Question about Dryers
Fuse keep blowing
I have changed the thermal fuse 2 times in maytag dryer its located under the heating element.
  • Rought Rider Dec 31, 2007
    I have a MDE5500AYW
    Takes a long time to dry, Lint trap is clean and vent pipe is also clean.
    How is the easy way to get to the heating elemts?
    Thanks
  • 291 Answers
I would check temp out of dryer should be 140 - 160
Is your cycling themostate good, cutting off when suppose too?  and Hi limit on burner good?
THe cycling themostate control drum temp, hi limit on heater is a back up and the hi limit fuse on burner backs up it all
Posted on Oct 17, 2007
Maytag Bravos XL Dryer not heating- blowing thermal fuse
The thermostat is controlling the temperature, however the Heating Coil may be defective. Check the COIL.
Feb 27, 2014 | Maytag MEDB950YW Electric Dryers
Knemore Series 80 Dryer - Blows Thermal Fuses, Humming Noise
The heating element is shorted to ground. You will need to replace the heating element and the thermal fuse, both available at the link below.
Heating Element $40.77
Thermal Fuse $6.99
Mar 02, 2012 | Kenmore Dryers
My maytag neptune dryer doesn't blow any hot air
on top of the heating element on the left side there is a white 2connector part, that is the heater thermal fuse. disconnect the dryer power cord and one wire of the thermal fuse and use a meter to find out if you have continuity to it. if not replace it. also check for burn wires at heating element. also test heating element by disconnecting one wire and using an ohm meter test it at 2 therminals. it shoul measure 10-12 ohms.
Feb 14, 2011 | Maytag Neptune MDE5500AY Electric Dryer
No heat
Hi
If the dryer is not drying the clothes then you would need to check for the following things-
Electric Dryer---
1. Inspect the fuses and circuit breakers they may have burned out or tripped. Usually, dryer will still tumble but not create heat if a fuse or a circuit breaker is not working.
2. Check for the amp reading at 240 V, it should have reading of 24, 21 and 3 amp (approx.) for 2 lines and neutral respectively.
3. Heating element may have turned or the connection to the element might be loose. Sometimes a shorted circuit element will keep on blowing the fuse or circuit breaker.
4. Motor wiring shorting to ground.
Gas Dryer---
2. Check for the continuity of the heating element in your gas dryer using a multimeter. Replace the element if continuity is not there.
3. Inspect the thermal fuse if it is burnt out, it is attached to the exhaust duct on the back panel of the gas dryer. Replace if necessary.
4. Check the igniter by first disconnecting it, and then place the probes onto the two contacts of the igniter. The meter should read under 100 Ohms of resistance, if it is above 100 then replace the igniter.
5. Check the continuity on the flame sensor. The sensors are usually located close by the igniter so are easily visible.
Hope this helps...
Daniel
Sep 24, 2010 | Maytag MDE2400A Electric Dryer
Doesn't get warm
Hi
Electric Dryer---
Gas Dryer---
Hope this helps...
Daniel
Sep 20, 2010 | Maytag Neptune MDE4000 Electric Dryer
My dryer has no heat
If the model number you posted this question under is correct, your heating circuits are comprised of the following components:
1. Heating Element
2. Thermal Cut-Out
3. Hi-Limit Thermostat
4. Internal Bias Thermostat
5. Thermal Fuse
You can access your heating circuits by UNPLUGGING the dryer and removing the rear panel.
As viewed from the rear of the dryer, your Heating Element will be located on the RIGHT hand side inside a heater box. The Thermal Cut-Out will be located on the outside of the heater box at the end opposite the heating element terminals. The Hi-Limit Thermostat will be located adjacent to the heating element terminals.
The Internal Bias Thermostat and Thermal Fuse are two small components mounted on the Blower Fan housing on the lower LEFT hand side.
You can refer to the following parts illustration for assistance:
http://pcappliancerepair.com/model-display.php
The components are listed as follows:
Heating Element (Item 17)
Thermal Cut-Out (Item 6)
Hi-Limit Thermostat (Item 15)
Internal-Bias Thermostat (Item 20)
Thermal Fuse (Item 19)
If you need assistance on how to troubleshoot a dryer, you can refer to this link:
http://www.fixya.com/support/r3574266-thorough_dryer_advice
The MOST common causes of heat related problems: 1. Blown Thermal Cut-Out. 2. Missing 1/2 your input voltage at the wall receptacle (the dryer will still run with half the voltage missing, but won't heat - double check your source voltage at the receptacle and/or your circuit breakers. 3. Bad power cord, causing 1/2 the input voltage to be missing. 4. Blown heating element. Read through all the information provided and let me know if you have any questions, or need further assistance. I hope you find this information helpful. NOTE: Take all resistance readings with the dryer UNPLUGGED and the component under test isolated (meaning disconnect any wire leads to ensure the accuracy of your readings).
Apr 02, 2010 | Whirlpool LER4634J Electric Dryer
I have a May Tag dryer which blows the Thermal Fuse.
I am not 100% sure, but I think that the model that maytag had with that dryer. When I was working for my local dealer I had to change several of those, and it about 2 weeks time they blew.
Aug 09, 2009 | Maytag MDE308DAYW Electric Dryer
Maytag Atlantis electric dryer Model
Check the following to address this issue.
1. No power to the dryer
Make sure there's power getting to the dryer. Check for tripped circuit breakers or blown fuses. An electric dryer uses two circuit breakers or fuses, and if only one of two is tripped or blown, the dryer might still run but not heat. Sometimes the power cord disconnects or burns at the dryer, if this is the case, the wiring and the terminal block must be repaired or replaced.
2. Heating element
A burned out heating element will show no continuity when measured with a meter. Replace the element if found defective.
3. Thermal fuse
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
Aug 08, 2009 | Dryers
Electric Maytag Neptune Dryer not heating up.
If the dryer won't heat up, the problem is typically either a blown thermal fuse or a faulty heating element. The thermal fuse is located just inside the back of the dryer on or near the exhaust duct. It is about one inch long. The thermal fuse and heating element can be tested using an ohm meter or multimeter. These components should have continuity. If either does not, that component is faulty. There is no telling if the moving around of the machine caused the problem or if the timing of the problem was coincidental. Sure hope this helps ya and best wishes.
Jul 21, 2009 | Maytag Neptune MDE4000 Electric Dryer
Dryer Won't Start
most common problem with the dryers is blown thermal fuses, something gets too hot and for safety reasons the thermal fuse blows. You can also check your incoming power supply make sure the breakers havent tripped. part num( LA-1053 )about $30 comes with directions to install. its located under main top towards the rear of unit moundted to the side of heater.BE SURE TO TURN OFF ALL POWER BEFORE CHECKING ITS LIVE!!!!!!!!!
Mar 06, 2008 | Maytag PYE2300AY Electric Dryer
Dryers Logo
240 people viewed this question
Top Dryers Experts
