Question about HP Compaq nc8000 Notebook
Connect a soyo desktop monitor to my nc8000 notebook
Ive connected the monitor via vga, and have enabled the second monitor in display settings, but all i get on the crt monitor is the mouse pointer
Are you able to drag items over to the other monitor? Such as a window or desktop icons?
Posted on May 17, 2009
I would like to hook up my old monitor, product LT782s, model 700P, to my new monitor so I can have duel monitors. The cord has 2 screws to attach. The new monitor does not have any place for a "scr
You need to connect both monitors to a computer. Monitors do not daisy-chain (in general). The exception are some SCART-enabled monitors.
What is your source (desktop)? What is the make/model of your new monitor? Please add a comment with the video outputs/inputs for your source and second monitor.
Many newer desktops have two or three outputs. (Some video cards have display port outputs which with active adapters can support 2 monitors each.)
If your computer has two or more outputs and your new monitor has an input compatible with the extra output, get the appropriate DVI, DVI-HDMI or HDMI cable for your new monitor. See the next section if both monitors have VGA input.
If you have a desktop with only one video output, you may be able add a video card to support two monitors. (Depending on your computer, you may need to upgrade the power supply to support a video card.) Then get the appropriate adapter or cables to add the second monitor. (Note: if both of your monitors have only VGA inputs, check the specs for video cards carefully. Not all modern cards support analog outputs on their DVI, HDMI or Display Port connections. These digital outputs would require a digital to analog converter to give the VGA out.) However, if one of your monitors will accept DVI digital signals and the other VGA, add a card with one of each of these connections and a DVI cable to match. (This is an if needed extra; many monitors still ship with only a VGA cable.)
Then turn off your computer, open it and add the video card. Install the drivers with only one monitor attached. Then power down the computer and connect the second monitor. Turn on both monitors before turning on the computer again. Most of the time, the second monitor should be recognized (by Windows) and the appropriate refresh rate and resolution chosen. If not, you may need to enter the Display settings to set the monitor up.
I have seen some computers/video cards where only one output is initially enabled. You may have to go into the device settings to enable it. (Laptops often need their external video ports enabled in the BIOS.) Bad video ports/cards/cables do happen so RMA if needed.
The USB video adapter, http://www.newegg.com/Product/Product.aspx?Item=N82E16812225007 , can be added to a desktop to give a second VGA output but it isn't the best solution. USB bandwidth limits are significantly lower than those for a PCIe x16 slot or an old AGP slot.
I hope this helps. Please add more information about your system if you want more assistance with this problem.
(who has done dual monitors with older and newer computers. My old Pentium 4 with a Radeon x1350 video card was fine for driving a VGA monitor and an HDMI monitor (using a DVI to HDMI cable). My second generation i5 and P8Z68 motherboard system is also fine using the on-CPU video graphics for those same monitors. A video card would improve gaming but isn't required.)
Dec 13, 2012 | Computers & Internet
Hotkey functions on Advent4211C
Connect the external monitor via VGA, (blue connector) or via HDMI.
Double click the Nvidia control panel, bottom right of screen.
Under Display heading:
Select "Setup multiple displays".
Now set display for primary (notebook display)
Set external display as the one you want to use.
Take care!
damnor01
Sep 12, 2012 | Advent 4211c Notebook
Why doesn't my laptop display when I hook the VGA cable to the projector
If the vga connection does not display the image it means the secondary display is not enabled into your computer ..Go to the image settings in control panel ..(the driver settings for the video card..)..open them and look for the option for enabling the second monitor ..It will start a wizard and you have to choose the mode and settings fro it ..(by mode I mean choose how you want to be displayed as clone ...or extended...first will clone the monitor and the second one will extend the monitor and you can even run different applications )
Also be sure you have the video driver installed cause if it works with the windows generic driver will not have all features for it ..and will not work )
for most laptops..the enabling of secondary monitor is possible when you press Fn+ the F key indicated with the monitor sign ..(it can be F4 or F5 or F7 ) ..
Aug 28, 2011 | HP Compaq nx9030 Notebook
Hi there basically I have two ports on my monitor dvi and vga and dvi is connected with another appliance so that leaves me vga but when I connect my vga to my desktop the computer is on but there is no...
try with DVI port and see it works or not.
if worked buy a converting port (DVI to vga) and connect you video card Via DVI
and connect your other appliance Via VGA port by that converter.
