Question about Gateway GM5259E PC Desktop
Screen goes off showing VGA with cable on the screen
I have GATEWAY COMPUTER MODEL GM5259E. My screen goes off after 1 munite. showing VGA with cable tip in the screen.
    President:
  • 814 Answers
This looks like a bad cable connection. Try using a new cable for the connection between the computer and monitor. If that does not work test you computer on another monitor to make sure you are getting signal output from the video card.Also check the monitor on another computer.This is to check and make sure the monitor is working properly.You can also try using a add on video card in the computer to see if you can use the monitor this way.If you still are having problems. You can use this web address to get customer from Gateway. http://support.gateway.com/s/PC/R/1013953/1013953nv.shtml. I hope this helps you with your problem.
Posted on May 20, 2009
Black screen on a gateway ma7 laptop
Bluescreen can be caused by a number of things Check all power and data leads from motherboard to hard drive and all of your cd/dvd drives make sure connections are secure dust free and not faulty computers need all power and data to travel through every working device and to finish its cycle so any faulty lead will end in computer error or shutdown / fail to boot or to reboot on a cylce Make sure your computers RAM modules are securely seated with no dust in the sockets also the Cmos battery has charge and seated with no dust in the sockets some motherboards cmos batteries are soldered in might be getting hot check your CPU make sure it has a thermal paste and a dust free and secure seating Could be a memory dump you might be running to many programs at the one time placing to much strain on the CPU you might not have enough RAM random access memory If you get your computer running to get a screen or even do it in safe mode Restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer If done properly the user should get to a screen similar to the below screen. Select the option for Safe mode command prompt only Windows Advanced Options Menu
Please select an option: Safe Mode
Safe Mode with Networking
Safe Mode with Command Prompt Enable Boot Logging
Enable VGA mode
Last Known Good Configuration (your most recent settings that worked)
Directory Services Restore Mode (Windows domain controllers only)
Debugging Mode Start Windows Normally
Reboot
Return to OS Choices Menu Use the up and down arrow keys to move the highlight to your choice. select the safe mode option You might have to many programs trying to or accessing the internet at the same time scroll to bottom toolbar (bottom of screen) right click select task manager applications you will see whats running if you see anything you dont need running select end now and you might uninstall that specific program if you or computer does not require it to run and some unnecessary programs that could be jamming up your computer also under processes see what is ticking over in the background again if you see something you dont need to be running select end now and users you will see who is using your computer
you might need to add more computer ram if you're not sure if a module is right for your system use the Crucial Memory Advisor tool for a list of guaranteed compatible modules. when purchasing any ram you should always ask if they can guarantee compatibility first you will need to select the manufacturer from a drop down list then select your product line from a drop down list then select the model then click find it will take you directly to compatible ram also you will have an option to scan your system might be getting hot check you CPU make sure its securely seated and has thermal grease http://www.hardwaresecrets.com/article/Thermal-Compound-Roundup-February-2012/1490 or it might be a virus right click in bottom toolbar select task manager applications to see what is running and processes to see what is ticking over http://windows.microsoft.com/en-US/windows/products/security-essentials/product-information malware protection http://100-downloads.com/download.php?p=615 windows xp microsoft security essentials http://100-downloads.com/download.php?p=614 windows 7 microsoft security essentials
Feb 26, 2013 | Computers & Internet
I have a Gateway NV53 laptop. The screen doesn't seem to turn on. It's been a year now and the screen hasn't turned on yet. However, it did turn on last week after I left it to charge for an entire da
WARNING: Before you start troubleshooting remember that you are dealing with electricity that can KILL. http://www.kitchentablecomputers.com/static.php - rules Only work inside the computer case when the power has been switched off and disconnected. Never open the power source. Some of the below steps recommend removing physical parts within the computer. While in the computer it is highly recommend that you be aware of ESD and its potential hazards Remove the memory modules from their slots. Take the opportunity to clean the slots on the motherboards and the memory module connectors. Use compressed air to blow dust away and clean contacts with a soft cloth. Do not use a metallic vacuum cleaner if it touches any component it may create a short and cause damage to the motherboard or other components. Do not use solvent that may attract dust and never poke things like cotton buds in to slots. lightly rub an alcohol (Methylated Spirits) on a cloth not to hard let the alcohol do the work on the copper gold or silver tabs and r Allow the pins to dry. They will air dry in a matter of minutes. If reseating the memory did not resolve the issue try swapping the location of the memory. If you have only one stick of memory in the computer try moving it to another slot and then boot the computer. Check the memory module and memory slot contacts. They are either copper tin or gold. The colour will tell you which they are. Mixing tin and gold can result in corrosion that prevents proper contact. Look for any sign of physical damage to the memory module, memory slots or the motherboard. Reseat the memory modules. You should hear an audible click when they are in place. Do not use too much force to reseat the memory module in to the slot this can cause damage to the module, slot or motherboard. The hardware that you are trying to access is damaged or failing.
