SOURCE: 1999 Olds ignition switch problems
Hi....
In your Intrigue to use the New Passcode sensor .
You need to program the new Passcode to the ECM. of the Vehicle.
This is a prosses that involve around 30 minutes maybe a little more.
Remove the old Ignition switch.
Install the new Ignition switch. with the new Passlock sensor.
Turn the key to on position and try to start a few senconds. them leave the key on run position.
For 10 minutes and NOT more than 11 minutes.
Them turn the key to OFF position for exactly 30 seconds.
Them turn the key to Run position 10 minutes or 11.
them turn back the key to OFF position for 30 seconds.
Them turn the key to Run position 10 minutes or 11,
Turn the key to OFF position and wait 1 minute, them try to start the vehicle.
If the car start you are DONE.
But if Not Letme know to give you more information.
OK I hope this help to try solve your problem.
Thank you for use fixya...
SOURCE: 99 olds intrigue ignition switch problem
You have to replace the ignition system, all the 99's came with an anti theft unit built in. The ignition is built into the system, so that could be the reason why.
SOURCE: is it a timing belt on olds intrigue 2000, 3,5L?
this engine uses a timing chain, chains require no replacement unless the engine is being repaired or the chain or spockets fail
Testimonial: "Thanks."
