Question about Magellan RoadMate 700 GPS Receiver
Unit keeps losing power. Cord has power light and
700 RoadMate keeps losing power. Cord has power light and I have tried it in several vehicles and it continues so I know it is not the power source of the car.
  • surene May 19, 2009
    My Magellan RoadMate 800 has a broken power pin which can't be fixed. The unit is in perfect condition but doesn't power up since battery cannot be charged. Please point me to a solution. I really appreciate it!
If it does what my Roadmate 9212T-LM do, it is not a power problem. On mine, partial power loss in the circuitry causes the problem to screen to blank in few seconds to few minutes. I can pull lighter plug out then in, picture comes back; instead of rebooting; which means computer stays up but losing graphic. I traced down to the uP6615A3 chip loses 3.3V on one leg but I can't find any info on the chip anywhere. the chip gets warm then, the leg loses 3.3V which causes screen to go black. it is worse( doesn't last) in the cold morning. anyone with uP6615A3 info will help me troubleshooting further.
Posted on Jan 29, 2015
I had the same problem. It was the pin inside the **** clamp that was broken. As I wiggled the plug in the unit the pin would dislodge. eventually the pin got lodged in the 12v power cord.
Posted on Jun 07, 2009
Our magellan keeps turning off. the plug seem loose. could it be the cord or is it the battery and can it be changed
Check your power cord. You may be losing power at the plug. When plugged in it may be losing contact with the recepticle. The power indicator light initially comes on but, breaks contact and therefore stops charging the unit. If this is the case you can sometimes plug into an adapter and get a tighter fit.
Apr 25, 2011 | Magellan Roadmate 1200 Car GPS Receiver
My Roadmate 700 will not stay on. It loses power
if its the port on the cradle, you can buy them on ebay cheaper then fixing it.
Jun 30, 2009 | Magellan RoadMate 700 GPS Receiver
Power wont come on
get a new unit like any magellan mastreo series 4000 or higher or roadmate 800 or higher,i had a 700 they start having alot of problems after i did my research on here.i have the mastreo 4000 and the roadmate 800 both work great.
Feb 23, 2008 | Magellan RoadMate 700 GPS Receiver
The most obvious question is, have you accidentally turned down the volume to a level where it can't be heard. There is a volume wheel on the unit. Also, there is a way that the sound can disappear if the unit gets "locked up". But that shouldn't be a persistent problem. Removing the power cord and reinserting it should clear that problem.
Dec 09, 2007 | Magellan RoadMate 700 GPS Receiver
MAGELLEN ROADMATE 700 NO POWER
One of the wires in your power cord could be broken. If you have the a/c adapter, see if you can power up with that. If you know someone else with a working Magellan, you could borrow his cord to test your unit.
If not, check the car adapter with a continuity tester. Put one tester probe on one of the side springs of the car plug and the other probe on the outside metal of the GPS plug. If that shows continuity, place one tester probe on the end tip of the car plug and the other inside the the GPS plug.
If either of those do not show continuity, first take apart the auto side of the cord. Check the fuse and the wire to contact solder joints. If they seem okay, carefully cut back the molded plastic from the GPS end and examine the wire to solder joints. If any are broken, replace the cord or resolder the joints.
Nov 02, 2007 | Magellan RoadMate 700 GPS Receiver
Road mate 700
The flash card hole is supposed to be empty - all you need should be on the hard disk BUT the first Roadmate 700 I purchased was empty i.e. no software loaded. The second failed due to bad power connection, the third worked but was factory refurbished! what a crass organisation Magellan is!!!
Try fiddling with the power connection that goes into the cradle that the unit sits on. The power connection is ultra sensitive. BUT, if you've only just bought the unit then you are in luck - return it and get your money - back Magellan Support is extremely poor.
I am binning my Roadmate and getting a Tomtom720 Go series with maps and cameras preloaded - it auto updates when it is on its cradle attached to my PC/internet.
Bin the Magella - 4 years of problems!!!!
Oct 24, 2007 | Magellan RoadMate 700 GPS Receiver
Keeps seeking but no GPS positioning
get a new unit like any magellan mastreo series or roadmate 800 ,i had a 700 they start having alot of problems after i did my research on here.
Sep 06, 2007 | Magellan RoadMate 700 GPS Receiver
Magellan Roadmate 700 does not power on
Hello, Rafster! Cigarette lighter plug problems are not uncommon, and - hopefully - this is the source of your problem. Because the green LED on your plug is lit, it would suggest that the FUSE inside is okay. Still, it's worth checking! The plug is easy to open, and the fuse easy to inspect/replace. IF the fuse is okay, the cord itself or the plug end that attaches to your Roadmate could be damaged. In order to determine this, you would have to check for voltage at the output end. But, you'd need a circuit tester and a wee bit of electronics knowledge to test it. If you don't have access to a tester, then the easiest test is to simply purchase a NEW cigarette lighter cord. You can get them at most retail discount stores (BestBuy; Circuit City; WalMart; etc.); RadioShack; or directly from Magellan. They're generally less than $10.00!
Jul 20, 2007 | Magellan RoadMate 700 GPS Receiver
Yes, get a new car connector. -Daniel
Apr 23, 2007 | Magellan RoadMate 700 GPS Receiver
Lost power- will not come back on
If you have a multimeter you should be able to check the out voltage on the powersupply to make sure the power cable isn't at fault. You may also try wigling the power cord a little bit to see if the unit will then get power. If so you have a faulty powercord. If there are any fuses they should usually be accessible from the outside; that's the point with them - they should be easy to change. I would put my money on the power cable. If you have access to a diferent power source try that out. If the unit works with a different power source your power source is at fault. If it still doesn't work the problem is within your unit. Check to see if any pins on the power source and/or the units power plug might be bent or dirty.
Mar 07, 2007 | Magellan RoadMate 700 GPS Receiver
Magellan RoadMate 700 GPS Receiver Logo
259 people viewed this question
Top Magellan GPS Experts
Jungle Ghost
Jungle Ghost
Are you a Magellan GPS Expert? Answer questions, earn points and help others