The device drivers for the hardware are faulty or incompatible. Could be a problem with the Hard Drive or the Hard drives PCB http://www.onepcbsolution.com/ http://www.youtube.com/watch?v=du0Qd_3wFWM There is a connection problem such as a bad cable for internal hard drives
Test all power and data leads that attach to your hard drive SATA
the leads from your MOTHERBOARD TO THE HARD DRIVE make sure they have a secure dust free connections and are not faulty although very rare for sata lead to fail Make sure all leads that are attached to your drives dvd\cd and floppy (If Applicable) have secure connections and are not faulty. or just replace them they could be faulty a computer needs power and data to travel through every working device and continue its cycle and have an end so any faulty leads will end up with a computer error
Feb 24, 2013 | Computers & Internet
The 450sx4 screen is bright but no video
Many computer users spend long hours online every day and don\'t realize that looking at a bright laptop screen can be hard on the eyes. If you spend a lot of time in front of a laptop screen, consider reducing the brightness of the screen at the earliest opportunity. There\'s a quick and easy way to perform this task so you can save your eyes as well as your battery power.
Press and hold the "Fn" key on the laptop keyboard. This key is usually located at the top right or bottom left of the keyboard. Press the "Up Arrow" and "Down Arrow" keys, which are usually located in the lower right of the keyboard, to increase or reduce the brightness of your laptop screen. Adjust the level so that you can gaze comfortably at the screen without any glare. Disconnect the battery charger from your laptop and repeat the above procedure. On some laptops, the screen brightness varies considerably, depending on whether or not the device is charged. Hope this helps.
Jan 22, 2013 | Gateway 450SX4 Notebook
Screen blank
Post the manufacturer and model number of the laptop. Model number is located on the bottom of the computer. In the meantime I can only give you a generic diagnosis to follow;
1) Laptop OFF, monitor OFF, connect a VGA monitor to the VGA port on the laptop.
This is an example of a VGA Cable, and VGA connector, (Port),
http://en.wikipedia.org/wiki/VGA_connector
(On the laptop near the VGA port it may have RGB, or External VGA, or nothing )
You can use a CRT type of monitor, (Looks like a small TV), or a flat LCD screen monitor that has a VGA cable attached.
2) Turn the monitor on. If a CRT type allow it to warm up.
Turn the laptop on.
By factory default settings, the display should show on the external VGA monitor.
IF not; Hold down on the Fn key, and at the same time tap once on the Display Toggle-Over key.
The Display Toggle-Over key will be one of the F keys at the top of the keyboard. (F1 through F12)
HP laptops for example, usually use the F4 key.
After performing the above, there is no display on the external VGA monitor;
There are at least 3 display options available;
1) Internal monitor of laptop ONLY
2) Internal monitor of laptop AND external VGA monitor
3) External VGA monitor ONLY
Hold the Fn key down again, and tap once more on the Display Toggle-Over key.
NO display shows on the external VGA monitor?
You have a bad graphics chipset, or the mounting of it to the motherboard is bad.
Display shows on external VGA monitor?
You have a problem with the Video Cable, or in the Display Assembly itself.
A) Video Cable:
This cable connects to the motherboard, under the Keyboard area, or just above it.
It then goes along, and up under the left Hinge.
From there it goes up into the Display Assembly, and connects to the back of the LCD screen.
There is also another wire, or two, that comes from the Video Cable, and connects to the screen Inverter
Primer:
An LCD screen does not produce light by itself. It needs an additional light source. A Backlight is the additional light source.
A Backlight can be a CCFL, (Or two of them), or a series of LED lights.
(These two technologies are used in the present )
A CCFL is a Cold Cathode Fluorescent Lamp.
Similar to Fluorescent lighting used in homes, and businesses, but on a MUCH smaller scale.
[ Average size is 2mm Thick, and the length is almost as long as the LCD screen is in height.
2mm is a little larger than 1/16th of an Inch.
