Question about LG Refrigerators
I have LG refrigerator model GN-M602YLQ made in Indonesia sold by LG Pakistani dealership. The freezer section is set to dial "1" position while the refrigerator section is set to 1 degC, even then the brand new refrigerator is not cooling properly and food items like milk and juices are rotten in the refrigerator section. The freezer section is working OK but the refrigerator section is not cooling even as low as 0 degC setting. Refrigerator is located to allow air circulation around it. Please email response at msghani_2000@hotmail.com.
fridgetech
  • 473 Answers
SOURCE: Items sometimes freeze on refrigerator side of unit - model GSS25LGMA
It is most likely a bad damper motor.  This is where the cool air comes out into the fridge section.  On this model it is a fairly common problem and comes a whole assembly.  The part # is WR49X10091 and will cost anywhere from $100 to $122.  Knowing this model I would bet this is your problem.  If the damper is bad and stuck open cold air will just keep blowing in.  It is suppose to open and close based on the temp setting.  Let me know if you have any other questions.
Posted on Oct 11, 2007
the dr
  • 447 Answers
SOURCE: kenmore 73503 not cold enough
Is the fan in the freezer working?? Is there Ice on the rear panel in the freezer?
Posted on Dec 04, 2007
  • 65 Answers
SOURCE: Kenmore refrigerator won't cool, but freezer does.
by closing that small door you are starving the refrig of cold air . you should be getting a heavy whisper of air through that door. place all controls in the middle position, close the freezer door and check for airflow through that vent.
Posted on Feb 24, 2008
Shilpika
  • 6 Answers
SOURCE: LG Refrigerator Model GR582WF
go & buy a new one
Posted on Feb 27, 2008
VtToolMan
  • 704 Answers
SOURCE: Refrigator not cooling properly, freezer works fine
I'll assume you don't have much food/items in the freezer section. Because you have the fridge set on the max cooling setting and the freezer set higher than the mid setting, it could be that you have frozen the cold air passage from the freezer to the fridge.
If you can, 1) remove all contents that would spoil; 2) turn off the fridge 3) open both doors and allow the fridge to manually thaw out completely (this will speed up the opening of the cold air exchange passage between the freezer and fridge, which is likely blocked and frozen solid. Have plenty of towels handy to soak up the water from the defrosting process,
After a FULL day of being left off and doors open to thaw out, check for any further thawing and dripping water inside, if present wait another 8 hours (you really want to get it thawed out the first time!) When that's done, reset BOTH temperature controls to the factory mid-point setting (5?) as marked on your control knobs.
The key to having a refridgerator run properly is to allow for it to run at the factory settings for at least 24 hours BEFORE you adjust the controls higher and/or lower for each section. Adjust it up or down in ONLY 1 setting increments so as to not cause ice build-up and freezing of the internal air exchange passages.
Also, as you've relegated this fridge as a garage "beer & backup" unit, make sure to keep the freezer as full as possible to make it run as efficiently as possible. You can freeze jugs of water and pack it with cheap thrift store bread to help it run correctly. An empty freezer has to work harder to keep just air at freezing temps. As such, it will pass much colder air into the fridge, and cause these types of freeze ups. By the way, turning up the temp controls only makes it worse and just results in a total "freeze up" inside the cabinet panels that you can't easily see or get at to rectify, hence the reason to shut it off and let it fully defrost.
When you're done, you should have your fridge back in action working like it should, but remember, don't rush temperature adjustments, even thou we all want those frosty beverages, it'll take a couple of days to achieve the desired "chill" you're likely used to getting when it was your primary fridge.
Hope this helps and Best Regards! Semper Fi!
Posted on Aug 03, 2009
I have a LG fridge model GR-P247STSL and the ice maker is not working. The plastic arm that determines whether the ice bucket needs replenishing is not coming down. Do you know why?
*Check your warranty. You should call vendor for service.
*** The following is for information only.**
* I've had this problem a lot with my old fridge. Water line works but no ice.
* Check if the "Ice Full" leaver is in the down (no ice) position. Some ice makers will lock the leaver (a stiff wire) in the full position to manually shut off ice maker. Make sure it swings up and down when ice tray is empty.
* Sometimes when the tray is left full of ice for a week or more then the tube feeding water will freeze up. Defrosting the freezer on a regular basis will help. A quick fix is to pour warm water in the ice maker section (where the ice is formed). This will help melt the clogged pipe and also make some ice while your waiting. You may have to do this several times. But at least you have ice.
* This (freezing up) may also be caused by the freezer set too cold. The temperature dial should be in the middle. But turning it colder and colder over time will cause ice to build up and prevent foods from freezing properly (thus turning the dial down colder.) Once your maxed out on the dial. You will find the freezer gets warm and things get covered in frost crystals.
* Transfer food to another refrigerator and perform a complete defrost by leaving it unplugged and the door open (freezer section).
* Frequently check and dump water at bottom of fridge. Clean the dust on coils while down there.
