Question about Dryers
Older kenmore electric dryer. Smells hot.
Almost smells like wet/hot. clothes come out a lot hotter than usual. very hot to the touch. cleaned vent and lint tunnel. have back off and cleaning any stray dust/ lint/hair in body of dryer.
It's older than the 8 years that we've been here.
Any ideas? Temp controller? Timer? Element?
    President:
  • 1,902 Answers
This is not a element problem, this is either a High temp or Timer going bad. If you could give me the model and serial number that would help more or you can go to repairclinic.com and just order the two parts and replace both of them. They are fairly cheap and very easy to install yourelf
Posted on May 16, 2009
Clothes smell after drying
I don't think the problem lies with the dryer, I would suspect the washer has mold, this is especially true on front load washer, they make products designed just for this problem, check with a large retailer, not sure who makes the mold and mildew remover, I think Home Depot or Lowes may have the product or know about it..
Jan 29, 2012 | GE Profile DPXH46EA Electric Dryer
Clothes remain wet after multiple times through drying cycle; the "AF" warning lamp is on as well.
AF= Air Flow: there is a restriction; check to make sure that the lint screen is clean,and that the door seal is in place and the vent isn't obstructed, just disconnect the vent and run the dryer, if it clears its the vent tube if not feel the back of the dryer with it running should feel hot/warm air continuous, if not feeling a lot of air, the you will need to take the dryer apart and clean all the lint off. if all checks out good then the control board. Hope this helps Tim
May 22, 2011 | Whirlpool Cabrio 7.0 Cu. Ft. Super...
Dryer not drying clothes, have had a small load in for over 2 hours still wet....
Hello s cissy. If the clothes are hot but not getting dry you probably have lots of lint accummulated in the vent pipe which is stopping the wet air from escaping to the out-of-doors. To solve this pull out the dryer, unplug it and then disassemble the vent pipe from the lower back of the machine. Clean out the inside of the pipe and the interior of the machine where the pipe connects.
If the clothes never get warm to hot, then you most likely will have to replace the heating element. Get back if that is the case and we can talk you through that repair. Joe
Thanks for choosing Fixya!
Nov 22, 2010 | Fisher and Paykel SMARTLOAD DE62TG1...
Dryer is running longer than usual, it's tumbling,
no make listed here...I would pull the hose off the back of dryer and see if a lot of air is blowing out of vent. if not, heres your answer a clogged filter area ..if air blowing out leave vent hose off and dry clothes with vent off for one cycle. if clothes dry with vent hose off..you have a venting issue and need your vent cleaned out...
May 15, 2010 | Dryers
My neptune dryer makes all my clothes reak. I have cleaned the air vent out and I didnt see any dead cats or anything like that. Clothes smell like they have been in the dump. They come out of the washer...
You may have lint mildewing in the vent. Take the vent tube off the back and reach in the back and see if there's lint stuck in there. Clean the vent tube also. Use a dryer sheet to help with the smell
Jul 18, 2009 | Dryers
Natural gas dryer running too hot
I suspect you have a blocked air vent. A blocked vent will make you dryer run hot. Most vents get blocked by lint near their exit to the outside. There's usually a screen at this location to prevent small animals from crawling into your house. Often this screen gets clogged with lint. Most vents are designed to allow removal and cleaning of this screen from the outside.
Jun 07, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Dryer turns, heats up but won't dry
check the outside of your house to see how strong the blowing is if it's weak then it's in the vent tube
Jan 25, 2009 | Bosch Nexxt WTMC3321US Electric Dryer
Clothes not drying even after 4 cycles
you have to check your dyer vent hose and vent pipe to outside for any restrictions. #1 problem for extented drying time. it like having a backed up sink
Dec 13, 2008 | Maytag PYE2200 Dryer
GE profile prodigy - dyer
hi. the vent inside the dryer needs to be cleaned.you must live in a warm climate. clean all air vents inside the dryer, and out. thanks the appliance doc
Oct 04, 2008 | GE Profile Prodigy WPSE4200A
Whirlpool dryer wed5700sw
you need a dryer vent brush first,bought at home depot cheap,and clean the entire vent to the house,then clean where the vent hooks up to the machine,if your filter is where your door is pull out the filter and stick the brush in there and pull out lint,also use your vacume,remember you let some lint out when you let the hose blow out but theres a lot more there to clean,and also unplug your machine as you do this,if this helps please give me a fix ya vote
Jul 14, 2008 | Whirlpool Dryers
Dryers Logo
87 people viewed this question
Top Dryers Experts