More information on CCFL, and general guide to replacing,
http://www.laptoprepair101.com/laptop/2007/12/09/replace-laptop-backlight-ccfl-lamp/ ]
A screen Inverter is used to convert the power from the laptop, for the LCD screen, and Backlight.
90 PERCENT OF THE TIME the fault can be attributed to a bad screen Inverter.
Some average examples of a screen Inverter used in a laptop,
http://www.laptopparts101.com/screen-inverter-board/
The thin plastic 'frame' in front of the LCD screen, is a Display Bezel. Has many names, depends on the manufacturer.
The screen Inverter is located behind the Display Bezel, and mounted at the bottom of the LCD screen. (Usually)
Primer over.
Check the video cable connection on the motherboard side, and at the back of the LCD screen.
Just with opening, and closing the laptop, the video cable could have been pinched in the Hinge.
This would lead to the video cable being pulled on, and pulling a connection loose. (Or both connections)
It could also lead to damage of the video cable.
Check the cable's outside sheath for obvious signs of damage.
This may indicate damage to the tiny wires inside.
(Stretched/broken)
It is best to completely remove the video cable, and with a multimeter check the wires inside for continuity. (Set the Function knob to Ohms)
B) Display Assembly:
The Display Assembly consists of the;
1) Display Bezel
2) Display Cover. (Top cover of laptop over LCD screen )
3) LCD screen
4) Hinge brackets, and Hinges
5) screen Inverter
6) Backlighting
7) Web camera (IF installed)
8) Microphone (IF installed in Display Assembly )
9) Screen Frame (Holds the LCD screen assembly together )
If the Video Cable checks out OK, move on to the screen Inverter.
Look to see if the cable (Wires) connections to the screen Inverter are tight.
Physically check, do not assume by just looking.
Is there any obvious signs of damage to the screen Inverter?
To test a screen Inverter requires a sensitive multimeter. Read fairly expensive,
http://www.fonerbooks.com/test.htm
Due to the fact;
1) That most do not have a multimeter of this type around,
2) The ease of accessing to replace a screen Inverter,
3) The usually low cost of the screen Inverter,
, the screen Inverter is replaced. Parts changing I know, but you have to use what is available to you.
Replaced screen Inverter, and you still have no display on the laptop's internal monitor?
Replace the LCD screen.
Note*
If a laptop uses CCFL for Backlighting, there is going to be a screen Inverter.
If a laptop uses a series of LED lights for a Backlight, there MAY, or MAY NOT be a screen Inverter.
In this case the LCD screen itself is replaced.
If you post the laptop manufacturer, and Model Number, (In a Comment), I may be able to link you a Service Manual. Also there may be pictorials with disassembly information.
Guide you as if I was sitting next to you.
Regards,
joecoolvette
Apr 28, 2012 | Computers & Internet
No video at power up
See if the problem is the graphics chipset before going any further.
If it isn't then the problem lies with the Video Cable, (Gateway = LCD Cable), or the Display Assembly.
The heading states Gateway LT2104u Netbook PC. This is what I'll be basing the solution on. However the main part of the solution, will apply to all laptops/netbooks.
1) Laptop OFF, monitor OFF, connect a VGA monitor to the VGA port (Connector) on the Left side of the netbook.
[ External VGA display port.
This is an example of a VGA connector, (Port), and a VGA Cable,
http://en.wikipedia.org/wiki/VGA_connector ]
The external VGA monitor can be a CRT type, (Cathode Ray Tube. Looks like a small TV), or a flat LCD screen monitor that has a VGA cable.
Turn the netbook on.
By default the display should be shown on the external monitor.
IF not;
A) Press, and hold down on the Fn key, and at the same time tap once on the F5 key.
(The Fn key is at the Bottom/Left of the Keyboard. The F5 key is at the Top of the Keyboard)
No display still?
There are at least 3 display options;
1) Internal monitor of the laptop ONLY
2) Internal monitor of the laptop AND external VGA monitor
You may have to hold down on the Fn key, and tap the F5 key more than once.
IF, NO display shows up on the external monitor, you have a bad graphics chipset.
[ Chip and Chipset are slang terms for I.C.
Integrated Circuit,
http://en.wikipedia.org/wiki/Integrated_circuit
The GPU is the graphics chipset,
http://en.wikipedia.org/wiki/GPU
The GPU for a Gateway LT2104u Netbook PC is an Intel GMA950 ]
IF, display does show up on the external VGA monitor, you have either problems with the Video Cable, (LCD Cable), or the Display Assembly.
