Question about GE Monogram ZISB360DR 36'' Trimmed For Panel, Black Dispenser Refrigerator
Freezer not working properly
The freezer temperature is not getting cold enough to keep things frozen. when you touch the front panel walls surrounding the freezer, they are burning hot. I moved the freezer temperature dial to max cold but still not working.
    President:
  • 1,902 Answers
Your heating element has failed and needs to be replaced, the heating element keeps your coils from icing up and in return when then go bad cause this problem.
Posted on May 16, 2009
How do I keep my refrig/freezer from defrosting in the winter when store in the garage.
There is only one source of cold in many refrigerators. If yours is a top freezer, then most likely it is in the freezer.
But the thermostat that you set temperature with is in the refrigerator, not the freezer.
In the cold garages, what can happen is that the refrigerator stays cold enough that it does not call for cold. So the freezer does not get enough cold.
The freezer control works by diverting cold air into the freezer WHEN THE RERIGERATOR HAS TURNED ON THE COOLING. If it is not turned on, oh well.
The best you can do for this is to put both on max cold. Then the refrigerator will call for more cold at a lower temperature, and the freezer will get it more often and will divert more when it is cooling.
This can result in the refrigerator freezing things too. You can try raising the refrigerator setting JUST A LITTLE and see if both work, but keep freezer on max cool.
This works for my situation, but ambient temperature fluctuations in the garage make this dicey. We don't put things like lettuce in the refrigerator in the garage in the winter because freezing damages them.
Good Luck
Feb 05, 2015 | Refrigerators
Ge refrigerator is not cold enough and ice is not working
What is the model number?
The ice maker will only run if the freezer is at the correct temperature.
Do you see any ice buildup on the back wall of the freezer or behind it?
Nov 27, 2012 | Refrigerators
FREEZER NOT FREEZING PROPERLY
There could be a large list of things that cause the freezer to warm up from the temperature it was before. The most likely reason is you probably have a defrost problem. Defrost heater, defrost thermostat and the defrost control are all things that may have failed. If your model is not a frost free let me know. Look inside freezer for a layer of frost building on the rear wall. If your refrigerator is not defrosting it will be a short time before the fresh food compartment begins to warm. To extend the time your refrigerator and freezer can keep food safe defrost by placing a bucket of hot water inside the freezer and close the door. Please place food from freezer and fresh food compartment into another refrigerator or cold storage area. By keeping doors shut as much as possible the refrigerator and freezer will last up to a week this way before defrosting again, Sea Breeze
Sep 12, 2012 | Hotpoint Refrigerators
Freezer turns of in cold weather
Many residential refrigerator / freezers are designed to work at temperature considerably above above freezing. Most modern refrigerator / freezer have a single electric thermostat - located in the fresh food compartment. This lone thermostat will control the compressor to keep the fridge (fresh food) section at the desired temperature (usually between 34 - 38 degrees F). The freezer will get colder regardless of how cold it is already whenever the fridge thermostat turns the compressor on.
Now that you see how the thermostat works, let's look at what happens when the fridge is placed in an unheated space - like a garage. In winter time, the temperature can drop considerably below 38 degrees. If the outdoor temperature remains cold enough, for long enough - it will affect the thermostat in the fridge. The temperature inside the fridge could drop below 38 degrees, preventing the thermostat from telling the compressor to turn on. Meanwhile, the temperature in the freezer compartment slowly rises from the normal -10 to 0 F degrees. It will continue to rise until it is the same temperature as the fresh food compartment or until the thermostat in the fresh food compartment tells the compressor to turn on again. This means the freezer contents will thaw.
If the temperature in the garage is even in the 40 to 50 degree range, the loss of cold in the fridge may not happen often enough to keep the compressor coming on often enough to keep some freezer items frozen solid - such as ice cream. Remember, water freezes at 32 degrees F, other products may require lower temperatures to remain frozen, and could thaw at 28 or other temperature.
Feb 13, 2012 | Refrigerators
Ge zisw48dyb hot to touch on middle bar front between doors
Pull the refrig out and remove the lower panel . Check that the fan motor is working and no object is blocking the blade to keep it from turning . If your compressor is a top model , remove the top cover and check the fan motor and coils for dust coverage .
May 01, 2010 | GE Monogram Side by Side Refrigerator
The freezer isn't cold enough to keep the food frozen
hi there,
eventually 4 years service gaurantee have been reached,but defend how you use your refigerator you can still check the thermostat if working properly or it may need to replace,occasionally thermostat is the one controlling your freezer temperature it may be defective there are several way you can check this
by removing this but this should be done by certified
refrigerator tech.If you have the tech ability and you can do it or bring thermostat to service center have check this one,If the thermostst was good.Check the compressor condition if working at its maximum effeciency.this should be done by certifed tech.have a good day and please dont forget to rate me.
Feb 21, 2010 | Refrigerators
Freezer is working OK but fridge is warming up - would this likely be a control board problem?
Not likely. Assuming you have tried adjusting the temperature control, a more likely suspect would be a problematic evaporator fan. This fan is located (usually behind an access panel) in the freezer. Its purpose is to move cold air throughout the freezer and the refrigerator. If the fan fails, there may be enough cold air to keep the freezer cold; but there is not enough to keep the refrigerator at the proper temperature.
If the fan is running, you should be able to hear it. If you can't, open the access panel and look at it. If it's not turning, you likely need to replace the fan motor.
Oct 18, 2009 | Samsung RB2155 Bottom Freezer Refrigerator
Fan runs constantly and does not keep temp cool enough
forst on the back wall means you have a defrost problem or a air leak aroudh the door gasket-mike
Mar 16, 2009 | Hotpoint 21.7 cu. ft. Side-by-Side...
Fridge part not working on Whirlpool Arc 7050 Fridge Freezer
If this is correct:
1. No ice build up on back of freezer wall.
2. Fan in freezer is working.
3. Items in freezer are frozen, ice cream is a good test.
Then:
Why is the cold air in the freezer not getting over to the Ref. side?
1. There is a channel (tunnel) from the freezer to the Ref, side and there is a door which regulates how much cold air from the freezer goes through to the Ref. side.
2. The control panel may have it labeled as "Freezer" setting, from cold to coldest. The coldest setting means the door is almost closed and will keep most of the cold air in the freezer.
3. Since your control panel is not working then this door must be almost closed keeping all or most of the cold air in the freezer.
Any service tech should be able to check the control panel and find the problem.
Jan 25, 2009 | Refrigerators
Amana neither fridge nor freezer getting cold enough
the defrost system has failed. to get it working temporarily, take the back panel off inside the freezer. melt ice off with a hairdryer.
after that, fault can be in several areas - defrost heater, thermal fuse or the main pcb
Jun 30, 2008 | Refrigerators
GE Monogram ZISB360DR 36'' Trimmed For Panel, Black Dispenser Refrigerator Logo
178 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
