Question about BenQ T701 TFT 17" LCD Monitor
BenQ T701 problem
Hi! I have BenQ T701 when I switch monitor on it display like tru red glass and after 3 seconds monitor goes off but the power indicator stays on.
SOURCE: Benq T701 LCD monitor
2SC5707 x4 (lamp driver transistor)....
Posted on Oct 26, 2007
djnupi
  • 26 Answers
SOURCE: benq t701 flat screen no display
see this post
http://www.fixya.com/support/t155971-benq_t701_lcd_monitor
Posted on Dec 16, 2007
viziks
  • 220 Answers
SOURCE: Benq 17"Lcd monitor fault
Resolder the power transistors on inverter board and also check them.If display is not there at all some of this 4 transistors C5707 should be defective.Check associated fuse and Fet which drives the transistor.
Also check with Benq ,Normally offers three year warranty.
Samir
Posted on Mar 24, 2008
SOURCE: Benq T701 Monitor not display
the video converter is brock
Posted on Sep 09, 2008
romsky79
  • 822 Answers
SOURCE: Monitor displays desktop for a short while
this kind of trouble is very common to all LCD monitors. your inverter is shutting down. please check all capacitors at the power supply some are badged or blown on top due to hot pressure inside.
Posted on Aug 17, 2009
When I plug in the monitor the green power LED comes on for approx 2 seconds then goes out. If I unplug the monitor for at least 10 seconds it will repeat the light on for 2 sec. If I unplug it for less...
It can be power supply, backlight inverter, or bad lamp assembly. You need to open it up and do in-depthtroubleshooting. Please read below and look at pictures, learn ablut bad caps, how LCD monitor works.
Basic LCD monitor troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://en.wikipedia.org/wiki/Capacitor_plague
Learn about bad caps: Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Nov 25, 2010 | BenQ T701 TFT 17" LCD Monitor
I have a benq t701 with power problems
faulty power board... possibly caused by blown capacitors..
Jul 03, 2009 | BenQ T701 TFT 17" LCD Monitor
Benq FP92G Display couple of seconds then blank. LED still green.
budged electrolytic capacitor nearby high voltage transformer. 220microcarad/25Volts. apply fresh solder and re-connect lamps.
Jun 01, 2009 | BenQ FP92G+S (Black,Sylver) (Silver,...
Power ok but No Display
see this one
Sep 16, 2007 | BenQ T701 TFT 17" LCD Monitor
LCD flicks on for a second, and then switches off
see this post
Sep 11, 2007 | BenQ T701 TFT 17" LCD Monitor
I had a similar problem: the backlight on my Benq T701 only functioned for a couple of seconds every time a turned the monitor on and then the backlight switched off (sometimes in two stages). An electronics guru at work said with those symptoms the transistors rarely were the problem and I just needed to resolder the connections of the high voltage coils onto the PCB. On visual inspection those solder connections seemed ok, but when I tried to reflow the existing solder at one connection I spotted the problem: just a thin surface layer of solder was present and I had to add solder to fix the problem. The 4 coils each have 6 leads on one side and 2 on the other. I only soldered the connections on the side with 2 leads. In just 30 minutes and without buying parts the monitor is now up and running again.
Jun 23, 2007 | BenQ T701 TFT 17" LCD Monitor
No display
if your monitor is not connected to a pc, then it cannot find a vga signal input and therefore go into power saving mode, which is indicated by the orange light, but as soon as you connect to the pc and power on the light will go green and the monitor will power up.
May 07, 2007 | BenQ T701 TFT 17" LCD Monitor
Benq t701 flat screen no display
see this post
Apr 15, 2007 | BenQ T701 TFT 17" LCD Monitor
Moniter
does it display a picture for a few seconds before it goes blank. or do you not get any picture?. i think i might know what it is but if you could let me know :-) All the best John
Mar 02, 2007 | BenQ T701 TFT 17" LCD Monitor
BenQ T701 TFT 17" LCD Monitor Logo
172 people viewed this question
Top BenQ Computers & Internet Experts
JP Services
JP Services
Tony
Tommmix
Level 1 Expert
Are you a BenQ Computer and Internet Expert? Answer questions, earn points and help others
