Question about Abit A17 Guru Motherboard
Hard drive What hard drive should use with abit-a17 uguru motherboard
  • 193 Answers
Re: Hard drive
U can use any hard drive seagate or samsung but u need to configure the hard drive
Posted on Oct 16, 2007
0 characters
3 Points
When I boot up I get one long beep up to 4 seconds long. If I keep trying the machine will boot up and work normally.
the beeps are post during post the very first work is done by the ram,all the memory in the ram is first transferred to the hard disk,and remains active untill turned off.
make sure that your RAM is securely seated
test or replace all the leads that attach to your hard drive make sure the connections are secure including electrical extensions + IDE,SATA the ones that attach from your
((motherboard to hard drive))
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty or just replace them they are probably old and faulty ?
hope this helps
Feb 13, 2011 | Abit A17 Guru Motherboard
UGuru and 64-bit Vista?
First of all, are you using the most recent version of uGuru? Previous versions did not work under Vista. The current version is 3.104. You can download it here: Assuming you have the newest version, can you get me the exact text of the error message? That would make it easier to troubleshoot. -Dyllan
Oct 06, 2007 | Motherboards
Driver genius pro is a good driver finder you could probably find a free one if you google for a torrent
Apr 05, 2010 | Abit A17 Guru Motherboard
No sound
try installing these drivers
for xp
for vista
Nov 29, 2009 | Abit A17 Guru Motherboard
Os install won't let me
Okay, this is elementary, but I've forgotten some pretty basic things before.
1. You've cleared the RTC?
2. Made sure you have the latest bios copy in it?
3. Gone into set up and set the computer to boot from the DVD before the hard drive? (If it's set to still boot from the hard drive first, it won't boot up)
4. Made sure the drives are properly defined?
By the way, does NT 4.0 run on Fat 32 or NTSC?
You don't happen to have a master/slave problem the way your drives are set up do you? Just trying to think of anything that might foul the install.
I think it sounds more like a hard drive problem with the way it is set up rather than the motherboard. I hope that is the case. Let me know how it goes.
May 12, 2009 | Abit A17 Guru Motherboard
Abit AN7 motherboard does not boot - POST code AF
i think thats memory so try removing your ram and re installing it. maby its not pushed in all the way.
May 09, 2009 | Abit AN7 Motherboard
Have a Abit A17 mother board that posting a 25 or 5D error code
I picked this up from an abit forum, It appears that it is quite common, look here,
Dec 21, 2008 | Abit A17 Guru Motherboard
Hey anyone can help me with some info
Well it will not hurt you're board if that's what you want to know. Depends what devices you have plugged into the board. If you're running 4 serial ATA SATA's. Two CD/DVD drives. A floppy drive & an AGP 8x graphics card. The 400w should do just fine. (You can never run too high a PSU source).
I'm running 4 serial ATA 7200rpm SATA's, 2 DVD-ROM's, a floppy drive. 1 PCI-E graphics card. Four, 4" case fans. Skt 939 Dual core 4200+ CPU & my 550w has been stable for over 2 years.
Have a great weekend!
May 30, 2008 | Abit A17 Guru Motherboard
Abit Guru Ai7 Hard Drive Problem
Simply....... no. Once formatted it's reinstall time.
You can load you're windows cd into the cdrom drive & try to get windows to load. If you do get the cdrom to load - (Press any key to load from cd...... ) & press any key. Once in windows setup ( DO NOT format the drive) but do reinstall windows, if windows see's another windows on your drive, great install over it. If windows does re-install it's self you should have enough time to install burner software & back up your personal data to CD or DVD before your partition looses it's cookies & shuts you down.
You can also leave it alone & install another drive & setup windows complete & slave it back into you're system for IDE.
SATA's are all master drives. Than copy your data back to you're new drive. In these cases I always suggest the user go to the web site of the hard drive & download the Mfg's bootable software tool's/setup utilities. Windows is not perfact at formatting.
Apr 08, 2008 | Abit A17 Guru Motherboard
Abit A17 motherboard error codes
check your ram and also clean yopur processor case reattach it.
then restart pc.
Mar 31, 2008 | Abit A17 Guru Motherboard
Abit A17 Guru Motherboard Logo
60 people viewed this question
Top Abit Motherboards Experts
Brian Sullivan
Brian Sullivan
Matthew Spark
Matthew Spark
Mark Taylor
Mark Taylor
Are you an Abit Motherboard Expert? Answer questions, earn points and help others