Jan 09, 2011 | Computers & Internet
My laptop monitor has vertical lines all across it, so I have an external monitor, how do i connect it to the laptop
Connect the VGA cable to the VGA port of the laptop then restart the computer.
Go to display properties and enable the second screen, then disable the notebook screen to display only on the external screen.
Nov 18, 2010 | Computers & Internet
I just got the Gigaware 2 port usb powered vga splitter and I have ywo monitors connected. Both monitors show the same thing but I want to extend the desktop across both screens, however Windows XP does...
A display splitter will only mirror the screens, you cannot extend the desktop via a splitter.
Most portables cannot support dual monitors without a docking station.
Jan 07, 2010 | Computers & Internet
I have a Gateway mx3422 notebook. I cannot get the display to clone when I hook it up to a projector. The notebook screen goes black and the display shows on the projection screen.
hi!!!
there is a setting in your desktop
try go into control panel
then click on display then go to
settings and the
advance try locate the dual monitor settings
Oct 31, 2008 | Computers & Internet
Connecting to Pioneer pdp 4270xd
  1. Go into Start->Control Panel
  2. Open up Display Properties
  3. Navigate to the last tab
  4. Enable your second monitor from this tab.
You can also change your external monitor settings if you have the nVidia graphics chip by right-clicking on your desktop and selecting the nVidia Displays Manager.
Mar 26, 2008 | Toshiba Satellite Pro M15-S405 Notebook
Acer notebook VGA problem
Not sure about your model as the header is Dell D600 and you mention Acer but the solution is probably the same. You need to enable the 2nd display - I'm assuming you are running XP. Go to display settings -easiest way is to Right click on the desktop, bringing the display menu and Left click on Properties (bottom entry). Then click on Settings and you should see 2 screens and you will need to enable the 2nd monitor and set up how to display on it. Additionally there is a setting in the BIOS that enables both display outputs.
Feb 19, 2008 | Dell Latitude D600 Notebook
Trying to connect Inspiron 6000 to TV
If there is no display on your TV, HDTV, or Projector, please make sure that all of your connections are set up properly and that you have enabled the display in the Catalyst Control Center. The connectors that you will be using would be Svideo for TVOUT, DVI-to-HDTV (Component video), VGA-to-HDTV (Component video) for HDTV, and DVI, VGA, or Svideo for the projector.
737-22474-1.jpg Here are the steps to properly setup and enable TV, HDTV, or Projector:
  • Turn off your PC and your TV, HDTV, or Projector.
  • Ensure that your card was installed correctly, as per the Getting Started Guide.
  • Determine if your TV, HDTV, or Projector has a S-Video (for TV), YPbPr for (HDTV), or VGA/DVI for Projector.
  • Looking at the back of your PC, locate the needed connector or the supplied adapter cable; attach one end of the cable to your graphics card and the other to your second display.
  • Turn on your second display then your PC.
If you are connecting an HDTV to your video card, please Click here for detailed instructions on how to set it up correctly.
Starting Windows with TV or Projector Display Enabled The TV screen may become scrambled during the initial Windows® logo display. This is only a temporary effect and your screen will be restored within a few seconds. During start up, your RADEON will go through a sequence of mode settings, during which your TV display will remain blank. This process takes only a few seconds and helps program the TV display.
  • To enable the second Display
  • Right-click anywhere on your desktop
  • Click Catalyst Control center
  • View
  • Advanced view
  • Display manager
  • Detect Displays
  • You should have the second display picture under “Attached displays currently disabled
  • Drag it to the box on top of it
  • Apply
  • OK
If for any reason the second display does not get detected, please do the following:
  • Open the CATALYST CONTROL CENTER
  • Go to Display options
  • Check “Force TV detection” *
  • Apply
  • OK
* Force TV: Allows you to force TV detection if the ATI driver does not automatically detect TV-out connected to the graphics accelerator.
Possible issues:
In case the users display does not natively support HDTV display timings in the EDID, you can add standard HDTV modes so that the usual HDTV resolutions (720p, 1080i, 1080p) are listed in the Display Manager resolutions. You can also create custom HDTV timings to solve any kind of over-scan options (for cases when the windows desktop appears to not fit on the HDTV screen, and the outside boarder is cut off).
For more information on connecting your second display to your Video card, including supported output device combinations, please refer to your user’s manual.
Jan 23, 2008 | Dell Inspiron 6000 Notebook
HP Compaq nc8000 Notebook Logo
79 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
