Question about Toshiba Satellite 220CDS PC Notebook
I erase some programs and now can't start up windows 95 i try the copy system.dat and all stil don't work
  • 60 Answers
Insert you os disk and repair it
Posted on May 16, 2009
How can I copy files using Windows XP onto a Quantum CD72LWH DAT tape drive?
With the drive came software, for certain operating systems. If you don' have a program with your quantum, perhaps you try a program from NovaStor. and hope they do also deliver the drivers you need for working with that drive. Inform first, because the NovaStor software is not for free. I don't know any free ware backup software you could use to test the drive first.
Nov 05, 2014 | Quantum CD72LWH-SST (768268020788) DAT...
Tip
How to Backup and restore the registry
In case you go and modify the registry manually and you want to back it up in case something goes wrong and you want to restore it, this is perfect for you.
Backup:
1.) Go into the start menu and click "Run".
2.) Type "cmd" and click OK
3.) type in the window "copy c:\windows\system.dat c:\windows\system.000" and press enter.
4.) Once Complete type "copy :\windows\user.dat c:\windows\user.000" and press enter.
You have now created a backup of the registry.
Restore:
1.) Go into the run menu again and type cmd.
2.) Type in the 2 commands that was shown in the backup section except in each command swap the twon directores.
(e.g.) "copy c:\windows\system.dat c:\windows\system.000" will become "copy c:\windows\system.000 c:\windows\system.dat"
Whatever was backed up when you created the backup file will be restored to the windows registry.
on Dec 26, 2009 | Computers & Internet
Tip
How can you backup and restore the Registry?
Maintaining the Registry
Windows 95
Microsoft included a utility on the Windows 95 CD-ROM that lets you create backups of the Registry on your computer. The Microsoft Configuration Backup program, CFGBACK.EXE, can be found in the \Other\Misc\Cfgback directory on the Windows 95 CD-ROM. This utility lets you create up to nine different backup copies of the Registry, which it stores, with the extension RBK, in your \Windows directory. If your system is set up for multiple users, CFGBACK.EXE won't back up the USER.DAT file.
After you have backed up your Registry, you can copy the RBK file onto a floppy disk for safekeeping. However, to restore from a backup, the RBK file must reside in the \Windows directory. Windows 95 stores the backups in compressed form, which you can then restore only by using the CFGBACK.EXE utility.
Windows 98
Microsoft Windows 98 automatically creates a backup copy of the registry every time Windows starts, in addition to this you can manually create a backup using the Registry Checker utility by running SCANREGW.EXE from Start | Run menu.
What to do if you get a Corrupted Registry
Windows 95, 98 and NT all have a simple registry backup mechanism that is quite reliable, although you should never simply rely on it, remember to always make a backup first!
Windows 95
In the Windows directory there are several hidden files, four of these will be SYSTEM.DAT & USER.DAT, your current registry, and SYSTEM.DA0 & USER.DA0, a backup of your registry. Windows 9x has a nice reature in that every time it appears to start successfully it will copy the registry over these backup files, so just in case something goes wrong can can restore it to a known good state. To restore the registry follow these instruction:
[list=1]
* Click the Start button, and then click Shut Down.
* Click Restart The Computer In MS-DOS Mode, then click Yes.
* Change to your Windows directory. For example, if your Windows directory is c:\windows, you would type the following:
cd c:\windows
* Type the following commands, pressing ENTER after each one. (Note that SYSTEM.DA0 and USER.DA0 contain the number zero.)
attrib -h -r -s system.dat
attrib -h -r -s system.da0
copy system.da0 system.dat
attrib -h -r -s user.dat
attrib -h -r -s user.da0
copy user.da0 user.dat
* Restart your computer.
Following this procedure will restore your registry to its state when you last successfully started your computer.
If all else fails, there is a file on your hard disk named SYSTEM.1ST that was created when Windows 95 was first successfully installed. If necessary you could also change the file attributes of this file from read-only and hidden to archive to copy the file to C:\WINDOWS\SYSTEM.DAT.
Windows NT
On Windows NT you can use either the "Last Known Good" option or RDISK to restore to registry to a stable working configuration.
How can I clean out old data from the Registry?
Although it's possible to manually go through the Registry and delete unwanted entries, Microsoft provides a tool to automate the process, the program is called RegClean. RegClean analyzes Windows Registry keys stored in a common location in the Windows Registry. It finds keys that contain erroneous values, it removes them from the Windows Registry after having recording those entries in the Undo.Reg file.
on Dec 02, 2009 | Computers & Internet
Except handler4 common msvcrt.dll
Download the DlL file here:
http://www.dll-files.com/dllindex/dll-files.shtml?msvcrt
Extract msvcrt.dll from msvcrt.zip. Copy the extracted msvcrt.dll to the installation directory of the program that is requesting msvcrt.dll.
C:\Windows\System32 (Windows XP, Vista, 7)
If problem stil occurs then use system utility tool like Reginout for an instant fix.
