Question about Canon PowerShot SD750 / IXUS 75 Digital Camera
Its saying the memory card is locked. its not
When i turn the camera on it says "card locked". I checked the memory card and its not locked.
    Sergeant:
  • 246 Answers
If you have checked the SD card was not locked, you may need to open the camera to check the SD card slot inside,
here is a tips shows you where to check
http://www.myfixtips.com/blog/digital-camera/how-to-fix-a-%e2%80%98card-locked%e2%80%99-problem-125.htm
Posted on May 16, 2009
My camera says the my memory card is locked.?? i dont no how to unlock it My Ixus 70 says my card is locked, but the card is NOT locked (button on the side of the card is in unlock position). The came
Oops. The little latch on the side in the unlock position, should engage a switch in the camera, indicating the memory card is not writ protected. It is not an electrical switch doing something in the memory card. But is the switch in the camera is defect, you get the same result. If someone once tried to press in a memory card, the wrong way around, this could have been the cause of a damaged switch. Just check the memory card slot, of nothing is in the cardholder, blocking the little switch from working correct. Sure the switch is in the up position, like in the picture? 25288825-qj532vtjsqner5bmetfl14fj-5-0.png
Nov 18, 2014 | Sony Cyber-Shot DSC-W530 Digital Camera
Canon SD1300 memory card locked
There are several possible causes for "memory card locked", "memory card error", or "no memory card". The most common cause is having the tiny slide switch on the side of the card in the wrong position. But, if you've checked the slide switch, the internal switch in the card slot may be jammed by a grain of sand or gunk. Here are troubleshooting steps for this problem. Recommend the toothpick fix for your particular problem.
Dec 06, 2011 | Canon PowerShot SD1300 IS IXUS 105...
My nikon camera says "Memory
Remove memory card from camera and slide lock in memory card (check photo).
Dec 02, 2010 | Nikon View DX (25243)
When i turn on my DSC-W310 camera it says memory card is locked. So I cannot take pictures or find a way to unlock the memory card. How do i fix this?
Here is a tip that I wrote about SD Cards and how to unlock and lock SD Cards.
If you are getting a memory card locked message then check this out.
How to Unlock SD Card
heatman101
Oct 09, 2010 | Sony Cybershot DSCW310 Digital Camera
My Canon A460 says the Card is locked. The lock switch on the card is set to unlock. I have another camera with a similar card. Both cards work in the other camera. neither card will work in the A460 both...
back up your data first,thenyou reformat the memory card in the camera.i guess you have formatted the memory card in another device.canon cameras generally do not accept cards that have been formatted in another device.then sitch off the camera and reinsert the memory card.
Jun 27, 2010 | Canon PowerShot A75 Digital Camera
When i turn the camera on it says memory ard error
If camera show Memory Card Error, Check whether the card is inserted properly or not. For SD card, check out the card lock switch is in the correct position and not stuck in between.
You can Format the memory card in the camera using the Setup Menu option (Format). Please be aware that formatting the memory card will remove any images currently stored on the card along with any other data.
If after formatting the card do not clear the error, try another memory card. If this occurs with only the one card it is likely that the memory card is defective, if the error persists over more than one card the camera may require service.
Rating the solution is highly appriciated...Good Luck
Mar 01, 2010 | Optics
My memory card is locked how do i unlock it?
Pull out memory card from camera. on side of card there is a slide switch. The card should say what way to slide to un lock.
Good Luck
Nov 09, 2009 | Samsung BL103 Digital Camera
CARD LOCKED
take out the memory card and move the switch located somewhere on the memory card usually on the side to the unlocked position. Then the memory card isn't locked this is so you don't accidentally delete important things
Thanks and enjoy,
Lee
Apr 26, 2009 | Pentax *ist D Digital Camera
Memory card locked
I had the same problem - just put the lock button of the card to the lock position and than again to the unlock position
Jul 06, 2008 | Canon PowerShot A450 Digital Camera
Unlock card
If the card is locked, you could the steps below:
- Turn off camera
- Remove memory card
- Take a look on the switch of the memory card itself
* If it's at the TOP = card is UNLOCKED
* If it's at the BOTTOM = card is LOCKED
- So, you just have to make sure that the switch is at the top
for the memory card to be UNLOCKED
After doing that, you just have to put back the memory card to your camera and turn on the camera. Try to check if this works.
Nov 10, 2007 | Pentax Optio 550 Digital Camera
Canon PowerShot SD750 / IXUS 75 Digital Camera Logo
371 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
