Question about Sport & Outdoor - Others
A rag that got sucked through the carbs and in to the intake
There is a rag that got sucked through the carbs on my Polaris xplorer 500. It is now in the intake but when you go to pull it out it falls apart. How would I go about getting that out? Is there an easy way to get to the intake or would I be better off taking it to a mechanic?
  • mandydawn08 May 16, 2009
    Yeah that's what I was afraid of. I have been digging pieces of the rag out of the carb where it has been falling apart. Lucky for me I haven't bought the thing yet. I was going to buy it from my cousin, who said all it needed was a new spark plug. I'm a girl, but i know a little something about these things. Anyhow, he told me that it needed an air intake filter but he had put a rag around it last year and he hadn't ridden it since then. So when i pulled the carb off there was the rag sucked down in there. When I started looking closer, it looks like the rag is down in the motor. I took off a side plate thinking maybe i could see something there, but that's where the timing chain is.
    President:
  • 1,902 Answers
Take it to a mechanic, cause you could still leave peices behind even after taking off the intake and will cause you more problems then you want to have.
Posted on May 16, 2009
Testimonial: "Wonderful and quick response! Thank you!"
  • Jeremy Reddick
    Jeremy Reddick May 16, 2009
    Ya, I would be a little concerened that he did run it. Also that it is stuck in the carb could leave you with problems like throttle getting stuck wide open, not closing, choke not releasing. If it is in the motor string can get wrapped around the valve. piston, and other moveable parts. If you feel like you can take this on. Then give it a try. You seem like you know what you are doing. It will just take some time and some effort to make sure all is out
1995 Polaris Xplorer 300 Mikuni Carb MIC H7B5 diagram
polaris atv forums should have links to service manuals for that
Jul 19, 2017 | ATVs
How to remove starter Polaris xplorer 300 atv 1997 ?
See: https://www.youtube.com/watch?v=aDN5dylOFBw and http://xplorer-manual.blogspot.com/2014/11/download-polaris-xplorer-300-repair.html
Jun 08, 2015 | ATVs
2001 polaris 500 only revs up when choke is on
probably needs a good carb cleaning, or maybe theirs a air leak in the gasline or the rubber intake boot.
May 27, 2014 | Polaris ATV
2001 Polaris 500 Magnum 4X4 will not start ..starter just clicks Will not start when jumping battery
It sounds like you haave a grond problem. When you jump start the quad, attatch the negitive cable to the exaust close to the engine. This should solve your problem. If it does, you need to remove the ground cable from the frame/engine, and clean it as well as where it mounts. Get a star washer and put it between the cable and the engine/frame, this will allow it to cut into the metal forming a good ground.
Hope this helps,
Matt
Feb 13, 2010 | Polaris ATV
Need to rebuild a Polaris Xplorer ATV. Where can
Try atvconnection.com . Thanks you for asking and I hope it helps.Please leave me a 4 thumbs up.
Feb 09, 2010 | Polaris ATV
My 97 xplorer 500 will idle and drive great untill wide open at top speed it seems to bog down. Any hints? rebuilt the carb, flushed the tank and fuel lines.
Sounds like you have extra holes in the air box or a loose/missing air box lid. If you make any holes in the air box or leave the lid loose or off, you will need to fix that back to stock or re-jet your carb for more fuel.
These 500s are set very lean at the factory for EPA reasons. The stock configuration relies on slight vacuum inside the airbox under heavy loads for both the fuel pump (vacuum operated) and the extra fuel needed at high RPMs.
If you drill holes or leave the lid off, you will run very lean and the fuel pump will not get the right vacuum pulse it needs to work.
Also check your fuel filter for sufficient flow.
Nov 10, 2009 | Polaris ATV
97 Polaris Xplorer 500 4X4 rev problem
REPLACE THE CAMSHAFT !!!,,, HAVE A LOOK AT CAMSHAFT , EXHAUST LOBE IS PROBABLY WORE RIGHT OFF....
Nov 03, 2009 | Polaris ATV
ATV RUNS BARELY SOUNDS LIKE IT IS EXHAUSTING BACK THROUGH CARB
Check the cam shaft. The exhaust lob is the weak spot. They will wear down to nothing.
May 02, 2009 | Polaris ATV
1997 Polaris Xplorer 300 No start condition
well...you only need 4 things to make an engine run.fuel,air,spark,and timing.
Apr 29, 2009 | Polaris ATV
Sport & Outdoor - Others Logo
62 people viewed this question
Top Sport & Outdoor - Others Experts
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
