Question about Honda Maxus Pressure Washer MX5222
Where can I find a replacement pump for a Honda 5.5 HP 2400 PSI Pressure Washer
  • Joey Sartain
    Joey Sartain May 11, 2010
    Honda does not make pressure washers. Does the unit have a brand name on it? Is the engine a 'side shaft' engine (pump mounts on the side) or is it a 'drop shaft' engine (pump mounts on the bottom)? If it is a bottom mount pump is the bolt pattern app 4 inches or app 12 inches?
  • 174 Answers
SOURCE: husky 2400 psi honda engine ran fine all day
It sounds like the bypass valve is stuck. Do you have a parts diagram?
Posted on Jun 27, 2009
  • 174 Answers
SOURCE: Honda Pressure Washer HP 5 not starting
You can try spraying some carburetor cleaner into the carb. If it starts for a minute, your carburetor need cleaning. When you added new gas did you remove the old gas first? Is the air filter clean?
Posted on Jul 19, 2009
  • 251 Answers
SOURCE: honda 2400 psi before it went out i cold tap the
hi,
there is a small ball bearing inside the nozzle on the end of the lance , this can get jammed or missaligned and the nozzle orifice can get blocked , clean this or replace the whole lance with another 200 Bar lance .
hope this helps
Posted on Feb 02, 2010
  • 68 Answers
SOURCE: I want to remove the 4gpm pump on my pressure washer.
HI, It sounds like it is just stuck on the keyway as these can be very tight. You need to force the pump of evenly on either side and should come of if patient.
Posted on Feb 08, 2010
Testimonial: "I'm sure the answer is correct. Over time my use of harsh chemicals no doubt corroded the key-way."
wmpcs
  • 100 Answers
SOURCE: My Honda Excell 2400 psi EXH2425 pressure washer
It sounds like the unloader on your pump is going bad but it is hard to say if it is that or the valves in the pump. The only issue with this machine is that parts are no longer available for this pump. The only option I really have for you is to replace the pump with a new one, it is a very simple process and only takes about 15 minutes to complete.
See this link for information on the pump that would fit your machine
The only thing else you might need is a coupler to have the hose adapt onto this pump
See this link for the coupler
Posted on Nov 12, 2010
How do I replace pull starter rope?
remove the pulley housing cover.Remove the remaining rope pay attention as how its' threaded.Loop the new rope exactly as the old one.That's it
Oct 21, 2012 | Mi T M Mi-T-M WP-2403-3MHB NA 2400 PSI 5.5...
Honda 5 HP OHC Engine
did mice chew threw the wires to the coil over the winter pull the cover and look
Apr 07, 2012 | ALL POWER AMERICA LLC AllPower America...
My Honda 4.0 1800PSI Power washer only has hose pressure when it should have 1800 PSI
hi spray some silicon oil in inlet and outlet then run attach hose back do this everytime you store the washer away it is because the seals dry up always lube when storing.
Jan 15, 2011 | ALL POWER AMERICA LLC AllPower America...
How do you replace the pressure loading valves
if it is a karcher machine you will need to remove the pump, and the valves need to be removed with a set of valve pullers, karcher sell the special tool needed for this, you cant remove the inset types any other way but with the tool,
any questions just ask away
Feb 24, 2010 | Alfred Karcher K2400HH 5 Hp 2.5 Gpm @ 2400...
No peessure
if you have good water flow to it and you have water coming out of the lance when you pull the trigger but its not under presure then it will most likely be bad valves in the pump head or worst case a fault in the pump. any questions just ask away
Feb 20, 2010 | Alfred Karcher K2400HH 5 Hp 2.5 Gpm @ 2400...
No pressure. Have cleaned inflow filter, checked water supply and cleaned and lubed the uploader valve.
if there is water comming out of the back of the pump then your piston seals need replaced , if the lace vibrates then one or more pump valves are blocked ) theres 6 in total /in pairs ) , try running the machine with no hose/lance connected as the lance nozzle often blocks up /malfunctions
hope this helps , if it does please vote
Nov 13, 2009 | Alfred Karcher K2400HH 5 Hp 2.5 Gpm @ 2400...
I have a karcher 2400 psi pressure washer and it doesnt get water pressurized when pulling wand trigger.
the most comon problem with thease is a stuck bypass valve, this is the valve that alowes the water to bypass round the pump when the triger is closed, when they stick all of your pressure runs around the pump and not out of your nozzle,,
its located in the centre of the pump on the top, undo the 2 cap screws pull out valve greese and re fit
Jun 08, 2009 | Honda Karcher G2400HH-R Pressure Washer
Pump doesn't work
ITS ON A KEY WAY JUST PRY THE PUMP OFF
Apr 22, 2009 | Alfred Karcher K2400HH 5 Hp 2.5 Gpm @ 2400...
Honda Maxus Pressure Washer MX5222 Logo
69 people viewed this question
Top Honda Garden Experts
John Trevino
JOHN LAPIER
Are you a Honda Garden Expert? Answer questions, earn points and help others
