Question about Frigidaire FRS26H5AS Side by Side Refrigerator
Keeps Running/Food Not Cold
Frigidaire-Model FRS26ZPH Keeps running and food is not as cold as it should be. I pulled it away from the wall and vacuumed/cleaned all the crud from behind and underneath as best as I could. Thanks in advance.
Bob,
Check the freezer side and see if there is ICE BUILDUP BEHIND the rear panel. If there is you can remove the panel and with a hairdryer thaw out the freezer coils. That should make it run properly, BUT you have either a problem with the defrost unit OR the Temp Control Unit for the refer side. I don't know how to test either unit to see if they are working though.
Posted on May 16, 2009
FRS26KF6EMK FRIGIDAIRE SS SIDE BY SIDE,stopped cooling,why?
There are many reasons for these symptoms. Feel the compressor top, is it too hot to keep your hand there? Look into the back of the freezer and tell me what type of frost pattern is on the rear wall? If the compressor won't start it could be because of a defective
Run Capacitor 5304464438
Start Device 241707712 APPLIANCE 911
Freon leaks or failed compressor can also cause the same symptoms
May 23, 2016 | Frigidaire Refrigerators
Why wont my fridge stay cool?
MAKE SURE THE FAN IN THE FREEZER IS RUNNING THATS THE ONLY WAY THE REFRIGERATOR STAYS COLD DO YOU HAVE AN ICEMAKER IF YOU DO IS IT WORKING OR A DEFROST PROBLEM ANY ICE OR FROST BUILD UP IN THE FREEZER
IF YOU SEE IT ON THE WALLS ITS FULL BEHIND THE WALLS OF THE FREEZER
Jul 11, 2014 | Frigidaire Refrigerators
My Dometic RM2852 regiferator is freezing food and there is no manual temperature control.
I have found that certain types of food will freeze when left against the back wall of the refrigerator, which is where the cold air circulates down from the freezer..moving it away from the back wall can help...
Dec 16, 2012 | Dometic Refrigerators
MCBR1020W is the model number for the refrigerator in my apartment. The refrigerator fresh food unit is not getting cold enough to keep food cold, this results in food spoiling. What could be causing this...
You could have the lack of air flow or a door seal problem. Could you check the freezer for me, look for frost on the back wall. If not frost, is the fan running in the freezer?
Please get back to me
Sep 08, 2011 | Magic Chef Refrigerators
Food defrosted pulled away from wall improved then defrosted again. Un plugged for day in case frozen somewhere, plugged back in and worked for a day. Now defrosted again. At times fridge has frozen food...
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator
Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Feb 23, 2011 | Frigidaire Gallery Series GLRT83TEK 30"...
I have a FRS26ZPH Fresh Food Compartment is not getting cold? sjvoss58@comcast.net
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Aug 25, 2010 | Frigidaire Refrigerators
My refrigerator is about 7 years old and it doesnt seem like its staying cold. my food is not as cold as it should be and stuff in the freezer keeps thawing and refreezing and the ince is melting together
may not be the issue, since so many issues can cause these problems
but try pulling it out and cleaning the back wall and coils behind it
just think you might be running a lil hot from air flow issues
Oct 06, 2009 | Refrigerators
Whirlpool Refrigerator fresh food section cool but not cold (freezer ok).
The most likely problem is in the defrost system. Behind the freezer panel there is not only an evaporator fan, but also the evaporator itself, and a defrost heater, termination bi-metal, and drain pan (or trough). You will likely find ice build-up in the evap coil. This could be caused by the defrost timer, the heater, or the termination bi-metal.
Have a service tech look at the unit.
May 28, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
WARM REFRIGERATOR
Check the freezer side back wall, do you see Ice forming on that wall?
If so you have a defrost issue. Also check to make sure you fan in the freezer side is running. If not, than cold air from the freezer cannot make it to the fresh food side.
I am factory authorized for Frigidaire Appliances and am confident I can assist you in this repair.
Bill
May 12, 2008 | Frigidaire FRS3R5EMB Side by Side...
Frigidaire FRS26H5AS Side by Side Refrigerator Logo
172 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
