Question about Amana AFD2535DES French Door Refrigerator
My Amana AFD2535DEW freezer problem
My Amana AFD2535DEW freezer is making a clicking sound that stays on for approximately then stops.  The refrigerator is holding temperature at 38-41 degrees but the freezer is at 40 degrees.  A few days ago when it was doing this I unplugged it for an hour then plugged it back in and the temp in the freezer got to 0 degrees.  It is like it is stuck in the defrost cycle.  The freezer setting is 4 and the frig setting is 4.
  • 447 Answers
Sound like the compressor is having trouble starting. You can purchase a RCO810 to assist the compressor's start winding. If the unit is under 5yrs there should be some warranty (no electrical parts) left in the compressor. It will need to be replaced.
Posted on Oct 16, 2007
SOURCE:
How can I get my freezer door handle to stay on?
If the screws are still good, put some "lock tight" on them and tighten. This should fix the problem
Jun 17, 2014 | Amana AFD2535DEW - 25 cu. ft. French Door...
Repairing freezer drawer slides on amana afd2535dew
if gear wheels are out of sink, give it a good twist till equil.
ifb it is the ballbearings in the rails replace hole rail, wize to do both sides at one time.
Apr 07, 2014 | Amana AFD2535DEW 25 french door bm...
I have an Amana AFD2535DEW. It is over a year old but the top has quit cooling, but the freezer is OK. It did this before, but I was told to let it sit over night with out opeing it. That seemed to...
Mine did the same thing about two years ago. It turned out, my problem was the little motor that opens the vent in the refrig portion to let the cold air in from the freezer went bad. A&E service tech said this was common. Cost about $90 to fix. Haven't had the problem anymore.
Aug 03, 2010 | Amana Easy Reach AFD2535DE Bottom Freezer...
Amana AFD2535DEW - Freezer compartment is operating fine, but refrigerator compartment is not getting any cold air, even though both compartments are set at "4". The baffel is open were the cold air would...
either the evaporator coil behind the freezer compartment wall is iced over and you can';t move cold air over an iced up evaporator coil to cool the refrigerator compartment or the compressor relay/overload is bad
Jul 25, 2010 | Amana AFD2535DES French Door Refrigerator
MY amana refrigeratior is making a loud clicking
fan blade hitting ice or something like that. check blades to make sure not ice on them. nedd check blade clearance.
Mar 04, 2010 | Amana ARB9058CS Bottom Freezer...
Amana AFD2535DEW freezer/refrigerator with intermittent tempurature swings
I had the same issue. It was the relay overload which essentially provides the extra boost to get the compressor going. The switch tries for about 10 seconds before giving up and then retries 3 - 4 minutes later. In the early stages of failure, eventually it will work and the compressor will kick on. But eventually the switch will fail and will just cycle through the 10 second attempt every 3 to 4 minutes. The part is about $35 - part number 67005560.
Jun 26, 2008 | Amana AFD2535DES French Door Refrigerator
Amana AFD2535DES French Door Refrigerator Logo
256 people viewed this question
Top Amana Refrigerators Experts
Sal De
Steve Allison
Steve Allison
Carmen Mikulic
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