* A fan blowing into the freezer section helps. (Do NOT use a heated fan as it will warp the plastic and overpressure the refrigerate.)
* Once defrosted (+4 hours). Power up the freezer and set the temperature dial to mid point and the freezer diverter to middle or normal setting. Don't put the food back in yet. Wait till the freezer gets down to normal freeze temp (about 0 to 10F)
* Move freezer back in place (if you moved it to access plug) then slowly put back the food. Try not to cram stuff in. Leave space for air to flow freely around items.
* Final, Call for service anyway and have them perform yearly service. Check your warranty.
Aloha, ukeboy57
May 29, 2018 | LG Refrigerators
Temperature settings 1, 2, 3, 4, 5 means
refrigerator dial settings work from hot + 5 degrees (5) to real cold (1) 0 degrees and in the freezer section they work in the opposite direction (1) is cool - is minus 5 degrees and ( 5) is minus 25 degrees
those figures are example figures to show how the temperature in the units will be in relation to the dial numbers
Apr 27, 2015 | LG LSC26905TT Side by Side Refrigerator
Its a LG GN-466FW after looking at it it was iced up & the fan wasnt working
We have the same problem and the same model fridge/freezer LG GN-466FW. Can you tell me if you got your problem fixed with no cooling in the fridge compartment ?
Feb 11, 2011 | Refrigerators
Refrigerator less than two months old. Freezer side fine refrigerator side stopped working altogether. All food ruined. Who should I contact. purchased from Home Depot.
This is a very common issue, If the freezer compartment is cold and making ice the
problem is simply airflow from the freezer into the refrigerated section.
Typically when one senses the refrigerator is warm they max out the settings
on both dials the thermostat with its 1-10 settings as well as off for the compressor.
This controls the compressor and temperature.
The additional setting or dial is for colder freezer or refrigerator as well , However
it simply opens or closes a flapper door between the freezer and refrigerator boxes.
When that dial or setting is maxed , it closes and makes the freezer colder, yet leaves the refrigerated section starved for sufficient airflow to maintain a cold box in the refrigerated section.
Just set the dial that does not turn the compressor off to the middle setting.
One can leave the thermostat that does control the compressor in the max setting , just not the colder freezer setting, If you notice colder isnt colder refrigerator, Its actually colder freezer, A common issue found on 25% of all refrigerator calls a simple setting adjustment.
Its easy to think that maxing out the settings makes for a colder refrigerator, it doesnt, it makes a colder freezer and warm rerigeration section.
If a freezer is making ice, theres nothing wrong with the unit other than airflow setting.
Add a comment
Dec 24, 2010 | Maytag Refrigerators
My GE TFX30PP is constantly running and doesn't turn off. The freezer is very cold but the frig side isn't cold enough. A repair guy put in a new "cold contol" sensor but it didn't help.
I would also clesan the condenser coils off.
Add a comment
Dec 24, 2010 | GE Profile Performance 29.8 cu. ft....
Freezer section 26 deg f. refrigerator section 58 deg f with both dials set on 3. refrigerator section not cold even if dial is set to 4 or 5
when you open the freezer door do you hear the fan blowing,also is there any like snow or frost on the freezer wall inside the freezer,touch it and make sure or was the door left open?is there frozen water droplets on the food packages and on the racks,let me know what you find and send the model number,open the fridge door and look on the left side wall near the ceiling
Sep 07, 2010 | Whirlpool 21.0 cu. ft. Top Freezer...
Country code
i have mobile (CYON)LG-KH1800.Now i im in INDONESIA. Sim already use in SHOW,that is not usable. When we insert the Sim in INDONESIA compnies, moblile asked the country code. Please help me. Thanks
Jan 20, 2010 | LG Cyon
Is it possible to turn OFF completely the refrigerator section and leave ON the freezer section of our side by side, so that we can use the freezer only. We do not need the refrigerator section.
Don't know which refrigerator make/model:
There are two dials, one for refrigerator and one for freezer.
Set refrigerator dial to lowest setting, leave freezer setting alone. Refrigerator will still operate at warmer swetting so it will not create mildew or odors... use odor-killing soda.
You might store foodstuff / cans/sealed boxes of cereal, flour, etc.
Sep 19, 2009 | Refrigerators
Freezer fine refrigerator is not as cold as it should be. dial is set to coldest position. butter is soft and milk is on verge of spoiling
do you notice ice built up on freezer section back wall if so you have a defrost problem if not you have a freon problem also make sure the freezer setting is not on its coldest setting this actually controls the air flow to the fridge section both freezer and fridge need to be set about half way
Jul 12, 2009 | Refrigerators
We have a LG Two Side Fridge.
Look for the air ciculation regulator sliding vent between frig & freezer section open accordingly. Set both sides to #3 on dials if frig not cooling to less than 40 degrees, might need new cold/temp controller behind frig dial
Apr 30, 2009 | LG LRSC21934 Side by Side Refrigerator
Refrigerators Logo
100 people viewed this question
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
