Cars & Trucks Logo
Posted on Dec 21, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Remove brake booster - Cars & Trucks
Daniel Mc Entee
Level 3:
Renaissance:
An user who is expert in 3 categories / brands.
  • Cars & Trucks Master 1,449 Answers
  • Posted on Dec 22, 2013
Daniel Mc Entee
Level 3:
Renaissance:
Answers
1449
Questions
0
Helped
275542
Points
3556
Remove the brake pipes , and the rubber hose with the plug. now go to the drivers foot well.need a torch to see .remove the two nuts holding the booster on .then lift out the front of the car. .now remove the master cylinder from the booster . now chance to change the seals in the master cylinder get a seal kit lift the rod away. remove the cir-clip lift out the plunger change the seals . refit to new booster and refit. bleed the system.
How do i remove a brake booster located inside the vehicle
Hello. Remove the brake master cylinder from brake booster and position it aside. Disconnect vacuum supply hose from brake booster. Unfasten the brake pedal from the 'actuating rod' of the brake booster. Remove 4 bolts fastening the brake booster to the firewall. Remove brake booster from vehicle. Good luck and keep me informed; if you want to.
How to replace brake booster on 2005 Pontiac aztek
Step 1 - Locate the Brake Booster The brake booster is located adjacent to the master cylinder. There will be 4 mounting screws protruding through the booster. The booster is also attached to the brake pedal in the interior of the car. This is where you will start work in replacing the brake booster.
Step 2 - Remove the Brake Booster Start by locating the booster rod that goes through the firewall and is attached to the brake pedal on the interior of the car. Typically, there is a cotter pin that secures the rod to the pedal, but there may also be nuts. When removing any fasteners in the course of this job, make sure to retain the nuts, cotter pins, and various other fasteners as the new brake booster will not come with replacement fasteners.
Remove the fasteners, whether it is a cotter pin or nuts. Slide the rod off the brake pedal. Disconnect the vacuum brake line that connects to the booster. In the engine compartment, there are four bolts securing the booster to the master cylinder and firewall. Loosen and remove these nuts. Remove the nuts (there are usually 2 in addition to the 4 that have already been removed) that secure the brake booster to the master cylinder. Wiggle the brake booster away from the master cylinder. There is a seal between the two. You will need to keep this as the new part does not generally come with another one. Remove the brake booster.
Step 3 - Install the New Brake Booster Set the new brake booster on the four mounting screws. Tighten the nuts on the bolts to the master cylinder. Insert the push rod through the firewall. Start these by hand so that the threads are not ruined. Reattach the vacuum hose, then the nuts to the 4 mounting screws. Reattach the push rod to the brake pedal by whatever means it was originally secured with, whether by cotter pin or by bolts.
Step 4 - Bleed the Brakes You will need to bleed the brakes after replacing the brake booster
Replace brake booster
You will have to drain and remove the master cylinder. Remove vacuum lines from booster. Than disconnect your brake pedal from the brake booster. This in done from inside the car. After you disconnect your brake pedal, there should be four nuts that hold the booster the the bulk head. Remove those and carefully remove booster from car from under the hood. Install in reverse order and bleed your brake system.
Step by step instructions for replacing brake booster on a 1999 Toyota Camry
its my pleasure to answer your question how to replace the brake booster :
1 With the engine off, step on the brake pedal several times to relieve the brake booster of vacuum.
2 Press the brake pedal down and start the engine. Verify that the brake pedal sinks slightly. Turn off engine.
3 Remove the vacuum hose from the brake booster.
4 Remove the brake lines from the master cylinder. Remove the master cylinder from the brake booster. Plug the fittings to prevent brake fluid seepage.
5 Disconnect the brake pedal from the push rod.
6 Have an assistant hold the brake booster from inside the engine compartment. Remove the nuts that hold the brake booster to the firewall. These nuts are usually located under the dash on the interior of the firewall.
7 Remove the brake booster.
8 Install the new brake booster to the firewall. Tighten the mounting nuts.
9 Connect the push rod to the brake pedal.
10 Connect the vacuum hose to the brake booster.
11 Attach the master cylinder to the new brake booster and reconnect the brake lines.
.12 Bleed the brakes at the master cylinder.
