Question about Sony KP-53XBR200 53" Rear Projection Television
No powering up
Red standby light blinks twice each time it blinks. will not turn on at all.is there a code for 2 blink red light i should know about.Is there a board I can replace to resolve this problem? BruceB.
  • 3 more comments
  • Bruce Baier May 16, 2009
    my red light blinks with not picture. Here is a post I found that explains the problem.
    2 blinks is +B OCP protection. The manual states "Short circuit of power supply system in each circuit." and "Goes to the standby mode. Short circuit of +B line"
    How do I fix this error? Can I replace a board or power supply or ??? to fix this? Thanks, Bruce B.
    Thanks Charlymonty! I appreciate your quick response. Bruce B.
  • Bruce Baier Jun 14, 2009
    I replaced the "G Board" it did not solve my problem. The red light still blinks twice and the set will not power up.
  • Bruce Baier Jun 16, 2009
    Here is the original solution I got. I bought and installed this board, but it did not fix the problem. Thanks, Bruce
  • Bruce Baier Jun 18, 2009
    Thanks. I will need to see if it is worth spending more $'s. It looks like a technician is the next step. Bruce B.
    Scholar:
  • 95 Answers
2 times red light indication:
, Diagnosis: B overcurrent(OCP). Possible causes: H. OUT (Q8024) is shorted. (D board), +B PWM(Q8035, 8038) is shorted. (D board) Symptoms of the problem: Power doesnot come on, Load on power line is shorted.
remedy:
You will either need a repair technician or you can delve into the set yourself if you are a technician. You would be looking for bad caps, fuses, bad solder joints on the main power supply board.
it would come around 100$ ,even if we try to solve at a point the technicians does the work neat and clean for your valuable tv.
prevention:
first try using a stabiliser,cuz if the current is not stable your board will short every time
Posted on Jun 16, 2009
  • 74 Answers
The replacement of power supply board is needed.. i had the same problem..
if you cant afford a tv repairman to go visit you. try going at the nearest electronic store.. .but man .. that will be a hard work.. .you got a good tv there.. n.n
Posted on Jun 14, 2009
    President:
  • 987 Answers
2 blinks is +B OCP protection. The manual states "Short circuit of power supply system in each circuit." and "Goes to the standby mode. Short circuit of +B line"..
you have to replace the power supply board ...If you hire a tech, you can at least point him in the right direction. You would be looking at $150 and up since this TV would require an in-house visit.
  • 3,741 Answers
Yes absolutely correct.you will have to replace the power supply board.its the power supply board problem. to replace the power supply board is not a difficult job as it is just fitted by some screws and some plug in wires that is easy job.but the tough job is to open the tv to reach till power supply board. the part number of power supply board is A-1316-400-A you can get this board at  http://www.partstore.com/Model/Sony/Sony/KP53XBR200.aspx
click the link directly and the cost of board is $198. but if you are not familiar with opening the tv then its quite advisable that you get it done by a local tv reparing technician.as it will be safe .
Please do rate the solution.Thank you for using fixya.keep updated. thanks
Posted on May 16, 2009
  • 483 Answers
Hi Bruce,
When power on the set, the green light blinks about 8-10 times before the light stays lit. Then the green bars appear. Looking at the service manual, it would seem to be an issue with the GI/GK board. Perhaps there is a connection problem betwwen the B1 and GI/GK boards. I did remove the B1 board and reattach. but the problem remains. Is this a direction I should follow (remove the GI/GK board and inspect?
My 2 cents,
Thanks
Fame !
My Sony Bravia TV - Model #: kdl-52z5100 no longer powers on. There's a red light that blinks twice whenever I attempt to power it on. Please help
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://electro-medical.blogspot.com/
Jul 30, 2016 | Sony KDL-52Z5100 LCD TV
Two red blinks of the power red light
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit stage inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power led, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating, to many popular brand TVs and other devices. Viewing it in "Mosaic" will make surf easy.
Blinking codes details to many popular brand TVs are given
Mar 14, 2014 | Philips 32PF7320A 32 in. LCD Television
Turns off itself And the red light blinks twice
Blinking codes details to many popular brand TVs are given.
Feb 09, 2014 | Sony KDL55HX800 55 in. TV
Sony TV turns off immediately after turning on
Two blinks - B+ over current protection (OCP), unit goes to the standby mode then displays the 2 blink fault. Could be a short in the power supply of any of the circuits. Check this link to get more details about Sony Blinking codes.
Jan 13, 2013 | Sony FD Trinitron WEGA KV-20FS100 20" TV
Looking for a sky remote control code for beko.
Hello
The three digit Sky remote code for Beco TV are:
514 398 065
Four digit code is:
0125
1* Turn your TV and SkyHD box on and press tv on your remote control.
2* Hold down select and the red button together until the red light on your remote
control blinks twice (this is after about two seconds).
3* Press tv again.
4* Key in your TV's brand code. The light on your remote control blinks twice.
5* Press standby on your remote control.
If your TV switches off, press select.
The light on your remote control should blink twice.
If your TV does not switch off, press tv, then press standby.
Repeat the sequence of pressing tv then standby until the TV switches off,
then press select.
If the light blinks three times, your remote control has checked all the possible
settings for the code you used. Check you have the right code and start again
at step 1.
*6 Turn your TV back on and press the tv guide button on your remote control.
The TV Guide screen appears, meaning the remote control settings have
been reset.
