Question about Hotpoint Dryers
Not Pumping water to reservoir
Hotpoint cdt40g condensor dryer working but not pumping water to reservoir. All pipes are clear. Any ides?
Fixed this problem by removing the back and side panel and simply clearing a build up of fluff from the channel that feeds the water from the condensor unit to the reservoir. To do this I had to open the plastic unit that houses the pump by simply unclicking the top section and clear this and also clear the entire base section. Dryer now not leaking and drying much quicker.
Posted on May 21, 2009
Hotpoint condensing dryer model TCFS93BGP. cleanfilter/empty water light keeps coming on after 3/4 minutes
Hi, my dryer has 3 things to check out of which one is more hidden:
- empty the water reservoir
- clean filter in the door
- clean condensor which is hidden below the bottom panel which has to be released through a button behind the door
The last one is less obvious and more difficult to find/reach. Might need to consult the manual.
Did you check all 3?
Hope this helps
Mar 25, 2016 | Hotpoint Dryers
Hi. Can anyone tell me how you take the top off a Hotpoint CDT40G dryer?
there is two screws at the back top each side remove them then lft slightly and with the heel of your hand hit it forward you will find it will move forward and lift off.
Sep 17, 2014 | Hotpoint Dryers
Hoptoint CDT40G condenser tumble dryer pump running no heat or movement
hi i have a ctd40 mine wouldent go a few years ago on the heater i had three stats on one of them there is a tiny hole i pushed a sewing needle in hole it reset the stat you can see if you look at bottom of stat it might be concave so pushing it out set it again dryer then worked pull plug first
Apr 29, 2013 | Hotpoint Dryers
Not filling water tray,condensating all around dryer
hi is condensor box nice and clean in bottom
Feb 15, 2013 | Hotpoint Dryers
Fault code F05
If Hotpoint or Creda,
F05: possible draining (pumping off) problem, check the pump filter, or pump, outlet pipe, or U-BEND.
Jan 18, 2010 | Hotpoint Aquarius WD640 Front Load...
Hotpoint condenser dryer ctdoo
water pump at the back of the machine at the right hand bottom corner has either been blocked up with gunge which can me easily cleaned or the pump is not pumping, replace the pump
Aug 24, 2008 | Dryers
HOTPOINT AQUARIUS CONDENSER TUMBLE DRYER CTD40
There are three water reservoirs - one at the bottom behind the condenser, a second at the back bottom of the machine and then a third at the top which is the one you would normally pull out to empty.
There is a hole at the bottom of the filter in the first reservoir (at the back of the condenser) which leads to the second reservoir at the back. If the hole gets clogged up with lint/muck then the reservoir at the back does not fill up.
So to solve this, unplug the machine, take out the condenser (front left bottom of the machine) reach through to the back and mop up the spare water with a towel and check that the hole to the back reservoir - you can feel this it is towards the right side at the back of the machine is clear from muck.
Once you have cleared it, water will flow to the second reservoir and then (once you switch on the machine) up to the main removeable reservoir at the top.
Hopefully this helps. GB
Jul 09, 2008 | Dryers
Hotpoint Aquarius WD440: IT seem when it supposed to pump the dirty water out,the waters are not coming,but if i take the pump and put down on the floor ,the water are coming out and it run the whole spin...
If you are getting voltagae to the pump and the water is not pumping out then you have a bad pump, just replace it and you have the problem solved, If you do not have voltage then we would have to find out why.
May 11, 2008 | Hotpoint Aquarius WD640 Front Load...
Hotpoint aquarius wf740
Sounds like water pressure could be low or inlet pipe is kinked.
F04: possible filling or water level problem. Check water inlet pipe (or shut-off valve), or the outlet pipe, or the pump or pump filter if accessible (check for blockages or foreign objects). Also could be the water valve solenoid weak, causing filling to be too slow.
Don't forget to rate!
Feb 27, 2008 | Hotpoint Aquarius WD63 Front Load...
Dryers Logo
216 people viewed this question
Top Hotpoint Dryers Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Dan Webster
Dan Webster
Are you a Hotpoint Dryer Expert? Answer questions, earn points and help others
