Question about Whirlpool ED5FTGX Side by Side Refrigerator
Grinding, Howling Sound Coming from Freezer
Here is the correct Model #, it would allow me to post w/o a model and my model was not listed.
///{Whirlpool Refrigerator Side by Side Model # ED5NHGXNQ00}///
Hope someone can help me; I have a Whirlpool 25'' side by side that starts making a loud spinning, winding, and growling sound for about 20 minutes and then stops. There is no pattern to when it decides to do this. It started about six months ago and then stopped until the last couple of weeks. It seems to be coming from behind the refrigerant radiator like piece of hardware behind a panel inside the freezer portion of the refrigerator. Does anyone have any idea what component this may be? Also does anyone have a schematic that would show the location of this faulty component for repair?
Thanks for any suggestion,
David S.
    An expert who has answered 20 or more questions within one hour.
  • 67 Answers
You almost certainly have a defrost fault building up ice around the fan
Posted on May 02, 2017
  • 481 Answers
SOURCE: whirlpool conquest 2001 GS6SHAXKQ01 refrigerator side by side top part is not cooling
the first one sounds like it is slowly leaking freon.
  •  the second Sounds like a defrost problem. Check to see if there is any frost buildup in the back wall of the freezer. If so, it is not defrosting as it should.
  • possible causes:
  1. bad defrost timer/control board
  2. bad defrost heater (in freezer)
  3. bad thermo switch in freezer
If you don’t know what these are then unplug the machine and let the ice melt in the freezer overnight with the door open. Then try it the next day, if is cooling fine then you need to have a service person replace one of the above items. If it still has a problem then it might be the compressor and you should probably replace the machine.
Posted on Jun 29, 2008
  • 1462 Answers
SOURCE: Whirlpool Refrigerator Door Seal surface is HOT.
transom between fridge and freezer is usually haeted to stop condensation when you open freezer door. suspect you have no fault
Posted on Jul 14, 2008
  • 478 Answers
SOURCE: freezer does not make ice
You need to check and see if ice maker has any water init. if not check the fill tube that goes thru the back wall for stoppage while you have it out rin the maker thru a harvest mode and listen for the sounds of the solonoid opening. If tube is full you'll need to replace the slow leaking valve a common problem. for parts call 704-819-6557
Posted on Mar 14, 2009
  • 2651 Answers
SOURCE: Whirlpool GD5SHA XLTO2 problems. Last night,
sounds as if your overload relay, controlling your compressor has burnt out heres a part number that should getyou back in working order( complete with intructions pn# 8201786
Posted on Jun 15, 2009
  • 2237 Answers
SOURCE: Whirlpool Side By SIde Refrigerator Freezer stopped cooling
5 reasons for fridge and/or freezer getting warm: 1- the evaporator coils are icing up and won?t let air circulate. 2- the evaporator fan is not working to circulate air. 3- there is no refrigerant in the system. 4- no power to fridge or compressor. 5- the condenser coils have no air circulation check under the fridge behind the vent. if it is too dusty or the fan isn?t working, it is not getting enough airflow to cool down. replace fan and/or vacuum out the dust. if there is no power to the fridge, the light will be off. if the compressor is not running, there is a defrost timer that cuts the power temporarily to the compressor to melt ice on the coils. it?s located under the fridge behind the bottom vent. If the timer is off and the compressor is not going, the compressor or the main board is bad and needs replacing. there is also a temperature sensor on the evaporator coils that tells the defrost coil to turn on and when to turn off. if the defrost timer is on but the coil is not heating up, replace the sensor. if it still won?t heat up, it?s the timer or the coil. the easiest way to tell if there is no refrigerant- the freezer wall is warm and the compressor is loud. if there is no refrigerant, it may be more cost effective to replace the fridge. if you feel no air coming from the freezer vent, the fan needs replacing. If you feel air moving in the freezer but not the fridge, the channel from freezer to fridge is blocked. if the freezer has air and the rear freezer wall has frost on it, the evaporator coils are iced up and need defrosting. causes: 1. low refrigerant 2. no fan 3. too much humid air in fridge/freezer due to door open or bad door seals 4. the condensate drain tube is clogged if the seal around the door is ripped or not completely sealing, or there is condensation at the bottom or the walls of the fridge, replace the seal(s). no air, no fan. Replace if the refrigerant is low, it just needs a top off. but you need to be certified by the epa to move refrigerant, so get a professional. defrost solutions: unplug the fridge. remove the wall of the freezer that is frosted/icing up. use a hair dryer to melt the ice. do not get too close. you will see a drain under the evaporator coil. make sure it is not blocked. the water should run freely to a condensate pan under the fridge that evaporates the condensation with the hot line from the compressor. once the coil is free of ice, frost, and water, replace the panel and repair any of the problems that caused the icing up. plug the fridge in and turn it on. If it frosts up within a week, there is still an issue that not been taken care of.
