Question about Kirby G5 Bagged Upright Vacuum
Kirby G5 rear wheels lock up completely when in "Drive"
Our Kirby G5 is about 5 years old and out of the blue, when I flip it to "drive" to vaccum carpets the large rear wheels completely lock up. So cannot afford to replace this super expensive vaccum so I need to fix it....Help!
  • hankie0404 May 11, 2010
    if you switch on the kirby , is the wheels running inany direction ????
  • Kirby Expert
  • 324 Answers
When wheels lock when vacuum is OFF - it is normal. If it happens when Kirby is ON then there are a few things that may have gone wrong
Primary drive belt is broken or something is wrong with plastic gears. See how to check the primary drive belt HERE.
If it is fine and gears are spinning - then something must be wrong inside the transmission. Parts for tech drive are not available from manufacturer so you are on your own. It is not really complicated - 2 clutches that engage and disengage depending which direction you push the vacuum. But if something in there is broken - you have to get a new tranny. It is not like getting a transmission for a truck but it still will set you back by about 100 $.
Good Luck
Rocky
Posted on May 30, 2009
The drive on my Kirby G-5 is stuck in forward.
Motor housing will need to be removed and transmission a linkage adjusted. Take to a pro shop for this one.
Sep 08, 2009 | Kirby G5 Bagged Upright Vacuum
Kirby Ultimate G wheels lock up when in drive...
Replace the transmission. The tranny that drives these Kirbys can give you problems.
May 16, 2009 | Kirby Ultimate G Bagged Upright Vacuum
DRIVE LEVER FELL OFF
PLEASE SEND $11.95 FOR THE "SILVER ANSWER PLAN "AND I WILL LET YOU KNOW HOW I GOT IT FIXED (IT WAS EASY)
Nov 25, 2008 | Kirby G5 Bagged Upright Vacuum
I would like to know how to change the transmission on the kirby g-3 vaccum...
Remove the top cover to expose the motor.Flip the vac over and remove the two screws between the drive wheels.The entire power drive will drop from the bottom.Be sure to remove and check the drive belt for wear
Oct 19, 2008 | Kirby Vacuums
G5 Kirby drive problem
Gary...
You need to adjust your transmission. Here's a link that may help...
http://www.greatvacs.com/Kirby%20Transmission%20Adj.shtml
Marci
Sep 05, 2008 | Kirby G5 Bagged Upright Vacuum
Kirby G5 - the Tech Drive does seem to have much power
you need either a new nutreal cam bracket assembly, that is what engages and disengages the tech drive.OR to adjust the handle pivot assy- diffucult . this is not for the faint of heart. it is possible to fix them as i used to repair kirbys, however, I remember how frustrating it was to figure out how to disassemble and reassemble them. it is very complicated to a novice. I would recomend having it repaired professionaly. it is possible for a professional to repair it in a very short period of time.
another thing to consider. look on the UNDERSIDE of your Kirby, between the two drive wheels. just in fronnt of the tech drive/nutreal switch. there should be a screw there, tighten that screw up. actually tighten all of them. on My generation 3 the center screw came loose and it would not go in to drive and it would make an aweful clatter. hope this was helpful
Jul 08, 2008 | Kirby G5 Bagged Upright Vacuum
Kirby G5
nuetral/drive, the g series has a power drive motor for the back wheels
May 13, 2007 | Kirby G5 Bagged Upright Vacuum
Kirby G5 Bagged Upright Vacuum Logo
370 people viewed this question
Top Kirby Vacuums Experts
Jim Parker
Jim Parker
Richard Agent
Are you a Kirby Vacuum Expert? Answer questions, earn points and help others