LCD Cable:
1) Connections;
The LCD Cable connects TO the motherboard, and TO the back of the LCD screen, in the Display Assembly.
IF, either connection is loose, you will have display problems.
Check both connections.
This requires partial disassembly of the netbook to access the motherboard side of the LCD Cable.
Also requires partial disassembly of the Display Assembly (Gateway = LCD Module) to access the connection at the back of the LCD screen.
2) Damage;
Observe the LCD Cable on the motherboard side. See if there are any obvious signs of damage to the LCD Cable's sheath.
The most susceptible area to damage is the area under the left Hinge.
However, the LCD Cable should be removed, and a continuity check of the cable should be performed with a multimeter, set to Ohms.
(By checking the connections, you are at a point anyway, that removing the LCD Cable should be no problem)
LCD Cable checks out OK?
LCD Module problem; (Display Assembly)
The LCD Module consists of the;
1) LCD Bezel,
2) Camera Module,
3) LCD Module Brackets, (Includes Hinges)
4) Microphone Module,
5) Wireless 3G Antenna,
6) WLAN Antenna cables, (Wires),
7) LCD Screen Assembly,
8) LCD Module Cover.
Primer:
An LCD screen does not produce light. It needs an additional light source.
A Backlight can be a CCFL, or a series of LED lights.
(CCFL = Cold Cathode Fluorescent Lamp. Similar to Fluorescent lighting used in homes, and businesses)
The Backlight for the Gateway LT21 series of Netbook PC's, is a series of LED lights.
There is no screen Inverter that is replaceable by the consumer.
The repair is to replace the entire LCD Module.
http://support.gateway.com/s/notebook/2009/gateway/lt/lt21/LT21sp4.shtml
To conclude:
If the problem isn't the graphics chipset, (Motherboard replacement), and it isn't the LCD Cable, the problem is the LCD Module.
Gateway LT21 series of Notebook PC's, Service Manual, (Free),
http://www.tim.id.au/blog/tims-laptop-service-manuals/#toc-gateway
Go to where it states Gateway 400. Drop down to the second line, (EC54), and scroll across to LT21 in blue.
Left-click on LT21.
This is a PDF file. The computer you are using now has Adobe Reader on it, which uses PDF files.
After you click on the file name (LT21) it may take up to 30 seconds, before the first page comes up.
{ You can save this Service Manual to your computer. This way you can burn it off to a CD disk, AND remove it from the computer to save harddrive space, and not have to temporarily download it again }
For additional questions please post in a Comment.
Regards,
joecoolvette
Jan 28, 2012 | Gateway LT2104u Netbook
My screen turns black upon startup. For awhile when my screen was on, it would flicker on and off but remain on. Now, the only time I can see the screen is when I unplug vga cable then plug back in but...
You mention a VGA cable so I assume its a stand alone monitor for a desktop PC.
It can be repaired,this fault is usually indicative of a capacitor, maybe two or three bursting in the
a) Power supply.
b) Back Lighter.
or
C) Inverter.
As its 6 years old, I would suggest replacing would be the most cost effective resolution.
Jun 10, 2011 | Gateway Computers & Internet
Gateway fpd1960 19in. flatscreen lcd monitor has "input analog' across the screen, then goes black. tput new cable on still no picture except when i push input button on the side of panel only for a moment...
checkl in your menu or settings if you have inout it to VGA signal...have you tried other mintor in your current CPU if it works? you can scan the input of the signal from your menu and it should be VGA input.
Oct 12, 2009 | Gateway FPD1960 19" Flat Panel LCD Monitor
FPD2275W No PC or On Screen Menu Display
Bad caps, be REAL CAREFUL when take the bezel out, you can easily damage the small ribbon cable attached to the front bezel.
http://s807.photobucket.com/albums/yy352/budm/Gateway%20FPD2275W/
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Jul 28, 2009 | Gateway FPD2275W LCD Monitor
Blank screen
When u power up the computer press "del" or F2 key then check your harddisk is detected or not.
Also load optimal defaults settings.
then restart the computer press F8 key then enter in enable vga mode.then change screen resolution to 1024*768.
Please let me know.
Jun 06, 2009 | Gateway 7330GZ Notebook
Cable for Gateway FPD 1520 15in. flat screen monitor
live in remote area of Nevada were can i find power cable for FPD1529 monitor???
Dec 01, 2008 | Gateway FPD 1520 15" Flat Panel LCD...
Gateway GM5259E  PC Desktop Logo
132 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
