Question about Gaggia Classic Espresso Machine
Cleaning the "showerhead" on a gaggia expresso machine
How do you clean the showerhead, I used steel wool to clean the built up coffee on it, but I still do not see light through most of the pin ***** holes
    President:
  • 1,902 Answers
Take it off, and heat up a pan of boiling hot water and add 1 cup of vinegar to two cups of boiling water. Once the water starts to boil, shut off the stove, and put the head in the pan, cover the pan and let it sit for about 30 minutes to 1 hour. Afterwards wash it really well then you will be good to go. The head does twist off
Posted on May 16, 2009
Gaggia titanium coffee slow coming out of machine
Not sure it will work for you but Our Bunn has a flex wire to run thru the tube weekly , and if we do not clean that tube it might take 20 minutes to make a pot where when cleaned it does 12 cups in 3 minute
Nov 26, 2015 | Gaggia Titanium Espresso Machine
I got problem with my expresso coffee machine, its 2 handle group, one handle leaks water n0n stop when the machine is on, what can dat be
Hi, It the group solenoid behind the leaking group. Try giving it a good back flush or remove the solenoid, pull it apart and try cleaning it. If you have a Boema machine, just replace the solenoid. Dazza
Sep 11, 2011 | Gaggia Titanium Espresso Machine
I use an oily bean with my Gaggia Brera which has the integrated grinder on it. I know this may eventually clog up the grinder; and so, is there a way to clean the grinder without taking it apart? Is...
Oily beans means the coffee is old and/or over roasted. I reccomend using fresher beans. i recommend buying less coffee more often. i usually use a paper towel and wipe out the "hopper" where the beans sit.. hope that helps
Mar 07, 2011 | Gaggia Expresso Machine
Water will come out of the steam wand but not out of the showerhead - There is a mere trickle from the shower head
Remove the screw and screen and clean. Burn out coffee from screen using an open flame or stove.
Nov 23, 2010 | Gaggia Classic Espresso Machine
I'm trying to clean my gaggia classic. Got the
The central part is the group head it id held in by two hex head screws.
You will need to remove this first to change the group gasket.
Feb 09, 2010 | Gaggia Classic Espresso Machine
Gaggia evolution not producing coffee
One question before I make any suggestions: If you remove the shower screen and screw, do you get a nice flow of water or is it still steam?
If you get a nice flow of water, then check your screen hold it up to the light and you should be able to see through the tiny holes, if not, get a pair of needle nose pliers and being very careful hold screen over an open flame like the stove burner. The coffee will burn before the anything happens to the metal. When it is cooled screw into group and see if the flow of water is better.
If you get nothing but steam then it is time to descale the machine.
Feb 27, 2009 | Gaggia Evolution Espresso Machine
Gaggia cffee machine will not pump water through th coffee
my gaggia coffee machine, will not pump water trough the coffee. I see the water going back in the reservoir. I used the cleaner cafiza, but no help. Please help.
Thank you
Jul 06, 2008 | Gaggia Classic Brushed Stainless Steel...
Coffe groungs drawer full of water
when you make ourself a expresso do you have the same amounth of coffee or it mush lower if recently you clean the machine inside check if you screw or put back everything at there right place let me know thanks for using fixya pierre
Feb 11, 2008 | Gaggia Titanium Espresso Machine
Gaggia Classic Espresso Machine Logo
326 people viewed this question
Top Gaggia Coffee Makers & Espresso Machines Experts
Henry  Thomas
Henry Thomas
Shehu Pro
Shehu Pro
Are you a Gaggia Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
