Question about Kenmore HE2 Plus Front Load Washer
Washer is stuck on spin and the door wont open. It is locked.
Kenmore he2 washer is stuck on spin and the door wont open. It is locked.
  • 15,935 Answers
This advice is for Kenmore Elite and Whirlpool Duet model front loading washers. If you experience a problem where the door becomes jammed and will not unlock or open, here's an easy way to gain access inside your washer WITHOUT calling the repairman.
1. Remove the lower panel under the door by loosening the three screws under the bottom edge on the front of the washer. HINT: If you prop up the front feet of the washer with some small blocks of wood, this will make access to the screws much easier.
2. With the screws removed, the lower panel should drop down then come off. If the panel sticks, a light tap on either side will knock it loose.
3. Reach your hand up inside the washer behind the front casing on the right-hand side. This is where the door latch assembly is located.
4. At the bottom of the door latch assembly is a small pull tab. This is the manual release for the door. Pull the tab straight down and the door will come open.
Sometimes these doors will not unlock for whatever reason. If there are no error codes being generated, this could have just been a momentary glitch. If you see "Fdl" "DLE" or "Fdu" error codes, these are usually indications of a failed door latch assembly and will require replacement.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 11, 2010
Lights keep flashing and door locks without finishing cycle
Kenmore HE2 Plus Front Load Washer Keeps unlocking ...
www.fixya.com > ... > HE2 > Kenmore HE2 Plus Front Load Washer
flashing prewash and add garment lights My HE2 Plus will fill with water, but when ...Kenmore HE3 2plus wont finish cycle Washer wont finish the last1 minute of cycle. ...We ran a load twice and it still did not unlock. du is the code for cannot ... Why does the door keep unlocking and locking in between the drum rotating?
Admiral, Whirlpool, Maytag - Washer Repair - Not ... - YouTube
? 5:51
https://www.youtube.com/watch?v=oBihToN6dxs
Sep 6, 2013 - Uploaded by ApplianceVideo.com
Troubleshoot your Admiral Top Load Washer that has these following symptoms: Not Completing all Cycles ...
Washing machines - Ariston
Jan 05, 2016 | Washing Machines
Open locked door
To open the door when locked. Start new wash cycle and the door will lock - unlock then lock again. when it unlocks open the door quick.
Feb 15, 2015 | Kenmore HE2 Plus Front Load Washer
My washer say f28 it is a kenmore HE2 plus
"F28" means your washer is locked and not unlocking. To unlock your washer take the bottom access panel off by removing the 3 bottom screws.Reach up near the latching assembly & attached to the door latch is a little plastic pull lever. Pull down on this lever and open the door. Unplug your washer for 60 seconds and plug your washer back in. If the error re-occurs you need to replace your door lock.
Thank you!!
Jul 18, 2010 | Kenmore HE2 Plus Front Load Washer
I want to unlock my door
Manually Unlocking the Door Lock System
1. Unplug washer or disconnect power. 2. Remove the lower kick panel. 3. Reach up along the inside of the front and locate the bottom of the door switch/lock unit. 4. Located on the bottom of the door switch/lock unit is a tear-drop shaped tab. 5. Gently pull the tab down about a ¼" or until a click is heard. 6. The door may be opened.
Apr 12, 2010 | Kenmore HE2 Plus Front Load Washer
The machine lock light will not come on. The door is shut.
Try and shift the knob to spin sometimes it opens.... Otherwise use the red tab to open door!!
Jan 15, 2010 | Kenmore HE2 Plus Front Load Washer
Kenmore model 44142400 door lock
Try unplugging for 2 minutes and if display looks the same, then theres and elec. issue.
Mar 08, 2009 | Kenmore HE2 Plus Front Load Washer
Kenmore he2 front load washer
remove bottom panel open pump port and ck for foreign objects lean washer toward rear wall this will help help keep water toward rear and reduce flooding floor might try opening door first and dipping out as much water as possible with bottom panel removed reach up to lock area there is a tear shaped plastic peace pull it down to release door
Jun 02, 2008 | Washing Machines
Kenmore HE2 Plus Front Load Washer Logo
363 people viewed this question
Sal DeAngelo
fordexpert
Mike Squire