How to remove brake booster on 1999 Toyota Camry
The following steps will help you to replace a Toyota Camry brake booster :
How do i replace the brake booster on a 98 Mercury villager
12 specific steps will help you :
10 Connect the vacuum hose to the vacuum brake booster.
2answers
Brakes
There should be two or four mounting bolts accessed from under the dash. Usually the booster has studs and you remove the nuts.
7helpful
Any info on changing a brake booster on a 1996 Sierra and also help trouble shooting a master cy. Thanxlinder
a defective master has just one common symptom, a soft sinking pedal.
Instructions Things You'll Need:
  • Nose pliers
  • Ratchet and socket
  • Ratchet extension
  • Slip joint pliers
  • Wrench
  • New cotter pin
    Removing the Old Brake Booster
  1. Step 1 Park your car in a safe place with enough room to work around the front and driver side of the vehicle.
  2. Step 2 Locate the booster push rod connected to the brake pedal.
  3. Step 3 Remove the cotter pin securing the booster push rod pin to the brake pedal using a pair of nose pliers.
  4. Step 4 Release the push rod pin from the brake pedal and slide the push rod off the brake pedal.
  5. Step 5 Unscrew the four mounting nuts off the brake booster studs using a ratchet, ratchet extension and socket. You should be able to see the four booster studs extending through the firewall, in front of the brake pedal.
  6. Step 6 Disconnect the vacuum hose from the brake booster, working from the engine compartment. Use a pair of slip joint pliers.
  7. Step 7 Remove the two nuts holding the brake master cylinder to the brake booster. Use a wrench or ratchet and socket.
  8. Step 8 Separate the brake master cylinder from the booster just enough to make room for booster removal.
  9. Step 9 Pull the brake booster off the firewall and remove it from the vehicle.
    Installing the New Brake Booster
  10. Step 1 Set the new booster in place by sliding the push rod and four mounting studs through the mounting holes on the firewall.
  11. Step 2 Slide the brake master cylinder flange over the two mounting studs on the brake booster.
  12. Step 3 Start the two brake master cylinder mounting nuts by hand to avoid damage to the threads.
  13. Step 4 Tighten the two brake master cylinder mounting nuts using a wrench or ratchet and socket.
  14. Step 5 Connect the vacuum hose to the brake booster.
  15. Step 6 Screw the four mounting nuts to the brake booster working from inside the vehicle. Start the nuts by hand to avoid damaging the threads.
  16. Step 7 Tighten the four mounting nuts using the ratchet, ratchet extension and socket.
  17. Step 8 Position the brake booster push rod over the brake pedal and slide the push rod pin.
  18. Step 9 Install a new cotter pin to secure the booster push rod to the brake pedal
How do you install brake booster on 1998 chevrolet suburban 1500
Press brake pedal several time to exhaust pressure from accumulator, Clean dirt from hydrulic line connections at booster and at master cylinder.Disconnect hydraulic lines from booster and plug all openings. Note; in most cases it is not necessary to disconnet master cylinder brake lines to remove booster.Remove and support master cylinder.Disconnect booster push road from brake pedal. remove booster to firewall nuts from inside vehicle.Remove booster and gasket
3helpful
Need to replace a brake booster on a 1998 chevy cavalier
get ready for some work.you need to remove the master cylinder nuts that hold master cylinder to brake booster.once you remove nuts you have 2 choices remove master cylinder to remove booster. to keep from bending brake lines.or you can leave master cylinder in pull it toward you easily careful dont bend lines .disconnect vacuum line at booster .go inside vechicle to floor on driver side loosen four nuts on floor to booster .disconnect power brake push rod from brake pedal .dont force pushrod to the sides when disconnecting it.remove four booster nuts then remove booster.when in stalling the new booster loosely install four nuts then connect the push rod to the brake pedal .install new clip tighten the booster unit .if you decide to remove master cylinder use inline wrenches on master cylinder to remove lines.also plug the master cylinder brake line holes to keep from losing all brake fluid.
Top Cars & Trucks Experts
ZJ Limited
ZJ Limited
john h
Arnie Burke
Arnie Burke
Are you a Car and Truck Expert? Answer questions, earn points and help others