Dec 04, 2012 | Microsoft Windows XP Professional
I own the DK Multimedia "My Amazing Human Body" CD, version for use with Windows 95. I am unable to use it with my Windows XP operating system. I understand that you might offer an upgrade...
In your case..the fix is to run the program in compatibility with windows 95..
Insert the disk ..and after that if it let's you install it is great ..Install it ..and after that click on the icon (right ) choose compatibility ..and in there tick the case that says "run this program in compatibility mode for : " and choose windows 95 ..
If it do not want to install it at all ..repeat the same thing with the execution icon on the disk ..
Insert the disk ..than in my computer folder..locate the cd icon ...click right on it ..select compatibility ..than tick same case...to run it as windows 95..and will work ..
In case the feature is not available cause the program is on disk and can not accept properties changes...click right on the icon of the cd ....choose explore... and it will reveal all that it has inside..
Copy all files in another folder on your hard disk ..in a location of your choice ..Than the properties will be able to be changed..and repeat the operation I says ..Locate the executable icon ...click right /properties//compatibility ..and select to run in compatibility with windows 95 ..and there will be no more issues..
Jul 25, 2011 | Global Software Publishing My Amazing...
Tip
Fixing Corrupt Registry
If your registry has gotten corrupted, and re-installing Windows95 over your existing version does not fix the problem,
there is a hidden, read-only, system file on the root of your boot drive called SYSTEM.1ST.
This is the initial system registry created when you first installed Windows95.
To use this file:
Go to your Windows directory
Un-Attrib your current SYSTEM.DAT file (attrib -r -s -h system.dat)
Copy your current SYSTEM.DAT to something like SYSTEM.BAD file (just in case)
Move to your root directory
Un-Attrib the SYSTEM.1ST file
Copy SYSTEM.1ST to \WINDOWS\SYSTEM.DAT
Re-start your system
You will need to install your 32-bit apps and any other programs or changes that modified your system registry
but you will not need to go through a new again. Your 16-bit apps should not need to be re-installed since they do
not modify the registry. You will also retain your current desktop configuration.
on Apr 27, 2008 | HP Pavilion a1410n (ER890AA) PC Desktop
How to solve the problem"*.exe
This error is generally an indication that the written program isn't designed to be run in the 32 bit windows environment, the program is corrupted, or an error occured while trying to run the program. It is generally due to an older program being run within windows.
The newer windows versions are mostly 32 bit platforms. Some of the old programs from windows 95 and 98 eras won't work because they are 16 bit programs. Examples may include older programs with a .com extension (which will bring up this error message), or old versions of .exe's written for 16 bit environments.
If the program you are attempting to run is a recent program (came with your version of windows XP or later) then it could be an error at execution or the program is corrupted. If the program is written by a major brand and is relatively new, contact the program's technical support number for help.
If you suspect a program error, try and obtain another copy of the program. Uninstall the current copy of the program, restart your computer, then install a fresh copy. If the error continues after doing this, then contact the program manufacturer's technical support number.
If the program you are using is one of the programs from within windows, (from the system 32 folder for example, and include notepad.exe, msconfig.exe, or other programs that can be selected and run from within this folder) do NOT remove or copy over the program. Some of the programs within the windows sub-directories are older 16bit programs, not designed to run within the 32bit platform. It is recommended to NOT remove any of these programs from the windows sub directories.
Jan 12, 2011 | Computers & Internet
I hv windows7 ultimate in my computer bt its activation has expired. On desktop its written dat this copy of window is nt genuine. So wat to do further to get my system error free. Kindly suggest any...
i hv windows7 ultimate in my computer bt its activation has expired. On desktop its written dat this copy of window is nt genuine. So wat to do further to get my system error free. Kindly suggest any solution so dat i may nt loss my data and free. inf me on y email shin_dragon_pke@yahoo.com help is need ASAP
Jul 02, 2010 | Computers & Internet
I am trying to copy a folder and when I do I get a message that says cannot copy mpdata.dat : Its being used by another person or program. I whent to task manager it does not show up there. So I am trying...
yes, u can use a porgrame called "system explorer", there is  a portable version of it 2, download it, when its loaded u can see all the prosesse, click on the opened files tab on the right, u will see all the opened files, and the prosseses using them and the infos u need....
if u want to copy the files, u need to stope all the prosesses using it....or u can access it with another operating system or livecd....gd luck
May 11, 2010 | Microsoft Windows XP Professional for PC
Lord of the Rings: Battle for Middle Earth 2 game.dat file error
if it said dat.exe error, then u should reinstall your LOTR again...it is because the system is crash..b4 reinstall, try to locate your save folder, copy it and save to other location...after reinstall, paste it back to the same location that u copy the save data. n then u can continue your mission without start again..
May 26, 2009 | Electronic Arts The Lord of the Rings: The...
Toshiba Satellite 220CDS  PC Notebook Logo
32 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
