confirm the reset--press SELECT again to confirm.
To verify you've reset the hours, you can repeat steps 1-9 above and then just press the EXIT button on your remote.
Hope this helps. Regards, James.
Apr 22, 2010 | LG 52SX4D 52" HDTV
Resetting lamp hour meter on panasonic tv
press volume down on tv and pip or split on remote
Nov 19, 2009 | Panasonic PT-56DLX25 56" HDTV
Installed new lamp/how to reset the lamp hour meter on samsung (HL-S4666W)
Here is the procedure for resetting the lamp timer.
This is a quick reference guide to show you how to reset your Samsung DLP TV’s lamp hour meter or hour counter. Resetting the counter is a very simple procedure.
Begin with the TV powered off.
Point your remote towards your TV.
Press:
Mute + 1 + 8 + 2 + Power.
Your TV set should now say “Loading Factory”.
Browse down to “Option” then press Enter (or the right cursor button).
NOTE: The Mute+1+8+2 buttons needs to be pressed down consecutively and fairly quickly. If your TV does not enter the service menu after using this combination, you can substitute MENU instead of MUTE. This seems to work for some sets. Also, the right cursor arrow also acts as the ENTER button, so try it if you’re having difficulty with the ENTER button.
To exit the service menu, hit press the EXIT button or just turn off your TV (remember not to turn on your TV immediately afterwards!).
I hope this information allows you to resolve this issue.
If I have helped you, please help me, and rate this suggestion the highest FixYa rating. (Two Thumbs Up) If you cant rate this post with the highest rating, then please comment to this post and I will try to help you further.
Jun 01, 2009 | Samsung HLP4663W 46" Rear Projection HDTV
Lamp red lght on
Did this work?
Resetting lamp hours on LG DLP TV
5a. Press and hold ENTER on the TV front panel (the TV will re-enter the menu; keep holding ENTER while you press and hold MUTE on the remote. After approx 5 seconds, the lamp life counter will appear).
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Oct 06, 2008 | LG 52SX4D 52" HDTV
Reseting lamp counter (LG)
Make sure the TV is on and:
1) Press and hold the Menu button on your TV SET
2) Press and hold the Menu button on your REMOTE CONTROL (at the same time)
3) Continue holding BOTH buttons down for 5 secconds or until the Service Menu pops up
4) Release the MENU button from your REMOTE CONTROL, then release the MENU button from the TV Set.
5) Press and hold ENTER (or OK) on the TV Set, then:
6) Press and hold MUTE on the REMOTE CONTROL (while still holding down the ENTER button on the TV SET
7) Holding both buttons down should lead to the Lamp Life Hours screen to pop up.
Release the MUTE button the REMOTE CONTROL, then release the ENTER (or OK) button on the TV Set.
9) Come back to this blog and post your HOURS on our site
10) Now press SELECT, then SELECT again to confirm the reset of the counter
** If the procedure above does not work swap steps 5 & 6.
** For a few special models (including 44SZ8D), you might have to change step 5 to:
5a) Press Enter on the TV Set to enter the Position Adjustment Screen
5b) Press and hold Enter on the TV Set (the TV should go back to the main Service Menu, continue holding Enter) and now also hold down the MUTE button on your REMOTE CONTROL. After about 5 seconds, your Lamp Life Counter should pop up.
Jun 30, 2008 | Televison & Video
Replacing lamp in rear projection tv
To do this, press the ENTER button on the TV and the MUTE button on the remote at the same time. After 5 seconds the screen should come up and it will read "Lamp use time...Total lamp use time ....lamp reset" Press the center button on your remote (the circle button right in the middle of the four directional buttons) and you will be reset to -0- again. Your orange light should now be off.
May 09, 2008 | LG RU-52SZ30 52" Rear Projection...
Projection lamp timer reset
I called 1800 211 PANA and they walked me through resetting lamp.
press recall and Volume- till solid screen shows, then hit recall till you see codes on top left, then hold volume- and mute(same time) till all codes return to 000000000000, then hit exit. turn off tv and check to see if it works
Jan 21, 2008 | Panasonic PT-50DL54 50" Rear Projection...
NEC VT470 Multimedia Projector Logo
291 people viewed this question
Top NEC Office Equipment & Supplies Experts
jasbo
jasbo
Are you a NEC Office Equipment and Supply Expert? Answer questions, earn points and help others
