No crank
1: battery dead, not charged. does it jump crank?
2: bad battery (corroded clean em) cables lugs. (4 ends)
3: bad starter /solenoid, assembly
4: engine seized, (turn it by hand you cant?)
5: bad key line, (from key switch to PRNDL to stater , no connections)
jump start it, if passed test, battery bad/discharged , and if fail?
you then (battery is good)
hot wire the starter solenoid, keys in pockets
fail? yes, bad starter, seized engine. turn by hand , now you know.
if passes hot wire test, bad key line. (tiny wire)
easy huh?
