Question about HP PAVILION DV4000 SERIES 100GB HARD DRIVE - 383488-001 CD-ROM Drive
HP dv4000 how do i open the laptop case to replace the motherboard?
  • Anonymous Sep 30, 2008
    hiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiii
    Genius:
  • 1,601 Answers
Black screen hp pavilion dv4000
not sure on this for sure but it sounds like what the dv6000 did or does and the motherboard needs replaced.
Sep 12, 2013 | HP Pavilion dv4000 Notebook
Hp dv4000 won't turn on, no lights on- totally dead
first check fuse in plug. if good then check power adaptor, even if its lit up it still can be faulty or use a voltmeter to check that you are getting continuous current. if good it gets harder youll have to open it up and check the fuse inside it dont look like a normal fuse its small. its at the back next to were you plug in the charger should say f. check picture. its not for youre model but just a demonstration. hope this helps. j.oates
Nov 16, 2012 | HP Pavilion dv4000 Notebook
How do I remove the motherboard in my dv4000 laptop
check out this link hope it helps (http://www.ehow.com/how_4853565_replace-motherboard-hp-pavilion-laptop.html) or u can try youtube...
Jun 10, 2011 | HP PAVILION DV4000 AND V4000 SERIES...
Hello, i have hp pavillion 4 laptop but when i power it the caps lock and num lock keys keeps blinking and the display screen is also blank.
This is a very common problem & it affects the Hp dv2000 , dv4000 , dv6000 , dv9000 series of laptops . In almost all cases this is caused by the video card overheating . There are 2 options , one is replace the motherboard ( expensive ) , the other is performing a " reflow " similar to how xbox 360's & ps3's are repaired . After the " reflow " you should replace the thermal paste with Arctic Silver #5 & I clean out the heatsink & fan before replacing them . Good Luck if you attempt the 2nd solution , I have done it about 20 times so far only 1 failure .
Apr 16, 2011 | HP Pavilion dv4000 Notebook
How to remove battery on motherboard on hp pavillion dv4000
hi
which bettery u wnat remove
if u looking to remove cimos bettery then in this model you have to open from the keybord penal if you well noon in this then only
or go to technition
May 15, 2010 | HP Pavilion dv4000 Notebook
How to open the case to replace the mother board in HP DV4000
Download service manual from the following link
http://h10025.www1.hp.com/ewfrf/wc/manualCategory?lc=en&dlc=en&cc=us&lang=en&product=468789&
The first one in the list is the service manual for your system.
Mar 07, 2010 | HP Pavilion dv4000 Notebook
Replacing hp dv4000 motherboard
Hi I suggest you go to the HP site at the link below and select your particular version and then seek out the manual for it.
But system boards are very expensive and tricky to replace. if you are not experienced in laptop repairs then forget it. It's really not worth the effort of replacing the system board unless you can get a good used one.
Just buy another laptop and get your data transferred. Go for a used Dell D610. Excellent machines, about 4 years old now but I sell loads and NEVER had a problem. Good build quality, unlike most of todays laptops
http://h20180.www2.hp.com/apps/Lookup?h_lang=en&h_cc=uk&cc=uk&h_page=hpcom&lang=en&h_client=S-A-R135-1&h_query=hp+dv4000&submit.x=3&submit.y=4
Dec 10, 2008 | Computers & Internet
I have HP DV4000 has a bright problem but cant get fn keys to work
Reinstall all drivers for your laptop from the HP.Com website. If the function keys still don't work, you may have a defective keyboard.
Turn the laptop off, then take the laptop keyboard off (usually takes 1 screw - bottom of case, and a few sliders, top of keyboard). And then there will be a couple of thin cables which are connected to the motherboard. There is a sliding connector which holds these on. Push this up, slide the cable in, puch it back down. Do for both cables if you have 2 (keyboard and tracking pad/pointing stick). Reinstall keyboard and try it out.
If that doesn't fix it, replace the keyboard with one from ebay.
Dec 06, 2008 | HP Pavilion dv4000 Notebook
HOW TO REPLACE HP DV4000 MOTHERBOARD
Check out the manual, located here:
http://h10032.www1.hp.com/ctg/Manual/c00530488.pdf
Check under the Removal and Replacement Procedures section.
Replacement for the Full Feature Motherboard can be found here:
http://www.getpartsonline.com/396696-001.html?source=googlebase&code=396696-001
Nov 25, 2008 | HP Pavilion dv4000 Notebook
Motherboard replacement for hp dv4000
could be the CPU , and could be another defective motherboard , check both ....also check the memory too.
Jun 24, 2008 | HP Pavilion dv4000 Notebook
Computers & Internet Logo
1,431 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