Aug 12, 2011 | Televison & Video
Hi i have lost instruction manual for my total remote urc 11-4110 b02 Universal Remote could you tell me how to code it to tv manually please
@font-face { font-family: "Cambria"; }p.MsoNormal, li.MsoNormal, div.MsoNormal { margin: 0cm 0cm 10pt; font-size: 12pt; font-family: "Times New Roman"; }div.Section1 { page: Section1; } SET UP
TV
The Search Method
If your device does not respond to the TOTAL CONTROL after you have tried all the codes listed for your brand, try searching for your code. The Search Method allows you to find the code for your device by scanning through all the codes contained in the memory of the TOTAL CONTROL.
To search for your TV code:
1 Switch your television on (not on standby) and aim your TOTAL CONTROL at your TV.
2 Press the TV key on your TOTAL CONTROL.
3 Press and hold down SET UP until the red light blinks twice. (The red light will blink once and then twice)
4 Press 9 9 1. The red light will blink twice .
5 Now slowly, alternate between POWER and TV, over and over, until your television turns off. You may have to press these keys many times (up to 150!), so please be patient.Remember to keep pointing the TOTAL CONTROL at your television when you press these keys.
6 As soon as your television turns off, press SET UP.
The TOTAL CONTROL remote should now be ready to operate your device. Turn your device back on and try all the remote’s functions to ensure they are working
properly. If some of the TOTAL CONTROL’s commands are not operating correctly, try the search method again. You may be using the wrong code.
Once you have Set-Up your TOTAL CONTROL, you can blink back your SET-UP CODE for future reference.
Example: To blink out your Television code:
1 Press TV once.
2 Press and hold SET UP until the red light blinks twice (The red light will blink once and then twice).
3 Press 9 9 0. The red light will blink twice.
4 For the first digit of your four-digit code, press 1 and count all the red blinks. If there are no blinks, the digit is "0".
5 For the second digit, press 2 and count all the red blinks. If there are no blinks, the digit is "0".
6 For the third digit, press 3 and count all the red blinks.
7 For the fourth digit, press 4 and count all the red blinks. If there are no blinks, the digit is "0". Now you have your four-digit code.Make sure you write your Television code for easy future reference.
Aug 12, 2010 | Televison & Video
How do you tune Sky+ remote into Sony KDL46W5710 Television
The Sky+ remote should automatically default to Sony TV's. Leave the batteries out for a few minutes and try again. The Code for Sony is 0000.
Or try this :-
With TV and sky box on.
Press the 'TV' button on the remote.
Hold down the 'select' and the 'red' button (of the four coloured buttons) together, until the red light on the remote blinks twice. (takes 2 seconds)
Press the 'TV' button again.
Now enter four zeros, the red light on the remote should blink twice.
Press the 'standby' button (top right).
If the TV turns off, then press 'select' and the light should blink twice again, job done.
If the TV does not turn off then press 'TV' followed by 'standby' again.
Alternate pressing 'TV' 'Standby' until the TV turns off.
When it does, finish by pressing 'Select.
Check the red light on the remote, if it blinks 3 times, then it has run out of options for 0000.
Dec 19, 2009 | Televison & Video
How do i key in code for digibox
TO PROGRAM THE remote USING THE 3 DIGIT CODE:
1. Turn on the TV receiver
2. Press TV on the Sky Remote Control
3. Hold down SELECT and the RED buttons together for approximately two seconds, until the RED LED on the Sky remote blinks twice.
4. Enter three digit code from list for the receiver (early versions now flash twice).
5. Press select to enter code structure (the LED will flash twice if a valid code has been entered).
6. Now press the STDBY button and test other functions.
Repeat if necessary until a code is found that works most common functions.
TO PROGRAM THE remote USING THE 4 DIGIT CODE:
1. Turn your TV on.
2. Press tv on your Sky remote control.
3. Hold down select and the red button together for about two seconds, until the red light on the Sky remote control blinks twice.
4. Press tv on your Sky remote control again.
5. Key in the four digit code for your brand of TV. The light on the Sky remote control blinks twice. If the light blinks once only, recheck the code for your brand of TV and start again at Step 1.
6. Press the standby button on your Sky remote control. If your TV switches off, press select. The light on the Sky remote control blinks twice (code stored). If your TV does not switch off, press tv, then press the standby button. Repeat this (press tv, then standby) until your TV turns off, then press select (stores code).
If at this point the LED on the Sky remote control blinks three times then all possible codes for that make of receiver have been checked. Repeat from step one, ensuring that you enter the correct manufacturer code.
At the end of the sequence, if you see the TV Guide screen, the remote control setup process is complete. If you did not see the TV Guide screen, you must now complete the following steps.
8. Press tv on your Sky remote control.
9. Hold down select and the green button together for about two seconds, until the red light on the Sky remote control blinks twice.
10. Key in the number of the channel on your TV that you use for watching satellite TV.
11. Press select on your Sky remote control. The red light blinks twice. The remote control setup process is complete.
If after trying this, you still have problems, call your broadcaster's help desk. For your broadcaster's help desk number, select the Telephone Numbers option from the Services screen.
Dec 19, 2008 | Computers & Internet
TV REMOTE CONTROL NOT WORKING
1. Turn your TV on.
Oct 17, 2008 | Philips HDD065 MP3 Player
No powering up
Dec 10, 2007 | Sony KP-53XBR200 53" Rear Projection...
Sony KP-53XBR200 53" Rear Projection Television Logo
125 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
