Question about Panasonic Televison & Video
High pitch squeal, buzz, no picture
Panasonic TV. CT-32G13W. The last few weeks I have to restart the TV several times to get it to stay on. Picture starts out with horizontal lines - like the really old tv's would get when you needed to use the horizontal set. Then the picture gets green, then b&w, then finally comes on and stays on. This morning I got a nasty high pitch squeal, no picture, and now a buzz. It is now unplugged waiting to go to the dump unless there is a rather easy solution. Cheaper to buy a new one than repair this. THANK YOU MUCH.
Tossed the television and put a new one in.
Posted on May 19, 2009
My tv powers on displays the LG logo then makes a high pitched squeal sound from speakers and then flashes on screen (strobe light effect) does not display picture or sound.
LCD TV Repair Tutorial - LCD TV Parts Overview, Common ...
? 11:05
https://www.youtube.com/watch?v=tS4sIpdajVw
Aug 23, 2013 - Uploaded by ShopJimmy.com
Repair review of common LCD TV Problems and Repair Solutions ... input the tv is set to it begins making a high pitched whiningsound. .... I have a LG 47LN5750 that powers on, flashes a good picture for about 1/2 second, then goes dark. ... hi my samsung tvis not turning on is black. and I just replace the ...
#Treat At Home high pitched whine from plasma tv Tinnitus ...
www.aspenridgerentals.com/tinnituscure/?...high%20pitched%20whine%...
LG 50PK540 plasma TV Repair power supply EAY60968801 Part 1-2 ... Sanyo DP42849 with high pitched squeal after replacing power supply. ... In my second daily fix video, I solve a mystery that was making me having to turn off my speakers before I went to be ... The flash is accompanied by an high pitched sound.
TV not turning on; making high-pitched sounds - Tom's ...
Dec 16, 2015 | LG 55LE5400 TV
50 " DLP makes a high pitch squilling sound and shuts off several times
Check and replace its color wheel. Contact any service technician. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy.
Feb 10, 2014 | Samsung DLP HL-P5663W 56" TV
Toshiba HD ready TV ct 90158 makes high pitched sound
A high pitch sound can be a capacitor losing power it would sound a bit like a fire work. most have back up on the board but it put more pressure on them the more times you use the tv. would check them and replace. all of them can be 5 in a row in some models.
Oct 23, 2013 | Toshiba Televison & Video
Partial vertical collapse, picture and buzzing sound
Check the solder joints on the vertical IC. If you reflow the joints and the problem persists replace the IC. Buzzing sound may be the flyback or something dealing with high voltage. Take the back of the TV off and see where the sound is coming from and see if you can see anything when you turn the TV on. Stay away from the TV and don't touch anything when turning it on.
Dec 28, 2012 | Panasonic CT-27G23 27" TV
5 year old goodmans tv suddenly went off, then intermittent high pitched squealing noises
Check the horizontal output section circuit. It sounds that the LOT {Line Output Transformer} has damaged.
May 11, 2012 | Televison & Video
I have this exact same problem asked by robert_a_962, but I don't see a solution. Any ideas? "By robert_a_962 on Aug 18, 2010 My Panasonic CT 32D32F picture went out, and now when I turn the...
The high-pitch squeal is from the power supply, caused by a short circuit. The usual cause is a shorted horizontal output transistor. I believe this model uses a 2SD1556, but I'm not certain. I don't have the service manual for this model, but that part is used in several other 32- and 36-inch models.
While the horizontal output can fail on its own, it's usually because of other problems. A large-tube TV like this is hard to work on, and you might want to let a professional technician check it and give an estimate for the repair.
Dec 05, 2010 | Panasonic CT-36D32 36" TV
High pitched noise
I am about to post a in depth guide about how to fix this problem. It's because a capacitor inside the TV has blown which causes the buzzing high pitched noise. It's really easy to fix however and only costs about £1 / $2 to sort out.
You can read a similar guide here http://www.fixya.com/support/r741402-polaroid_flm_373b_lcd_tv_black_screen but I will shortly be uploading a guide on the buzzing problem!
Dec 22, 2008 | Polaroid FLM-3732 Television
Panasonic 32" CT-32G13W
That's good you have time and patience.
You should have service manual and electronics knowledge to recognize and test / check parts in tv.
Problem is in Pin Out area of tv and you can have new parts from Panasonic Parts.
You can buy service manual from Service Manual net
Good Luck.
Dec 11, 2008 | Panasonic CT-32HXC14 32" TV
Sanyo TV buzzing
may be a problem with power supply.
Nov 14, 2008 | Sanyo DP42746 42 in. Plasma Television
Buzzing sound, no picture on my Panasonic TV
You might have a short causing the set not to start. Probably in the horizontal/high voltage circuit. The buzzing sound that you're hearing is the power supply overloaded. Stargazer
Apr 22, 2007 | Panasonic CT-27G23 27" TV
Televison & Video Logo
120 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
