Question about Koss HD 50 Computer Speakers
Speakers set up properly, but no sound from PC
I have set up Koss desktop speakers properly (I think) -- they are plugged into the power outlet, plugged into each other, and plugged into the CPU of my computer.  But there is no sound at all coming out -- just silence.  Do I need a special driver for these speakers, or is there something simple I'm overlooking?
Many thanks!
  • nickt1 Aug 13, 2008
    well, they are plued in but when i try windows media or anything with sound it says error device not properly put in i fixed it over and over and it still doesn't work ..help me!
I have set up Koss desktop speakers properly (I think) -- they are plugged into the power outlet, plugged into each other, and plugged into the CPU of my computer. But there is no sound at all coming out -- just silence.Can You Please Help Me
Posted on Mar 08, 2008
Hi! I have a problem with desktop speakers, buzzing sound without reproduction from sound card...other speakers work properly, so obviosly it is a problem with the speakers..the power suply is ok, diode is...
Are this powered speakers connect to the same mains power socket as the computer.
If not you may be getting an earth loop which causes a humming sound.
Connect these speakers to the same power outlet, if you have not sufficient outlets use a power board.
Apr 26, 2011 | Teac PowerMax 160 Desktop Speakers,...
My GD-50 KOSS SPEAKERS HAVE NO SOUND AN THEY ARE PLUGED IN
you need an external sound card. plug into your pc or laptop then plug in your speakers , hey presto. prob solved. and cheaply to.
Sep 11, 2010 | Koss HD 50 Computer Speakers
Headphones work but no sound from either of 2 sets of speakers.
Are speakers turned on with volume up?
Are there batteries in the speakers of not powered by the outlet?
Are the speakers plugged into the wall as well as the computer's earphone jack?
Is windows set on mute?
I would check the above first.
Jul 14, 2010 | Dell Inspiron 545 (884116037743) PC...
I am getting no sounds from my speakers. Everything on the PC seems to be set correctly. The speakers do work when an Ipod is plugged into it. How can I tell if the problem is the cord going from the PC to...
I have tried everything I can think of to fix the problem, but finally gave up and called the person who I purchased it from last June. As I had been using a headset, I don't think we ever tested if the speakers worked with this PC. He is coming to look at it tomorrow. I seem to have ruled out everything except the connection ports on the PC. I hope that he can solve the problem tomorrow.
Jan 17, 2010 | Koss HD 100 Computer Speakers
I have a dell dimension 3000 and i can't get any audio sound. it came with a samsung sw-2525 CD/RW . come to think of it i don't get any sound through the external speakers. it has no internal...
check to see the sound is working under the control panel .. system icon click and goto device manager
you might have a bad driver for the sound device or the device is bad on the motherboard
also test under sound devices.. and set the default device to use ..
Sep 28, 2009 | Dell Dimension 3000 PC Desktop
Sound problems
your speaker connections are plugged in incorrectly or the speakers are not plugged in and powered on.
check the back of the computer where your speakers are plugged in and make sure you speakers are plugged into the right colors
May 31, 2009 | Computers & Internet
Don't know how to hook them up
What a lovely daughter, how very nice of her,
here goes....straight for Mr. Koss
To Operate with AC Adapter
  1. Open battery compartment located at the back of both speakers and remove wires.
  2. Replace battery covers.
  3. Connect DUAL PLUG CONNECTOR on left speaker to right speaker at connection marked "TO LEFT SPEAKER."
  4. Connect remaining wire with 3.5mm plug to headphone jack on your audio source.
  5. Connect AC adapter (not included) to back of left speaker at connector marked "DC 6V." Plug remaining end of AC adapter into wall outlet. Be sure your AC adapter is built with the center pin as ("-") negative. Connect remaining wire with 3.5mm plug to the headphone jack on your audio source.
  6. Turn ON/OFF switch at back of right speaker to "ON."
  7. Set "INPUT SELECTOR" switch to audio source.
  8. Turn on audio source
  9. Adjust sound in the following ways: Turn volume control to desired level; push Bass Boost button located on right speaker to "ON" for added bass; push Treble Boost button on right speaker to "ON" for added treble
  10. Operating a microphone through your speakers require an additional 3.5mm plug to 3.5mm plug cable (included). Connect cable with 3.5mm straight plug to right speaker at input marked "MIC" on back of speaker. Plug the remaining 3.5mm L--plug into the mic input on audio source. Connect your microphone to the front of your speakers at "MIC" input (microphone not included)
Hope you have all of the skinny you need, good luck,
please leave a rating, thank you kindly
Apr 27, 2009 | Computers & Internet
No sound through external speakers
Although some monitors have built in speakers, most people have stand alone speakers. If the old monitor had built in speakers and now it is unplugged you won't hear sound. Even if the speaker cable is still plugged into the sound output on the back of your computer, the monitor must be plugged into an electrical outlet to have power.
I'd recommend buying a new set of external speakers if this is the situation.
If you never had speakers built into the monitor then normally changing monitors would make no difference whatever. The only explanation that makes sense under those conditions is that in the process of replacing the monitor, you dislodged the speaker jack from the sound output on the back of the computer.
Make sure your external speakers have electrical power plugged in, the power is on (green light on at least one speaker lights up) and the volume on the speakers is at least half way up.
Unplug the speaker from whatever hole it is plugged into and plug it firmly back in and test sound.
If still no sound other than some static on the speakers, try every single hole on the back of the computer that the jack will fit properly and test for sound.
Let me know if you have further questions.
Honest1abe
Jan 10, 2009 | Acer Computers & Internet
Need a wiring diagram for connecting KOSS HD 50 COmputer speakers
Hello there! lellya
First,
1) you have to tell , what kind of sound card you got? on board audio? A7, or Creative Audigy? 5.1 or regular.
2) then, you have to connect one speaker to the other, one two way connector cable, for the 2 KOSS speakers.
3) another cable that goes in back of your koss and from the out of your KOSS Speakers to the input of your sound card, at back of your PC, this input is your sound card jack.
4) its supose to work like so.
good luck
Oct 16, 2008 | Koss HD 50 Computer Speakers
Connecting 4 speakers
well some computers dont support 4 speakers.
Dec 13, 2007 | Acer Aspire™ T180 PC Desktop
Koss HD 50 Computer Speakers Logo
552 people viewed this question
Top Koss Audio Players & Recorders Experts
Steven Wander
Steven Wander
Steve K
Rick
Are you a Koss Audio Player and Recorder Expert? Answer questions, earn points and help others
