Question about GE 24 in. Profile PDW9880JSS Built-in Dishwasher
Dishwasher will not start
I have a GE profile dishwasher that will not start and none of the setting lights are working
  • Anonymous May 17, 2009
    Water fills but the cycle will not start.
    Problem Solver:
  • 14 Answers
Check your receptacle where the d.w. is plugged into with a voltage tester if it works then un plug the d.w. and take the bottom front panel off.there is a small box where your power cord connects to..usually it has a 1/4 or 5/16 screw holding it closed.Open the box and check to see if the wire nuts are tight.This is usually where the connection is lost
Posted on May 16, 2009
  • Bobby Burgett May 16, 2009
    Chec your breaker first,and also if you have a gcfi receptacle in your kitchen check to see if it needs to be reset.
My GE dishwasher is showing an E8 code...my dishwasher will not start. What can I do?
Maybe try unplugging it for a minute or so and plug it back in.
Jul 26, 2016 | GE Dishwashers
GE Profile GSD4010202AA Built in Dishwasher acts as if no power
1. turn breaker off to diswasher. 2. remove bottom access cover. 3. remove cover over electrical connection box on right side. 4. hold each wire nut connector and firmly tug on one wire at at time to make sure none of the wires pull out of the wire connecor nuts. A loose connection here is more common than you might think.
If those are all OK, turn breaker back on and make sure you have power there. (120 volts black to white) If that was OK, then check door latch switch inside door at the top center and wires passing through door at the bottom of the door.
Jul 26, 2010 | GE Dishwashers
GE profile PDW9880J00SS dishwasher just beeps
appears control is going bad,or problem with control circut
Oct 16, 2009 | GE 24 in. Profile PDW9280JSS Built-in...
Electricity went out last night. when i get up this morning, it is making a high pitch squeeling noise and now none of the buttons work????? its a ge profile dishwasher
The electricity probably "surged" when the power came back on. It sounds lke the conrol board may have "fried". Call the repairman and get an estimate.
Mar 29, 2009 | GE 24 in. Profile PDW7800 Built-in...
Buttons won't work on GE Profile PDW7980N10SS
You have the control lock activated. Press and hold the heated dry pad for 5 seconds and it should unlock it
Nov 15, 2008 | GE Profile PDW8400J Built-in Dishwasher
I talked with a GE techy, and was told to either turn off the circuit breaker or unscrew the fuse for the power to the dishwasher, wait 45 seconds, then turn the power back on. GUESS WHAT? IT WORKED!!! try it.
Mar 17, 2008 | GE 24 in. Profile PDW7800 Built-in...
No lights on the control panel
check the thermal fuse at the control panel, the door switch, or the electronic control.
Mar 07, 2008 | GE 24 in. Profile PDW9880JSS Built-in...
Problem with GE Profile Dishwasher
My delay start switch does not work and the dishwasher beeps periodically throughout the day. Also, I have it set for a 109 minute cycle and after about 20 minutes it says that I only have 35 minutes left in the cycle! Any suggestions?
Mar 04, 2008 | GE 24 in. Profile PDW9280JSS Built-in...
GE Profile PDW8800
Try replacing the water inlet valve.
Nov 12, 2007 | GE 24 in. Profile PDW7800 Built-in...
GE 24 in. Profile PDW9880JSS Built-in Dishwasher Logo
286 people viewed this question
Top GE Dishwashers Experts
Mike
jdthefixer
Dan Webster
Dan Webster
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
