Question about Whirlpool Inglis IP4400 Washer
Selection dial has come loose.
Inglis Heavy Duty 'Superb' washing machine.
Selection dial has seperated from the knob. How do you re-align them?
Dennis
Found I could unthread the knob (counterclockwise), then removed the selection plate, and its adapter. Noticed that it was originally welded to the plate, via 3 palstic studs. I was able to determine that the two plates would ONLY align in one postion, and then was able to ReGlue them together, courtesy of No More Nails. All is well in Washerville again.
Posted on May 17, 2009
How do I align my Dial to my GE Washing Machine Timer
Most GE knobs and dials have either a flat spot or notch on the knob that aligns with a similar spot on the shaft. They can only go on one way.
Oct 20, 2014 | General Electric WH11X10033 Dial Assembly
Kenmore Heavy Duty Series 70 washing machine gets stuck in cycle.
Either your timing motor has broken or the gears that it drives are stripped. The timing motor is easy to replace but if the gears are stripped you will need a whole new dial assembly.
May 09, 2017 | Kenmore Washing Machines
I have a 15 year old Kleenmaid Heavy Duty washing machine, the wash selection knob has broken, where can i get another in the Newcastle area. Second hand will be fine. Lyn
IT IS TIME TO BUY A NEW WASHING MACHINE. IT MAY COST MORE, BUT TRUST ME, YOU WILL FEEL BETTER KNOWING YOU BOUGHT A NEW WASHER. THE KNOB ON THE OLD ONE THAT IS BROKEN, CAN BE REPLACED, BUT I DON'T KNOW HOW. GOOD LUCK.
RODNEY
May 14, 2009 | Washing Machines
Cold water won't stop
You need the water valve to be replaced.:)
Mar 09, 2009 | Whirlpool Inglis IP4400 Washer
INGLIS WASHER SUPERB AGITATOR DOES NOT WORK
sorry not real solution as I am not familiar with that design but recommend replacing machine.
Jan 31, 2009 | Whirlpool Inglis IP4400 Washer
Inglis Superb 2 washer,
Inglis cloths washer Model L038001 will not drain or agitate
Jun 25, 2008 | Washing Machines
How to remove the washer cycle selection/start-stop knob on a Whilpool Heavy Duty Thin Twin stacked washer dryer
I believe the selector knob on a Whirpool just has to be turned counter-clockwise with the selector pushed in. It will spin off the shaft and then the outer indicator dial will pull off. The shaft also has a keyed slot that will only allow the dial to be removed and installed one way, so there should be no question as to how it goes back on.
Was there a reason as to why you are removing the washer selector knob? If this is a simple matter of replacing a broken water temperature selector, you shouldn't have to remove any of the control knobs to gain access to the selector. The entire front panel comes off by removing the screws holding it in place. That way you can access the broken selector from behind the front panel much easier. Just remove the panel right above the washer top (under the dryer) and it should expose the front panel mounting screws. Remove these screws and the front panel comes off. Just make sure the unit is unplugged before you begin. I hope this helps you. Let me know if you need further assistance.
Apr 22, 2008 | Whirlpool LTE6234D Top Load Stacked...
Whirlpool Inglis IP4400 Washer Logo
117 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