Posted on Aug 28, 2009
Check the fan. It comes on at different times. It could be the source of the grinding sound.
Oct 06, 2014 | Maytag MFI2568AES Stainless Steel Bottom...
My frigidaire fer231cas2 makes a horrible loud GRINDING noise after its been running for 10 or so mins
Hello friend, thank you for your post!
I see that you have changed multiple parts within your Frigidaire dryer due to a grinding noise. Since you have changed the bearing cup, felt, pulley, and belt I would recommend having a technician come out to diagnose your appliance to avoid any further unnecessary part purchases. You could be seeing an issue within the drum or motor. I hope this information is helpful. -Matt
Aug 26, 2014 | Frigidaire Dryers
Freezer is full of snow
Check freezer and refrigerator door seals, ice dispenser ice door and floor of freezer for ice buildup caused by a defrost drain blockage. If ice door is stuck open it will allow for warm moist air to be drawn inside freezer and collect as frost over everything. Is GTS16BCS the correct model number listed above your post? I will be here should you have questions, Thanks Sea Breeze
Mar 07, 2013 | GE (GTS16BCS) Top Freezer Refrigerator
My GE Fridge PSS26SGRD has a moaning howling
The fan is hitting on ice buildup...unit is not defrosting...
There are a few reasons why the refrigerator part will not are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
Refrigerator2_bing.gif not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Jul 12, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
My refrigerator side is making a grinding noise and today I noticed that it is warm. the freezer side is fine. I have a frigidaire frs26kf6e.
Hi and welcome to FixYa, I am Kelly.
That grinding noise is usually ice build up on the evaporator coils to the point that the evaporator fan blades strike the ice build up. i.e. Possibly an automatic defrosting problem.
Here is what you can do to find out.
1. Unplug the refrigerator
2. Remove the contents from the freezer section
3. Place a fan blowing into the freezer compartment for a little over 2 hours. THIS MAKES A WATER MESS so be prepared.
4. After the manual defrosting period with the fan then reload the freezer.
5. Plug the unit back in
6. After 4 hours recheck your freezer and fresh food section temps.
7. You should no longer hear the grinding sound
It is highly probable that the ice build up will repeat. If it does then for sure you have an automatic defrosting problem and will need to service the defrosting problem. At least you will know what caused the grinding noise.
If after all of this that grinding noise you heard is still present you will have to check the evaporator fan assembly for signs of bearing wear.
If the grinding noise is coming from the compressor... bad news the compressor rotor is dragging and that requires a compressor replacement.
Your parts can be found here:
(there are 2 missing digits from the model number)
Click on the model number of your exact model and the parts page will appear.
Thanks for using FixYa
Apr 25, 2010 | Frigidaire FRS26KF6E Side by Side...
My refrigerator/freezer making a howling sound and an intermittent whirring sound. I have noticed this at night, not sure if it is doing this during the day.
I have the same model, and the exact same problem. Additionally, the compressor/fan for the freezer cycles up and then down (rising and falling noise pitch) at a frequency of about every 5 seconds. The howling is worse at night(!?). It is 4 yrs old and was in the house we just bought. Help quickly, or this is a CraigsList item.
Jan 12, 2010 | Hotpoint HSS25GFP Side by Side...
The Top Freezer Is making a Loud buzzing Noies!
Hello psimmons304,
Yes it does sound like a issue for the fan. What i would do is look up the model on google and type in replacement fan. you should be able to find it that way.  If this doesn't answer your problem please post again.
Please post what you do and how you did it. I look forward to your posts.
Nov 11, 2008 | GE Profile Arctica Stainless Steel Top...
Noisy compressor
Is a Hotpoint refrig?? Ge (who makes hotpoint) is having trouble with the freezer fan howling. Check out posts on Ge SxS PSS models. Some say its the main board, i disagree.
Dec 02, 2007 | Hotpoint HSM25GFRSA
Howling - Which is the correct fix
I think I have the same problem. The unit is also about 2 years old (GSH25KGRBB). I have an extended warranty. They already replaced the controller card. I see it is the exact part number you have mentioned. It seemed to help for awhile but I think it has gotten worse again. The noise is more consistent after they changed the board. Less revving up to "turbo" mode. Howling is a good description. I can hear it now, on the other side of the house. I would change the fan out. I think they did the board first because it probably is easier even if the part cost is higher. I will probably call them back again. This will be the third time. The first time they just changed the little flapper on the ice dispenser. Otherwise the unit cools and runs flawlessly.
Aug 11, 2007 | GE (PSS26MSRSS) Side by Side Refrigerator
Whirlpool ED5FTGX Side by Side Refrigerator Logo
71 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
