On my projector my 3d facility has stopped working for no reason when I go to settings it says 3d off and nothing else is highlighted. I haven't changed any settings either
Did you check the 3d adapter that came with the projector. It may have come unplugged. 2nd try sending a 3d signal to the projector then enabling the 3d.
You Just Need A New PC With An Intel Pentium Prossesor Because E Machines Is A Piece Of Junk No Offence But Im Just Being Honist With You And Of Course It Does Not Work!
Did you try flashing the EDID ROM ? You need a .bin from another h5360 user.
Try reading this post, two links available of people posting some.
I gave you the link of the post 'cause I thought you might wanna read it.
It seems to work, as a lot of people are saying that it does.
you need to be connected to a 3d source when you try and switch and it must be playing 3d media before the projector would even try and im sure you know you need to be connected via hdmi for this to work, so grab a 3d dvd player and a 3d capable hdmi cable and a 3d dvd and then try it--Good Luck.
Your DTR-7.8 receiver is not 3D compatible. It does not support the new 1.4 HDMI. You have to have 1.4 HDMI and 1.4 cables for the 3D format.
You can bypass your receiver for the video though. Simply run your HDMI cord (1.4) from your Blue Ray to your Projector. Your audio can be ran from your Blue ray to your reciever.
open the projector (6 inset screws on bottom) - carefully rermove the top (there are 2 wire sets attached: one for the speaker and one for the control panel) -- make sure all wire sets are properly seated -- i had one loose set -- reseated it, closed the projector and the thing wotks fine now. every repair facility i called didn't want to deal with the projector, and one person told me i ought to buy a new one
